Question about Polaris 800 Twin Sportsman Ride on Toy
Our polaris 4 wheeler will not go forward only reverse. How do we fix this problem?
    Genius:
  • Polaris Master
  • 1,508 Answers
Rmove the battery and black plastic piece under the seat, this will give you access to the shifter switch, make sure that both of the connectors are connected
Posted on May 23, 2012
3 Suggested Answers
  • 4 Answers
SOURCE: peg perego polaris 4 wheeler
If it runs only in slow speed your hi/lo speed switch is bad. Cheapest I've found is at tigerimports.com part#MEPU002 for $11.00 plus $2.00 shipping USP. Hope that helps.
Posted on Oct 19, 2008
  • 156 Answers
SOURCE: I have a peg-perego polaris four wheeler. One
I would take off the wheel that is not spinning and see if the wires have come loose.
My grandson had a polaris 700 and one of the wires had come off.
I needed a gearbox 3 days later (go figure) and I got it at
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-batteries.html
These guys help me out with all my toy problems.
Hope this helps
Posted on Jul 17, 2009
2010 polaris sportsman 300 awd is not in awd in reverse is this normal or do I have a problem
Push the yellow button on the hand area. On some models, it engages 4 wheel drive
Jan 06, 2014 | Polaris ATV
2-wheel ATV 4-wheeler won't go forwards but will go in reverse
If this is an automatic 4-wheeler, the shifting fork will bend when shifting from fwd to rev. or vis-versa. because your not completely stopped when you change directions. (kids do this to mine so many times I am tired of changing the darn thing) The part costs appx $50. Looking at the old part you can't tell it's bent.... If it's a manual tranny then your linkage is worn and needs adjusted.
Jan 05, 2014 | Atv Cover Quad 4 Wheeler Yamaha Yfz450x...
Taotao atv 125
He has learned an expensive lesson on equipment abuse. Rolling backward "slammed" in forward ... probably broke a shaft somewhere. Just as '... there is no crying in baseball' ... there should be no 'slamming' of gears in driving.
Sep 08, 2013 | Motorcycles
My Polaris 24 volt power ride on toy when put in reverse would go forward. When shifted in drive would go in reverse. Now it does nothing. Can anyone help?
remove the rear tires, then pull out the gearboxes and motors and use a multimeter and see if you are getting any power to the motors, then post back the results
Jan 26, 2013 | Toys
My Polaris 4 wheeler cut off when I put it in reverse. any ideas?
Almost sounds like the reverse limiter is bad. Try holding the override button in while putting the atv in reverse and see what happens. Depends on what year, the limiter might be inside the CDI box, not a separate part. Try that and if you have any questions let me know, Daniel.
Aug 26, 2011 | Polaris ATV
We have a New ATV 250cc that will not start..getting fuel,getting spark, engine just turns over!
  1. eHow
  2. Car Repair & Maintenance
  3. Car Oil Maintenance
  4. Drain Car Oil
  5. How to Repair a Polaris Four Wheeler
How to Repair a Polaris Four Wheeler By Brianna Byrne, eHow Contributor repair-polaris-four-wheeler-800x800.jpg Spark plug inspection and adjustment can be one way to repair a Polaris ATV.
Almost every vehicle needs regular servicing and repairs in order to continually perform at its best, and Polaris' lineup of four wheelers is no exception. The company has released dozens of ATV makes and models throughout the years, ranging from sporty racing quads to youth models to heavy-duty utility ATVs. Despite the differences between the company's many makes and models, general repair tips and troubleshooting instructions remain consistent for all Polaris four-wheelers. The electrical, ignition and fuel systems are some of the most common sources of Polaris ATV problems.
Read more: How to Repair a Polaris Four Wheeler ' eHow.com http://www.ehow.com/how_8074861_repair-polaris-four-wheeler.html#ixzz26pmQIzeh
Nov 21, 2009 | RTO 200cc Full Size Four Wheeler ATV
Polaris 340 pool cleaner, will not reverse
A big problem with this cleaner is that the screws come loose with vibration. You'll have to disassemble the cleaner to get to the power module, once you have to power module out, remove the endcap and check the screws on the cams that engage the reverse drive mechanisms. The main problem is when the screws come loose, they won't fully engage the reverse drives and will sometimes cause the cleaner to stop while it should be reversing, then continue on forward mode. I guess the best advice I have is to make sure all the screws are tight, but not over-tight as you can pull the threaded inserts out of the plastic. 1dcd685.gif
Sep 17, 2009 | Polaris ATV
1986 polaris 4 wheeler 250 gas leak. Need a manual in how to
Find a Clymers or Haynes manual for it at a Checker or Auto Zone or go online to find one.
Sep 10, 2009 | Polaris ATV
Lost low on polaris 4 wheelers heard a pop and no more low
how do you fixs pull ropes for yamaha kodak
Aug 10, 2009 | Garden
When engine is running, you accel the motor and it does not have enough power to move the 4-wheeler
Try hitting the Reverse Override button, I have a similar problem and am in the process of finding what is actually wrong, but hitting the override at least gets me enough power to get it up my ramps and into my truck
May 08, 2009 | Polaris ATV
Polaris 800 Twin Sportsman Ride on Toy Logo
596 people viewed this question
Top Polaris Toys Experts
Adam Fjeld
Adam Fjeld
cwradio73
D. E. Hev
Are you a Polaris Toy Expert? Answer questions, earn points and help others
