Question about Philips DECT 2252S Cordless Phone
Can I buy extra headset for Philips SE 450 twin phone?
I have Philips SE 450 twin phone. Can I buy an extra head set for this?
5 Suggested Answers
  • 79 Answers
SOURCE: need instructions to make cordless twin set work
If you had a power failure the memory may have been affected. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You may need to register the handset to the base by following the instructions in the user's manual
Posted on Sep 12, 2008
  • 49 Answers
SOURCE: My Philips SE 450 sounds
you may have to enable a feature called voice enhancing on your voice, the echo is sometimes caused by feedback from various sources. it should appear as a VE symbol when you have it turned on, this helped me greatly when I was going through the same prob, it also makes the phone reception sound better on both ends. you may have to call the phone company to check to see if they installed the lines right in the first place. Also if your phone has the ability to change channels you can keep switching channels until you find one that sounds better to you.
Posted on Nov 13, 2008
richa33
  • 71 Answers
SOURCE: Philips CD135 Twin Cordless Phone
Disassembly the battery pack, and power on after that.
Posted on Jan 21, 2009
SOURCE: How do I turn my phillips phone SE 450 on?...
push talk
Posted on Jun 09, 2010
How to pair a philips cd 245 as an extra handset
Contact Philips support at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=us&userLanguage=en
Mar 21, 2015 | Philips CD235 Twin Cordless Phone
Philips SE 455 twin set cordless: The charge lasts less than an hour when using speaker phone, so I am looking for replacement batteries. Phones only 2-3 years old and absolutely fine in all other...
A higher capacity battery should work even better because a fully charged 900 mAh battery allows the phone to operate 50% longer than a 600 mAh battery between charges. I have had good results with Rayovac Recharge Plus 900 mAh in my Philips SE450. This phone will latch and not operate upon ringing if it doesn't like its batteries (probably high internal resistance), even though the batteries test good on a battery tester.
Jun 28, 2011 | Philips 2252 Twin Cordless Phone
My neckband comp headset hasnt come with instructions
A head set like this if for your computer or a phone, one plug is a ear bud or head phone for listening, the other plug is for a Mic. to talk into.
Jan 10, 2010 | Philips GOGEAR SA6045 MP3 Player
I use the cordless phone binatone twin model 3300 e 2107th on one of the headset now only writes HBI singala it does not have a while before it was written, the signal h2 b2.Sada constantly blink (MIGA)...
Problem is solved On the telephone headset to make the first reset, selecting keys 1 0 and confirm the green headset. After that, the BASE press for registration until the hear a beep. Within 30 seconds the phone headset press PROGRAM 1 6 and enter the number 20,000 and confirm the green headset, or OK. Telephone handset is registered as the second in a row and at the same writes h2 n2. Problem solved PROBLEM JE RIJEšEN Na telefonskoj slušalici prvo izvršiti resetovanje, odabirom tipki 1 0 i potvrditi zelenom slušalicom. Nakon toga na BAZI pritisnuti tipku za registraciju dok se ne čuje BIP. U roku od 30 sekundi na telefonskoj slušalici pritisnuti PROGRAM 1 6 i ukucati broj 20000 i potvrditi zelenom slušalicom, odnosno OK. Telefonsk slušalica registrovana kao druga u nizu i na istoj piše h2 n2. Problem riješen
Oct 28, 2009 | Motorola Mobility E51 MD7161-2 Twin...
My Phillips se 450 home phone..
This is likely one of three things. The battery is toast, the connections on the phone or charger staion are dirty, or the power supply to the base is not putting out the correct voltasge any longer.
Jul 15, 2009 | Philips Lands Phones
Philips SHM3300 Headset
try to unplug your main speakers and replace the head phone, if it still doesn't produce any sound, then you may replace your head phone.
Oct 30, 2008 | Philips SHM3300 Headset
Call transfer problem between Philips VOIP8411B and Plantronics C65 headset
sounds simple in the manufacture hand book that came with head set
states on some models they have this particular compatible mode built in
depending on specs of phone and headset gotta make sure that they were built with these built in specs and not all dect/gap work with other sets
Jun 02, 2008 | Philips VOIP8411B/37 IP Phone
Pairing with my Sony Ericsson w810i's MP3 player
hi stefan,
sorry to let you know but sony w180 does not suort an A2DP profile,
which is necessary to listen music wirelessly. so u'll have to change ur handset if
u want to listen to music via ur bluetooth headset.!!
good luck!
Dec 11, 2007 | GN Netcom GN Jabra BT620s Bluetooth Stereo...
Philips DECT 2252S Cordless Phone Logo
206 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
