LCD TV and VGA output
I have an Element FLX-3202 32" LCD TV. I can get the VGA cable connection to work with my old (Dell Inspiron 4100) laptop, but not the newer laptops that we have. When I try the newer computers,the screen flickers and tries to connect, and at one point (with myMacbook) it said "not compatible." All I get is ablue screen and "no input" up in the corner. I triedfiddling with the resolution settings on the newer windows laptop, butnothing. I'm not finding much on-line because it's such a little-knownbrand. Any suggestions?
  • bpollard66 Apr 20, 2008
    thanks, Jerry- I suspected the resolution but not the refresh rate. I'll have to look into refresh rates on the computers and see what i can do. thanks again
I want lcd tv with RGB/VGA input - output, video input - output, or any solution for that? output is very essential for me...
Posted on May 21, 2011
I have a Sony Vaio Laptop and tried connecting to my Panasonic TV using VGA cable, since the laptop doesnt have got an S-video port. The TV starts flickering everytime I connect my laptop. I tried all the resolution and refresh rate properties in laptop.
I connected successfully another laptop (HP) using S-video and it worked fine.
Please let me know if the problem is with my sony Laptop or the VGA cable. How can I make it work using the VGA cable?
Posted on Nov 17, 2008
    Genius:
  • Televison & ... Master
  • 1,689 Answers
The resolution and refresh rates have to match exactly to the TV for it to work correctly with the computer.
The newer computers are using much faster refresh rates by default. Their default resolution is also different.
Consult the manual for the TV and see if the computer's external monitor output can be set to match to what the TV exactly requires. Both the refresh rate and resolution are critical.
Jerry G.
Posted on Apr 20, 2008
How torun a flat panel hd lcd tv on a dell 531s
Please check the input ports on the LCD TV and the output ports on the computer's video card. You need to have a proper cable (VGA, HDMI or DVI) to connect your computer with your LCD TV. Later you need to select your TV's input mode.
Mar 08, 2014 | Dell Inspiron 531s Notebook
How can i connect my dell inspiron 1721 to my tv samsung led
If your Samsung TV has a VGA input then connect a VGA cable to the TV and the other end of this cable to the video port on your Dell laptop. Turn on your TV and select the VGA (computer) input then boot up your Dell laptop.and then the video data from the laptop will automatically divert to the TV.
You can toggle between the TV and laptop LCD screen by holding down on the Fn key and press the F8 key.
Jan 26, 2013 | Dell Inspiron Computers & Internet
Connect Dell Inspiron 6400 to VIZIO E601i-A3 60-inch 1080p LED HDTV using VGA Connector
When you connect the vizio try changing the resolution settings on your laptop to see if that makes a difference. Could be that your video card output is not really compatible with the higher requirements of the Vizio.
Sep 20, 2017 | Vizio 60" E601I-A3 Full HD LED-LCD TV
What do I need to connect between my Mini Dell Inspiron to my LCD projector
That netbook has just a VGA output so only a VGA cable will work - your projector must have a VGA input, check that since very few new ones still have it.
Jun 26, 2011 | Dell Inspiron Mini 10 Notebook
When I started using Netflix, I hooked the Samsung Flatscreen TV up to my Dell Inspiron laptop via a VGA cable and it worked beautifully. Suddenly, the TV indicated that there is no signal. I checked the...
Most laptops have 3 video-display options:
* output only to internal LCD screen
* output only to external VGA port
* output to both LCD and VGA
Hold down the blue 'FN' key on your keyboard, and look at the BLUE labels on/above the 12 'F' keys. One of those Function-keys can be used to "toggle" through the above 3 display modes.
Jun 04, 2011 | Samsung Computers & Internet
Multiple vertical screens at startup (dell inspiron 4100)
Try connecting an external monitor to the laptop (15 pin VGA connector). If the display appears normal on the external monitor then you have an issue with your laptop's LCD display. If the external monitor also has vertical screens then your video circuit on the laptop has a problem.
May 19, 2011 | Dell Inspiron 4100 Notebook
Does my dell inspiron 2200 have tv o/p facility to the vga connector?
yes you have monitor out VGA connector just check left side of your laptop you can see 15 pic monitor output , that's VGA connector, you can use them to connect your lcd tv.
Good luck ! if you think your problem solved don't forget to rate
Jan 03, 2011 | Dell Inspiron 2200 Notebook
Connecting dell mini inspiron with LCD with HDMI cable on both si
You just need a HDMI cable to go from the laptop to the TV. It is refered to as a patch cable. You then go into the TV menu and set it to component or in some cases it will say computer. The VGA on the TV just allows both style interfaces to be connected.
Jun 20, 2010 | Dell Inspiron Mini 10 Notebook
Connecting Dell Inspiron 1501 to TV, Windows Vista
The PC card you have doesnt appear to work with that adaptor. Dell Has its own Svideo / Video output adaptors.
You need a converter not an adaptor. Try looking on Amazon for this: ITV-900 PC to TV Converter
Dec 23, 2008 | Dell Inspiron 1501 Notebook
Connecting laptop to LCD TV
Have you tried another monitor on the VGA output? If that still doesnt work may need to set up in CONTROL PANEL>DISPLAY>SETTINGS>DISPLAY- should show another monitor fool around with that and see if you can get it to work, if so then try your tv, But ive never seen a tv with a VGA input? Maybe its me? Good luck JLS
Oct 14, 2008 | Dell Inspiron 1200 Notebook
Televison & Video Logo
1,222 people viewed this question
Top Televison & Video Experts
