Question about Home
Toilet makes a sound of a horn blowing. It will do this several times a day. What is this problem ?
    President:
  • 670 Answers
Assuming that you have a conventional toliet, what I mean is not a powered assist toliet. The problem occurs when the toilet bowl is refilling, the refill value gasket is vibrating as the water fills the bowl. This occurs when the rubber gasket ages and becomes hard. It can be fixed by replacing the gasket. Hope this helps.
Posted on Jul 13, 2010
1998 Toyota Camry XLE, 10 Amp horn fuse blows when using "unlock" on the remote.
It sounds like you have a ground wire trace the wire from the horn back in check to make sure the insulation around the wire is not rip or torn or touching metal also when you used the horn check the button you push to make sure the short is not there
Jan 19, 2018 | Toyota Cars & Trucks
Toilet pumps when not in use
sounds as though there may be a trickle of water going in to the pan from the cistern. To check you could turn OFF the water to the cistern, or tie the float arm up. then flsu the water in the cistern so that no more water will trickle in to the loo. Leave it a goodly time, several hours say, and monitor if it still runs for a few mins every hour. Actually running for two/three mins is rather a long time but first i would think you need to eliminate the possibility of the above steady trickle from the cistern.
Nov 06, 2013 | Saniflo & Saniplus& Macerator Pump
My horn sounds off and won't stop 'til I disconnect battery cable. Why?
sounds like there's a short in your wiring in the steering column, A lot of times with a tilt wheel a wire get loose or gets a short in it. the steering wheel may have to come off to fix the problem but make sure to disconnect the airbag first, I'm not sure what vehicle you have so I don't know where to tell you to look for the connection, may be best to take to a dealership if possible. Hope this helps.
Jan 18, 2013 | 2002 Mitsubishi Lancer
1995 riviera buick horn want stop blowing and some times blow fuses
Faulty horn relay.sounds like relay is sticking or horn botton is stuck.
Jun 06, 2012 | Buick Riviera Cars & Trucks
On my 1995 crown vic. one day horn blew on its own for about an hour. i looked and fuse was blown now when i put new fuse in and hit horn, horn sounds for second and fuse blows. everytime i put fuse i
Sounds l;ike the horn itself has a short. Try another from a salvage yard. If fuse blows again, it's likely a wire to horn that lost insulation and touching metal.
Good luck.
Feb 01, 2012 | 1995 Ford Crown Victoria
What do I do to stop water from leaking from the tank, it refills itself several times, day or night? The toilet looks like a Sedona, although the shape of the tank differs a bit, the width is the same,...
Sounds like something in the floating device is bad so it doesn't shut off when filled. We just replaced our flush valve on ours because the toilet keep running.
Jul 11, 2011 | Toto Toilets ST784S 12 Sedona Beige...
Horn blows randomly when closing doors
Horns have constant power all the time so when you press the horn button, all you are doing is grounding the circuit and that makes the horn blow. Usually what happens is that a spring breaks underneath where the horn button is or something allows the horn button to ground out somewhere, possibly even through the inside of the steering column.
Jun 15, 2009 | 2003 Volkswagen Golf
04 CooperS: Horn does not work
Check the fuse first. should be in the drivers footwell. Make sure that it is not blown. 90% of the time fuse will just blow due to high resistance from one of the horns. There is a high and low horn often it requires to replace one and try the horn and see if it blows. Then replace the horn that blows the fuse.
Feb 18, 2009 | 2004 Mini Cooper
Home Logo
53 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
