Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
Cool tech 34788 purges alot. Excessive purge time and set error messages for being unable to purge.
    Problem Solver:
  • 14 Answers
ID your internal tank if it comes back clean your air purge transducer can be out of calibration and needs replaced
Posted on Jul 17, 2012
    President:
  • 180 Answers
Please check 1# The refrigerant which you'v add to the machine, it may CONTAMINATE or NOT PURE R134a. the machine will purge continue while active VACUUM mode if refrigerant is not origenal ! Identify refrigerant if possible.2# Check the automatic air purge device & air purge solenoid repair or rebuild as require
Posted on Jul 13, 2010
Unable to clean 46. this error display in lcd of brother dcp585cw printer. how to solve me this problem.
Machine Error 46 - Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An "initial purge", for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Jun 26, 2011 | Brother DCP585cw AllInOne InkJet Printer
I'm Archie i've a Robinair 34988 just five days old and having problem with it. It keeps displaying HIGH PRESSURE (HIGH PRESSURE RESET). whether you try to vacuum,recharge, refill or anything...
This is a common problem of Model: 34788, 34788-I, 34988, AC34788, GE48800 etc.
You need to replace air purge solenoid (Air purge solenoid located on top of the ISV tank, if you open front panel cover then you can see it on top of the tank).
After doing above stapes and your problem still exist then you have to replace PCB relay board. Just claim for warranty (Air purge solenoid and PCB relay board) from where you bought the machine.
Hope this will help to solve your problem, if so please vote for it for farther help! Good luck
May 16, 2011 | Robinair Cool Tech 34700Z Recovery,...
I have a robinair 34788 and when i tunr it on it shows a massage "hi pressure "
Hope this will solve your problem, if so please vote for it for farther help! Good luck
May 13, 2011 | Robinair Cool Tech 34700Z Recovery,...
UNABLE TO INIT
Hello all - here is the code solution - happy printing!
Machine unable to int - Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
1) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
2) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
3) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
4) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
5) Press the 9 key twice to return to the standby state
Jan 06, 2011 | Brother DCP 115C All-In-One InkJet Printer
It says "unable to clean"
Dec 20, 2010 | Brother MFC-5840CN All-In-One InkJet...
WE HAVE A ROBINAIR 34788 JUST OUT OF WARRANTY. WILL NMOT PURGE AIR FROM SYSTEM AFTER TWO OR THREE VEHICLES. LOCKED UP. IS THERE SOMETHING THAT WE CAN DO AT THE SHOP HERE W/O TAKING TO REPAIR FACILITY 60...
Opeen front cover and check air purge solenois (12VDC) on top of ISV (Internal storage vessel) tank. It may need to replace solenois coil or rebuild solenoid assy.
Sep 28, 2010 | Robinair Cool Tech 34700Z Recovery,...
Cool Tech 34788 "air purge not working"
Please check ISV tank air purge (pressure) transducer & 12V DC discrete Solenoid ( both lacated on top of ISV ), it sounds like defective!
NOTE: Never use Automatic Mode till you are not very familiar with this machine
Jul 06, 2010 | Robinair Cool Tech 34700Z Recovery,...
Hi. We've got a CoolTech 34788. Whenever the machine tries to purge air from the tank, we are consistently getting a message saying that the "Air purge timed out". The internal tank shows ~10 lbs of r134a....
It's sound like normal. However when thes message come again you just press Stop/No key to terminates this function. Press Recover & see if the machine is going to recovery after self clearing. If it is then you can continue to work. Hope this will help you best of luck!
Jul 01, 2010 | Robinair Cool Tech 34700Z Recovery,...
DCP-110c is showing machine error 46. I have followed instructions as per cene765 solution #1 withput success. I get as far as 'maintenance 80 display. Pressed 'mono start' many times but still displays...
Many thanks - I fixed the error 46 by following the helful solution provided below.
mydcp110c
Rank: Apprentice
Rating: 86%, 8 votes
Hello!
Here is the "Unable to Clean" (code 46) solution:
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
Solution no. 1. (DCP-110C):
The proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times.this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Dec 11, 2009 | Brother DCP-110C All-In-One InkJet Printer
Not printing
Machine Error 46 – Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
Carry on printing !!
Nov 21, 2007 | Brother MFC 210C All-In-One InkJet Printer
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
786 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
