Question about Whirlpool Kenmore 5.9 cu. ft. Extra-Large Capacity Electric Dryer
Wneh the dryer is first started up with a fresh load of wet towels etc. there is a sqeal which sounds like a worn automobile fan belt and goes away after a while. is the fan belt worn and in need of replacement? If not can you diagnose the possible problem by email? Desmond Kramer
3 Suggested Answers
  • 4 Answers
SOURCE: dryer won't start
that dryer belt broke...see other posts on how to change it
Posted on Apr 10, 2008
  • 864 Answers
SOURCE: wet clothes
Make sure the lint filter is clean and that the exhaust duct and outlet are not clogged. If the duct is clear check to see if air is being blown through. If not then the blower fan may be disconnected from the motor shaft.
Posted on Jan 15, 2010
Fixing a front load dryer
it sounds like the belt may be either hung up or broke and stuck in
the pulley
Feb 05, 2016 | Dryers
Tip
Automobile headlight and lens cleaner
# 1 Old automobile bodymans trick: sand lens with # 1200 sand paper,
use any automobile body rubbing compound and then clean off with
a soft cotton rag or towel. good luck!
#2 squeeky fan belt, mix some cheap dish soap in a spray bottle
and spray on fan belt or belts if belt stops making noise, just
replace fan belt. good luck!
on Jun 25, 2011 | Chevrolet C3500 Cars & Trucks
Sqealing
Two things to check. If your car has a harmonic pulley on the crank shaft check that it is not slipping on the rubber insert and squealing. Second point is when there is no need for power steering ie straight ahead or idling there is no load on the pump so it will feel ok but as soon as you move the position of the steering wheel the valves close off and the pump comes under load. If the drive belt only drives the power pump and it broke then I would suspect a problem in the pump. Check that the belt is the correct size for the pulley groove as if it is too small the belt will run on the bottom of the pulley and slip, and squeal.
Jul 24, 2013 | Cadillac Brougham Cars & Trucks
Dryer is sqealing
have you inspected the belt on it? sounds to me like one of the components inside the dryer like the belt could be worn out or rubbing. Dryers are fairly simple to take apart, just take a few screws out and look around to see what you see
Jul 22, 2012 | Frigidaire Dryers
Dryer has started to make a loud sqealing when it starts and gets up to speed, the kind of sound a loose fan belt makes on a car, and now just makes a buzzing sound when the button is pushed but dosen't...
If you push the start button and you here a buzzing sound, This sounds like the motor is bad.
Somthing you can try and this might not work. but open the dryer door and turn the drum a littel bit then close the door and try to start it. If it starts running again then you have hit a bad spot on the motor.
If it just still just makes the buzzing noise then the motor is most likley bad.
Jan 15, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Dryer wont start up quickly
HI the belt is worn and so it slips on the motor pullet. relace the belt thanks the appliance docp
Oct 15, 2008 | Amana Dryers
Dryer won't start
Mar 29, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool Kenmore 5.9 cu. ft. Extra-Large Capacity Electric Dryer Logo
48 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
