Question about Eureka Enviro Steamer 310 Stick Vacuum
My eureka steamer mop just stopped working - Eureka Enviro Steamer 310 Stick Vacuum
Too much steam comes out of the mop and floor is dripping wet when it first comes on.
I had this happen to me when I first bought mine. You are most likely overfilling
it with water or lifting the head off the floor too much. THEN you get flooding.
Jun 06, 2011 | Eureka Enviro Steamer 310 Stick Vacuum
I ned at instruction book for electrolux enviro multi steamer
You didn't specify which model you had, but I assume it's the newer Eureka Enviro Steamer Model 313A.
Here's a link to the owners manual for your Steamer. If you have an older Enviro steamer, please feel free to reply using the comment field below. Also, if you found this solution helpful, please be sure to leave feedback for me. Leaving feedback is greatly appreciated by the FixYa community, and ensures that repair experts continue to leave great FREE advice, as opposed to just answering the premium, or paid questions.
Hope this helped you, thanks again.
Eureka by Electrolux Enviro Steamer Owners Manual for 313A
Jan 07, 2011 | Vacuums
The Shark Steamer stopped steaming. Can I fix it
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Nov 22, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
What is the difference between the 2 eureka enviro steamers: the 310 model, and the 313A? are they doing the same job, and which one is a better buy i.e., does the job, and does not cost an arm and a leg...
Greetings,
The Eureka 310 Envirosteamer is no longer made. Eureka discontinued this particular model several years ago. It was a very highly rated steam mop at the time, so Eureka came out with a new model that had a very upgrades which was the Eureka 312, which is also now discontinued. These two old models are discontinued because Eureka has introduced the 313A which is the best model they've made to date. This is the most current, and only upright steam mop that Eureka makes currently, so if you are going to buy a Eureka, the 313A is the one that you want to buy. It's a great steamer I think. We do offer a 60 day full money back guarantee with any purchase, I hope you will consider us when you're ready to go for it.
Please feel free to request a clarification here on Fixya if you have any questions I can answer further for you.
I hope this was helpful information for you. If this was helpful, please rate it as helpful by clicking on the thumbs up icon in the lower right hand corner.
Thank you so much,
Chris J.
Mar 17, 2010 | Eureka Enviro Steamer 310 Stick Vacuum
Shark steamer has stopped working, where to look
There is no fix...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Jan 01, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Euro pro mop the ligt wont turn on anymore.
my husband fixed my shark steamer by taking it apart and testing it wire by wire .the problem ?a fuse hidden inside the unit..unscrew the screws and get inside the steamer .at the bottom of the steamer there is a gold orange foil looking piece .under that is a small fuse .unless you can find another fuse just cut that one off and rewire the wires together .shark now comes on
Sep 27, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My steamer stopped producing steam, and then it seemed to short
heatman101
yk
Jul 04, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
How much water should I put in Eureka model 300 steamer
Use 12 ounces of water.
It's best not to use extremely hard water in the Eureka steamer due to mineral deposits it may leave behind.
If you need cloths for your Eureka 300 or 310/311/313A see my listings on eBay by searching "eureka steamer."
This is a great floor cleaning machine. I have several for use on large areas of linoleum and sealed hardwood in our home.
Jan 04, 2009 | Euro-Pro Shark SC-505 Handheld Steam...
Need directions on how to clean clogged steam nozzle
If your steam mop is Enviro Steam Mop by Eureka. remove the 2 screws on the bottom of the steamer, that holds the center panel on. (Not the screws that hold the whole bottom.) Use a needle the clear the steam holes. Soak the panel in white vinegar for a couple of hours and scrub with aa brush to remove the lime calcium deposits. Check the center hole that goes into the steam and make sure it is clear. Reattach the panel. If the panel does not fit snuggly (either end does not contact the base panel, add two more screws about an inch in from either side. I used stainless steal screws because of the consist moisture. Used screws that are no more than 3/4 on an inch long and about the same diameter as the two you removed.
Apr 06, 2008 | Eureka Enviro Steamer 310 Stick Vacuum
Eureka Enviro Steamer 310 Stick Vacuum Logo
398 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
