Question about Biostar K8VGA-M Motherboard
My motherboard will not power up after the power supply was changed.
  • 524 Answers
Hi...
1.the probelm is with the power supply unit which supplies power to all the unit.check weather output is comin or not.
2.check the power cable is properly inserted in the socket.
3.the socket connecting to the motherboard is damaged.
if my answer was usefull please vote me.
Posted on Jul 13, 2010
Supply problem in motherboard
Supply problem? change your power supply replace a new one, you can find the exact specifications of the power supply on the back or on the sticker of the body of the power supply.. hope this may help you
Jul 25, 2011 | Gigabyte GA-8VM533 Motherboard
Intel desktop d845epi in the motherboard is not powering on.plz send a solve procedure.urgent
computer not power on can be caused by 2 thing, first is your power supply was dead, and the second is your motherboard was broken
try to connect another power supply, if your motherboard can power on it mean your power supply was dead if still not power on it mean your motherboard was dead, change the motherboard with new one
Mar 18, 2011 | Intel Desktop Board D845EPI Motherboard
I am replacing a motherboard with a G31-M7 TE and find that my existing power supply has a 20 pin plug consistant with the old motherboard but the new one has a 24 pin socket. Why is this and do I need to...
New motherboards have a 24-pin power connector. Here is a diagram of both plugs:
You can see that the two are almost identical. The extra 4 pins on the 24-pin connector provide extra connection points for a few voltages. Newer boards and processors need more current, and the extra pins were added to prevent overloading.
Adapter cables are available to go from your 20-pin power supply plug to the 24-pin motherboard connector. Here's one from TigerDirect, and other vendors have them as well. If you're not making other changes than replacing the motherboard, you shouldn't need more than this adapter.
If you are upgrading your processor along with the motherboard, you should probably replace the power supply too. Older power supplies are often in the 300-watt range, and this is too low for reliable operation with new processors, motherboards and video cards. A new 500 or 600-watt supply is not expensive, and would give you the 24-pin power connection the motherboard needs.
Hope this has helped. Thanks for using Fixya!
Nov 20, 2010 | Biostar G31-M7 TE Motherboard
Board will not boot.power supply changed
The power supply and motherboard have a connection (4pin) that communicate to each other. Without this connection, the board will not boot and the power supply will not come on.
The power supply can be fooled by jumping certain pins, but the motherboard must be connected.
Please consult your motherboard manual for the location of this connector.
Visit this site for more clarification please.
http://www.pcguide.com/ref/power/sup/partsMotherboard-c.html
Sep 27, 2010 | MSI MS-6734-10 (-6734-010) Motherboard
Changed out power supply, now can't get video to work
pls ckh ur power supply 5v 12v again other wise change power supply.
pls, chk it is at,or atx power supply.
or ur mother disply ic is damage
inset new display card.
Feb 23, 2010 | Intel ASUS P4S800-MX SiS661FX Motherboard...
Will not power up
This is a common problem with Emachine motherboards, the problem is the power supply is a best tech and allows voltage surges to the motherboard which fries it too. If available you usually have to replace both the power supply and motherboard. I do not know what exactly goes bad on the motherboard but I have replaced many emachine power supplies and motherboards. The motherboard kit which used to be available from Emachines included a power supply and no warranty if you didn't change the power supply. They knew they had a problem.
Dec 27, 2009 | E-Machines (308714) Motherboard
I get no beep tones nor video card output on new P5N-D motherboard.
Check if the power supply is working. If it does not working then it is the power supply. Change the motherboard power supply.
Nov 07, 2009 | ASUS P5ND2-SLI Deluxe Motherboard
A200-1V0 power light and battery are on, but will not boot
try a new power supply if still same result problably you need new motherboard
Oct 13, 2009 | Computers & Internet
I have a emachine PC. PowerSupply blew up. changed it still down
Dear,
ELECTRIC SHOK OR IMPROPER EARTHING IS DAMAGE POWER SUPPLY,MOTHERBOARD,PROCESSOR,RAM
HOW TO CHECK IT.
(WHEN CHECKING KEEP CAUTION :- REMOVE HARD DISK DRIVE POWER SUPPLY SOCKET)
1. check power supply watt 400/450 and same another power supply install and check it. if power supply change and system is working ok so problem in your power supply.
2. check CMOS cell on motherboard,(3 volt)
3. Bfore power supply changing check on mother board any capasitor is like as damaged or not.
OR check main chipset ic is marked as intel.whenpower on it is very hitting or
normal)if very hitting require to repair your motherboard.(intel chipset ic near cmos cell or pci slot,)
4. checking of ram on other pc (working or not)(one beeps coming or not,if one beep coming ram is working ok)
Feb 27, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
I change the power supply but i have a little problem. The new one on the ATX power connector have only 19 pin then 20 old one plus extra 4 pin for something else. The new power supply in Rosewill...
The extra 4 pins on the power supply's atx connector is for new motherboards that require 24pin power supplies. If your motherboard has a 20pin port, then only connect the 20pin portion of your power supply connector.
If your power supply has a 24pin fixed connector that can't be split into a 20+4pin configuration, and your motherboard doesn't have space to let the extra 4pins on the side, then you might want to consider returning the power supply and change it for one that can be used as a 20 or 24pin. Otherwise you will need to cut the extra 4pins apart.
Jan 05, 2009 | ASUS P4B533 Motherboard
Biostar K8VGA-M Motherboard Logo
90 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Alun Cox
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
