Question about Systemax Venture PC Desktop
My computer, keyboard and monitor just turn themselves off. When I turn it back on it doesn't say anything about closing improperly.
    Sniper:
  • 51 Answers
L just build a new computer an the cup fan runs but nonthen else no screan ..... send nothing to my monitor. It doesnt say check signal, unless i unplugg it. .... So I turned off and back on and this time it's reverted back to the ...
Posted on Jul 13, 2010
Monitor doesn't turn on
1ST CHECK POWER CORD.
2ND CHECK CONNECTION ON BACK OF PC
3RD HAVE YOU INSTALLED, DELETED OR REMOVED ANYTHING FROM YOUR PC PRIOR TO THE MONITOR SHUT OFF ON YOU
Feb 17, 2013 | Dell ST2420L 24 inch LCD Monitor
My computer is not displaying anything (black) on the monitor even though the computer is turn on
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on.
To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard.
Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue.
Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue.
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment.
Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard.
Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector.
Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place.
Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken.
If the monitor doesn't work, the motherboard or video card might need to be replaced.
hope this helps
Sep 17, 2012 | Sony Computers & Internet
Computer doesn't recognize ez eyes keyboard
unplug the keyboard, go to the manufacturers website and download and install the drivers, plug the keyboard back in.
If that doesn't work
check your device manager and see what keyboards are in the keyboard section. delete anything but the hid keyboard device and the standard ps2/2 keyboard from the keyboard section. repeat the first set of instructions
if that doesn't work either
take the keyboard back it is most likely faulty
Aug 25, 2012 | Toshiba Computers & Internet
My acer travelmate 8100 turns on but screen is blank
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard.
Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced.
hope this helps
Aug 19, 2012 | Acer Computers & Internet
Black screen
hope this helps
Jul 20, 2012 | ASUS K60ij 16" Genuine Laptop Hard Drive...
My hp v75 monitor doesn't come on. All the lights
Make sure the VGA cable is properly inserted to your pc and monitor
Jun 29, 2012 | Computers & Internet
Dell 17" monitor is not turning on.
1. Check the cable with the blue connector. Make sure it's plugged well to the back of the computer.
2. CHeck the light on the CPU's power button. If it's solid green, press the numlock key on the keyboard. Tell me, if the numlock light on the keyboard turned off or on. You can press it again if you didnt catch anything.
3. If there are no lights on the keyboard or the computer when you turn it on, the computer is the problem.
Just post here what lights are present or what happens when you press the numlock key.
Jun 16, 2009 | Dell P793 17" CRT Monitor
Mystery icon on Dell Keyboard Model SK 8115
The icon should mean the NUM LOCK is on. All that does is activate the numberpad on the right side of the keyboard. Chances are the monitor's backlight is bad. Try another monitor. You can also get a flashlight, turn it on and hold it very close to the face of the screen. Look closely at the screen, can you see your desktop or login screen? If so the backlight is not working with in the monitor.
Jun 01, 2017 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Systemax Venture PC Desktop Logo
49 people viewed this question
Top Systemax Computers & Internet Experts
Steve Allison
Steve Allison
pankaj rautela
pankaj rautela
Abhinandan  Patil
Abhinandan Patil
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
