Question about Kenmore Washing Machines
Kenmore model 24622300 cut off in middle of a cycle. Will not drain. Might have been overloaded. Is there a reset? Can you help?
  • joebrent7 Jul 13, 2010
    Very helpful and to the point. Thanks again.
  • Kenmore Master
  • 2,605 Answers
Hello, Welcome to Fixya.
There a several possible reasons your washer could have just "cut off" in the middle of a cycle and not drain, but are all different based on if it`s a frontload or topload.
But I first would like to varify if the unit is a topload or frontload. The model number provided ( 24622300 ) doesn`t come up on the "searspartsdirect.com" website, or several others I tried.
If you could either specify which it is and double check the model number that would be great.
I`ll wait for your reply and then I should be better equipped to help you by taking out the needless Q & A from there.
macmarkus :)
Posted on Jul 13, 2010
  • 3 more comments
    This washer is a topload. The serial # is CP3509724. It probably came with the house built in 2003.
    After further research I found the model # uses 11024622300. I hope this helps. Thanks.
  • Mark MacDonald
    Mark MacDonald Jul 13, 2010
    Excellent,
    Thank you, It sounds like a lid switch problem based on your description.
    Here's a simple way to confirm the switch problem on most kenmore top load washer's but not all, hence the need for the model number...
    Lift the lid, if you observe the underside of the lid there will be a plastic "strike" or "actuator" that goes into a hole when the lid is closed.
    Check the hole where the actuator goes into the cabinet and insure you can see a gray oval shaped piece. If so take a small screw-driver, pen/pencil or something small enough to fit thru the small hole and try activating the switch by pushing it down ( machine must be in the agitate or spin cycle ). If you don't see it, the switch has likely broken loose and needs to be replaced.
    If it start's to function than the switch is not being contacted properly by the actuator on the lid and likely is due to the switch being worn. Make sure it is being held in place via the two screws along the side, if they are loose tighten them, if it is broken, it will need to be replaced.
    Here`s a helpful link for changing it out, http://videos.wittysparks.com/id/3098139...
    The lid switch will look like this...
    I'll watch for your reply to see what you find and if I can assist you further.
    good luck.
    macmarkus :)
    I can confirm that the lid switch is broken! And will use the easy link to try to repair.
    Thanks very much. Genius.
  • Mark MacDonald
    You are very welcome joebrent7, but please a genius...hardly. I prefer to call it years of experience, You`ll see how easy it really is once you replace it.
    Thanks for coming to FixYa once again.
    macmarkus :)
Clean light flashes continuously. None of the cycles work except drain.
Might help if you provide the model number of the dishwasher.
It is likely the float switch at base of dishwasher is cutting in. Have you tried to turn the power off and back on.
Need model no.
Jan 22, 2011 | Kenmore Dishwashers
Kenmore model 119 24622300 Heavy duty 2 speed washing machine....The machine was in mid wash cycle and completely stopped. Although we have emptied the clothes and water out manually (it would not drain),...
the first three is 110 on your model number,not 119.lift the lid up around two inches and close it down,do this a few times,if you don't hear a clicking sound the lid switch is broken,part number 3949238.if that's ok when the washer is in spin does the motor run,if it does you broke the motor coupling,this is located behind the motor,let me know what you find and if you could answer the questions i asked i can help you out better
Oct 08, 2010 | Kenmore Washing Machines
The machine fills up then will not compltete the
Assuming that this is a basic top load, direct drive, neutral drain machine, the following is the Whirlpool (Kenmore) installation and maintenance manual with a very good troubleshooting section.
The problem seems to point to either the timer or motor.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If you need to tear the machine apart, please see an excellent description from GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Sep 20, 2009 | Kenmore Washing Machines
Kenmore type 111, very weak spin
Clothes do not spin out good on NORMAL regular express, but do on casual.
Jun 24, 2009 | Kenmore 22422 Top Load Washer
Kenmore TL Washer Just Hums
try to wash by 1/2 load the same cycle maybe the problem come from overload laundary
Jun 06, 2009 | Washing Machines
Kenmore elite washer problem
LD stands for long drain, you probably have a bad pump or the pump is clogged with lint etc.
Jan 15, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 24622300. clothes are very wet after spin cycle
washer may not be spining at all start in rinse cycle allow washer to wash and advance through cycle on it's own do not advance manually..after agitation listen for short pause after pause pump out should begin after pump out should be another short pause then spin should start..if spin does not start after 2nd pause suspect transmission if lid is raised spin may start but if it doesn't start during normal operation bad gearcase one other ck possible look underneath for oil it may be getting on clutch causing clutch to slip and not allow to spin full speed
Nov 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
