Question about GE Energy Star WCVH6260F Front Load Washer
Smell from water remaining in grey seal
I have noticed a smell in my laundry room, it is coming from my washing machine, it is a GE model #GCVH6400J. After the load is complete, water still remains in the grey trim/seal type area at the front of the drum. Why does this happen? Also, there is sometimes water in my bleach / softener dispenser, too which is really odd. Please help!! We no longer have warranty on this machine, it is 2 years old - but thankfully I have a handy hubby:)
  • 3 Answers
My GE washer model wcvh6400j0ww was leaking. May be standing water under your machine. The repair person thought the gasket. It turned out to be the water in-let pipe (WH41X10118 and you will need seal WH41X10119) and not the gasket. He ordered the gasket and took machine apart to replace and found cracked pipe. Take your machines front off and make sure it is the gasket leaking. Good Luck,
Posted on Jul 20, 2010
The grey rubber door seal in our Electrolux EW1080 F has lots of black mould trapped inside it. Is there any way to remove the entire seal to clean it or do you just have to try your best to wipe around...
Don't use eucalyptus oil, because it will damage the rubber, and the smell will linger.
The black mould should be wiped off using a damp soft cloth and mild detergent. Diluted bleach (1 part in 10 parts cold water) can also be used, with care (wear gloves); don't use full-strength bleach, because it can damage rubber and corrode metal. Leave the door and detergent drawer open between washes and overnight to keep air circulating through the machine. This will slow down the regrowth of mould. For further improvement, wipe the seal dry after each use of the machine. If your laundry room remains steamy or damp for hours after washing, improve the ventilation
Jan 31, 2018 | Washing Machines
I have a he2t wash comes out smelling like mildew really tired of it please do not tell me to leave the door opened I do still smells
The trick is to clean the interior using regular detergent, baking soda, and hot water; run a complete cycle without any laundry in it. Wash the rubber boot where the door seals with same mixture at which point the interior should smell fresh and clean. Now is the time to leave the door open after use so that the remaining moisture can evaporate out to prevent mold growth. Hope this helps!
Sep 23, 2010 | Kenmore 44072 Front Load Washer
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Apr 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Foul odor from front load washing machine
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Nov 06, 2009 | Washing Machines
Laundry room smells like rotten eggs
Does the sewer drain line have a trap at the bottom that prevents sewer gas from entering the room? If the smell seems to be coming from the washer itself, run a wash cycle empty with a cup of baking soda, detergent and hot water to clean the interior.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Maytag Neptune washer #MAH550Bww Serial #88922156AJ has water coming out the front door and getting my laundry room floor wet. I have also noticed a musky smell in some of my clothes just after washing
You need part 12001772. The issue with the smell is a combo water, too much soap and too long of a cycle. 2 Tbl of soap and a lighter cycle is usually fine for these machines, plus to keep the soap drawer clean:) Here is a pick of what you need. See part 18
Oct 12, 2008 | Washing Machines
Smell coming from washing machine
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Apr 18, 2008 | Hotpoint WMM39 Front Load Washer
Rubber door seal mouldy
Wouldn't normallyexpect a few mould spots to leave that bad a smell, so likely you've got two distinct issues.
Starting with the water trapped in the seal: Open the door and very carefully slip your fingers into the seal where the water is gathering (to stop your hand getting trapped between the drum and the outer casing, put your other hand inside the drum and push it up out of the way - just be careful not to let it spring back too fast).
At the very lowest point,of the space inside the seal, either at the very front or the very back (so tucked into the corner between the floor of the seal and it's front or back wall), you'll find a little drainage slot. Once you've cleared the inevitable blockage from this slot, your seal problems should vanish.
If the foul smell is coming from inside the machine, the problem is likely to be grey sludge inside the works of the machine. This is usually caused by modern detergents not being quite as good at working at 30 degrees as they claim to be. The answer is to run a cycle every now and then with no laundry, detergent, or conditioner in the machine, on the longest, hottest programme the machine will support. This should be sufficient to dissolve the rotting sludge and pump it away down the drain.
A.
Apr 06, 2008 | Zanussi ZWF1440 Front Load Washer
New Bosch water not draining
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
Apr 01, 2008 | Bosch Axxis WFL 2060 Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
204 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
