Question about Dometic RM2652 Refrigerator
The fridge is blowing the 12 volt fuse as soon as I power up the motor home, The fridge is turned off and it still blows the fuse, I tried to undo the 2 wires that go to the 12 volt block on the fridge and turned the power on to the motor home and it does not blow the fuse and eveything workes fine that is on the fuse example, the stove light,fan,outside light are all on the same fuse, And everything works as long as I have those 2 wires disconnected as soon as I hook up those 2 wires it just blows the 20 amp fuse every time, If you have any solutions that would be great,Thanks Shane
  • 905 Answers
Unplug the wire located at terminal J4 (12v positive) on the control board, and see if you are still popping fuses. If so, then the fault lies between the wire you just removed and the fuse that keeps blowing.
If the fuse holds, and blows when you plug the wire back onto J4 terminal, then unplug the wire(s) at J2. These go to your door heater (used in humid conditions to remove condensation), as well as the interior light. The switch for the door heater is located on front panel, or is at the top edge of the freezer compartment with door open. It is not unusual for this switch to have issues since it gets chilled and moisture condenses on it. If unplugging the wires at J2 allows the fuse to hold, you probably got a shorted heater or bad heater switch. But, pull the lens off the interior light, and check the contacts there as well.
If the fuse still blows with J2 removed, then unplug the connector in the top left corner of the control board. This goes to the control panel on the inside of the fridge. If the fuse blows, replace the control board. If the fuse holds, the replace the control panel.
Posted on Jul 18, 2010
Why does 15 amp 250 volt fuse in my lg refridgerator keep blowing
the 15 amp fuse is blowing because the current draw to run the compressor exceeds 15 amps
that problem could be from a failed start/ run capacitor or a failed compressor motor (I am betting on the capacitor)
the best answer is to get a fridge technician to check it out as the capacitor is a cheap fix while the compressor unit is as costly as a new fridge
Jun 25, 2015 | LG Refrigerators
Just bought a used 1987 Real-Lite truck camper. The roof air unit is Dometic as well as the LP/AC refrigerator. When turned to "cool" the air conditioner really draws down, dims the lights, and eventually...
To start with, if it's plugged in to a 15 amp breaker, and extension cord, the compressor starting up may just be enough to trip the breaker. It will draw close to 15 amps on start-up of compressor, and if there is a light extension cord used to plug it in, that only makes it worse. Make sure you shut all other breakers off in panel except AC, and try it. If you have water heater on hydro, fridge on hydro, and then try to start AC compressor, you'll be way over the 15 amps, especially if it's a light extension cord.
Keep in mind, in order for fridge to work, you need 12 volts DC (Battery) power going to back of fridge. If the controls aren't lighting up at top, you've most likely got no 12 Volt DC power going to fridge. Check all fuses as well.
Jun 02, 2010 | Dometic Rooftop RV Air Conditioner
I have a 98 1500 silverado . I was driving home this weekend and came up upon a hill and my truck completely shut off , lost all power . Found my ecm-1 fuse was blown . It blow everytime I go to turn my...
Well you have a short and still have to narrow it down.
How difficult that is depends on what attaches to that fuse.
If it is just the ecm, then disconnect that and see if the fuse still blows?
(if you want to stop wasting fuses, you can just use a test light in its place.
If you have a short, the 12 volt light will be bright. If things are normal, then the 12 volt light will be dim because in series it will only be getting 6 volts.)
If removing the ecm stops the fuses from blowing, then take it in and have it tested.
May 22, 2010 | 1999 Chevrolet Silverado 1500
Front fans wont blow
If the fan is not blowing turn it on and see if the motor is what is buzzing. It sounds like the fan motor is bad. You can check the fuses and also if you know how to test for power see if the motor is getting 12 volts. If it is and is not turning then then replace the fan immediately.
Feb 13, 2010 | 2005 Dodge Grand Caravan
Blows 15 amp car fuse as soon as switch is turned on nothing plugged into inverter
If the fuse doesn't blow until you turn the inverter on, the problem is in the input circuit. First, be sure the polarity is correct when you're connecting the inverter. If you manage to get the 12 volts hooked up backwards this will blow the fuse. If the input polarity is correct, the diode inside that protects against reverse polarity may be shorted. Beyond that, it's difficult to make any suggestions about what parts to check. You would need to use an ohmmeter to check the parts in the input for very low readings from the 12 volt input to ground. If you can do this yourself or know someone who can, it might be worth a try. But if you try to take this somewhere for service - if you can find a shop willing to look at it - it may be more economical just to replace it.
Good luck with the inverter, and thanks for using Fixya!
Nov 24, 2009 | Powerline 0900-73 Slimline Inverter
1986 RV blows instrument panel fuse when switch pulled
The headlight switch has a rheostat built into it to dim your dash lights, it may have shorted out. As soon as you turn on the switch this rheostat comes into play and is probably whats blowing the fuse. I think if you replace the headlight switch, it will solve your problems.
May 28, 2009 | 1986 Ford Econoline
1984 ford ranger keeps blowing the running light fuses. when i let it sit at idle it won't blow the fuses but as soon as i start driving with in 5 mins or so it blows.... any ideas?
short in the wires will need a wiring diagram and ohm/volt meter to locate the problem, test lights work well to.
you will need replace the fuse with a light bulb so that the power will not go away. and you will have to search for power going straight to a ground source.
usually a raw wire from rubbing somewhere. can do a quick visual inspection first for the obvious, and then use the meter at certain points till you find a volt drop.
May 13, 2009 | 1984 Ford Ranger
Heater/air conditioner
check for power(12 VOLTS) AT THE BLOWER MOTOR WIRING. IF YO HAVE POWER YOU NEED A NEW BLOWER MOTOR. IF NO 12 VOLTS YOU HAVE A BAD FUSE OR RELAY.
Mar 22, 2009 | 2006 Mitsubishi Endeavor
Fuse blow as soon as it plug it in
sounds like your inverter has died :)
Jan 21, 2009 | Car Audio & Video
Dometic RM2652 Refrigerator Logo
629 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
