Hello, Roper (Whirlpool) Washing Machine toploader: Model: RAS7133KQ0. Machine will no longer 'spin', agitate. Fills with water O.K. Checked drain hose, it drained into bucket O.K.. Power to Machine O.K. Suspect either bad "Gearcase assembly" pictured in basic instructions, or a bad 'drive belt'? Could not download any service manuals for this unit. Have not attempted to remove rear (large) cover as yet. In work searching for recipt, purchased at either Lowe's or a Sears. Thanks for any help with this, regards, Mark.
  • Mark Pagano Jul 14, 2010
    Yes, however, problem also involved a bad lid switch. Coupler was worn but not broken. Replaced both and machine runs great! The new couplers were beefer with metal inserts. Original coupler designed to fail? Annoying. Thanks again, Regards, Mark.
  • Washing Mach... Master
  • 8,220 Answers
This washer does not use a drive belt. It uses a transitional coupling to transfer the motors power to the pump and transmission. The motor does double duty, it has the pump mounted on one side and the transmission on the other and it is reversing. One direction does the wash mode and the other direction does the pump and spin. The transmission feature a neutral pack which allows the pump to drain the water first. Then when the timer pauses for a moment the spin pawl gets slung outward under the main drive gear in the transmission where it will catch 1 of 3 spin bosses under the main drive gear. This causes the basket to spin. All of that is shown in the training manual I am including. So what can go wrong? I strongly suspect your coupling has failed.
A common problem with these washers. Very easy to repair.
   Roper (Whirlpool) - 13c23df.jpg670fe8f.jpgHello, Roper (Whirlpool) - 16fc208.jpgttp://i.fixya.net/uploads/images/16fc208.jpg" alHello, Roper (Whirlpool) - adbf410.jpgjpg" class="h_mi" />adbf410.jpgb224841.jpgb65ce5d.jpg4ddb052.jpg
Training Manual for direct drive
My FixYa Tip- How it works: Direct drive washerMy Direct Drive blogpage
Posted on Jul 13, 2010
My 5 year old Roper washing machine fills up, washes/agitates the cloths, drains them when the washer get to the rinse line to start the rinse cycle it stops, and all I hear is a humming. The machine will...
I'm not familiar with roper washing machines so I'll ask the question does it have two fill hoses. Most European machines now only have one fill. If it has two then it sound like the machine takes the initial water from the one fill and the rinse cycle water from another. The humming sounds like the valve for the other fill needs replacing. These are quite inexpensive and easy to fit. Power off.. remove lid ....switch of water...take out valve when you establish which one is affected and replace
Oct 17, 2013 | Whirlpool WTW5700S
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Have a whirlpool roper washing machine, runs thru cycle perfect but will not spin...lid sesor or switch was no good so took out and direct wired does that switch have to be there to operate to spin
I have a Roper washing machine model # RA S7133KQ1. On all cyle it does not spin or drain but it does agitate. I checked the capacitor, timer and water pump. All is good there. What could be the problem? There is no agitate or spin solenoids in this unit. Could it be the motor coupling for the direct drive washer? Am I missing something else that could be wrong with it? Waiting to hear from the expert.
May 08, 2010 | Roper RAS6233KQ Top Load Washer
Washer fills up but wont switch to agitate
posibble bad timer. if it is skipping over the agitate.
Jun 15, 2009 | Roper RAS8445KQ Top Load Washer
Washer stops after the tub fills, agitator and tub do not spin
Your lid switch is bad. If you give model number I can give you the part number you need.
May 18, 2009 | Whirlpool Washing Machines
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
Roper(whirlpool) washer will not spin model # ras7133kq1
check the motor coupler between the motor and the transmission
Mar 17, 2008 | Roper RAS8445KQ Top Load Washer
Maytag topload washing machine
either you have a bad pressure switch or the latex hose to it or has a hole in it it may have come off either the tub or the switch if it was shaking badly it will be connected to the fill option switch on the control panel go down then hook to tub
Dec 30, 2007 | Washing Machines
Washing Machines Logo
162 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
