Question about Dryers
I just want to know how to take my sunbeam twin window fan apart for cleaning. I have taken all the screws out but the expandable sides are holding it together. What do I do?
5 Suggested Answers
Demmy
  • 59 Answers
SOURCE: Need to take a C400 apart
For dell computers. you need to start from the keyboard down to the bottom. use this link to guide you. http://support.dell.com/support/edocs/systems/latc400/en/sm/index.htm
Posted on Oct 11, 2007
SOURCE: How do I put it back together?
buy a new one, look at it, put yours back together and return the new one.
Posted on Oct 13, 2007
fellowesrep
  • 102 Answers
SOURCE: Shredder ps60c-2
There are usually one or two hidden screws under the stickers.
Posted on Apr 01, 2008
SolutionGuy
  • 331 Answers
SOURCE: Can not get it apart!!!!!!!!!!!!
Here's the repair manual.
Let me know, OK? At the very least, you can rate this solution, right?
SG
Posted on Apr 08, 2009
Sunbeam repair manual
Hi...Before trying to take it apart, you should verify that the paddle in the bread pan is moving or not. Take the pan out of the machine and try to turn the paddle by hand. It should turn free and smooth with little effort. If you can't turn it by hand then the bearing is frozen and the bread pan needs to be replaced. (no fix for it).
If the paddle moves freely, then the belt in the bottom of the unit is loose or broken. Reply to this thread and we'll help you out!
Hank
Jul 26, 2014 | Sunbeam Kitchen Appliances - Others
Holmes twin window fan.One of the blades doesnt move after i sprayed it with the garden hose to clean it.
Never wash any electrical appliance by getting it wet or hosing it down. It is likely shorted out completely and will need to be replaced.
If you ever need to wash a fan, the propper way to do so is to unplug it, then use a screw driver to open the housing, be carefull not to lose any of the screws. Hold each blade, one at a time and use your hand to turn the hub screw (center piece of the fan blade) and remove it, then slide the blade off. The hub screws on fans is most often threaded in the reverse direction of what you would expect, the best way to tell which way to turn would be to keep in mind that they need to turn in the same direction that the fan blades would turn if the fan were running. Then the fan blades themselves can be washed with water and dish soap, but allow to fully dry before puting them back on to the fan.
Never allow any of the motors, wires or switches to get wet.
Oct 03, 2013 | Holmes Products HAWF2041 Twin Window Mount...
I have a sunbeam 1387 warm mist humidifier. I need to know how to clean scale from the filter. It looks like it can be taken apart. Can it?
Actually, Carol, it shouldn't be necessary to take the unit apart. Mix a 50/50 solution of White Distilled Vinegar and Bottled Distilled Water (enough to fill the tank). Pour the solution in and allow it to sit overnight. Then empty the solution and fill the tank with Bottled Distilled Water. Turn the unit ON and allow it to run for 1 hour. Then empty any remaining Distilled Water. Doing all the aforementioned, should have not only cleaned the filter, but also the unit itself. If you use Bottled Distilled Water in the future, rater than tap water, the filter and the plumbing of the unit will stay clean longer and will require less maintenance.
Hope this helped you. Please let me know. Thanks.
Jun 26, 2011 | Sunbeam Warm Mist Humidifier Dehumidifier
How do you take the door apart so that you can clean the glass? We have taken out the 3 screws, but it will not come apart.
i just replaced the glass on a jenn air slide in, remove screw on each side, inside the door, near the hinge, lift door off hinges, remove 3 screws on bottom of door. Trim holding glass should now come off. Remember, hinges are spring loaded.
Dec 29, 2010 | Jenn-Air SVE47100 Slide-In Electric...
We have a Sunbeam 2591 stand mixer that won't work. How do we take it apart? No screws?
Gently pry the front cover off to expose the only two screws holding the mixer together.
Nov 14, 2010 | Sunbeam Food Mixers
How to use a SUNBEAM twin window fan with
Intake brings the air outside into your room, exhaust pushes the air inside your room out.
What setting you use depends on your personal taste of temperatures and the temperature inside vs outside. If you set the thermostat to 72 degrees and it is more than that outside then I would use the exhaust setting. If you set it to 72 degrees, and it is 68 outside but 84 inside then I would set it onto intake to cool the inside air.
Jun 21, 2009 | Dryers
Trying to take apart a Kenmore Ultra Wash 665
normal threading on the screw, trick is totry to hold the impellar, while trying to loosenthe bolt, sometine placing a screwdriver in form the side, allows you to hold it
Mar 07, 2009 | Kenmore Dishwashers
Installation of fan
Not knowing if you have ever taken one apart, start by laying the screen all the way back(flat) and then remove strip with power button. you have to start on the right side where there is a small notch. then remove 4 screws for keyboard. DON'T DROP THEM INSIDE CASE! remove 1 screw for shield. Then 4 screws hold down heat sink/fan assy. remember to disconnect power lead for fan. Installation is reverse. Be sure to use thermal grease between cpu and heat sink assy.
Feb 12, 2009 | Dell Inspiron 5100 Notebook
Marvin Box Fan Cleaning
It has six phillips-head screws around the perimeter. Loosen all six screws and the halves separate. Be careful loosening the screw that holds the motor in place - I ended up stripping the head. If you can use a vice grip to get it started, that may help.
Jul 03, 2008 | Marvin 1210 Floor / Box Fan
Dryers Logo
524 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
