Question about Plumbing
I cannot remove the combi-care compact cartridge even though I have released the pressure relief screw and unscrewed the cartridre locking screw . I have turned the cartridge a quarter left but still cannot get it to come down.
  • 25 Answers
Grab hold of the shaft that the handle attatches to with pliers or multi grips and give it a good pull, it will be seized to the tap body
Posted on Jul 14, 2010
What's happen when the presure is to maximum (4)? I don't know how to get down. The heater is off. Is Capriz combi.
If over pressured water tank may split,to release pressure ,close boiler filling loop an open the pressure relief valve ,( will be a vlave with red top) if you cannot find this open a bleed valve on a radiator untill you see pressure guage fall to safe level ,between 2 & 3.
Jan 10, 2017 | Water Heaters
Tip
Removing Whole House Filters
Frequently whole house filters can be very difficult to remove. The canisters become almost impossible to loosen, even after pressing the pressure relief valve and using a housing wrench. The most common reasons for this are the housing was put back on with the housing wrench, debris in the housing threads and a bad pressure relief valve.
http://i.fixya.neth2oservices.jpg
How to remove a stuck filter housing.
1. Turn off the incoming water.
2. By-Pass the Softener
3. Go to the nearest cold water faucet, open it and let the water run until pressure drops significantly.
4. Turn the water off at outlet of filter (If housing has shutoff on top off head, turn this off now).
5. Press and hold the pressure relief button to relieve pressure further.
6. Use filter wrench to unscrew housing (If it still won't loosen repeat steps 2-5).
7. After removing, clean housing thoroughly, make sure threads are clean on filter bowl and housing head. Lubricate threads of housing and head with plumbers faucet lube or silicone.
8. Clean and lubricate the O-Ring (replace the O-ring every couple years or if housing leaks after screwing back on). It helps to flip the O-Ring over a couple times per year.
9. Replace the cartridge filter and screw the housing back on.
10. Turn the incoming water on slowly while holding the pressure relief button down until all air is purged.
11. Open outlet and let water run to cold water faucet until all air is purged.
12. Put softener back in service.
IMPORTANT! Only tighten the filter housing by HAND!
NEVER use the housing wrench to tighten the housing.
I hope these tips help you with the angst of removing stubborn filter housings.
RJ
on May 30, 2011 | Culligan Under Sink Water Filter
How to change out copper piping from release valve
If the release valve referred to is the pressure release valve, then a water leak out the attached vent pipe is an indication that the valve is failing. To change the valve, the water must be allowed to cool (turn off AC power or gas) and the water level inside the tank must be lowered (drained) to below the level of the pressure relief valve. Once this is accomplished the vent pipe is unscrewed from the relief valve and the pressure relief valve is unscrewed from the water tank. A new pressure relief valve with a sealant on the threads, is then screwed and tightened into place with the outlet port facing downward. The vent pipe is attached to the new valve and the tank refilled with water. A hot water facet must be opened to allow air to exit while filling. Upon becoming full (water will begin to flow from facet), turn off the facet and restore AC power or gas, therefore allowing the water heater to heat up. When the first hot water is utilized there may be some air expelled from the facet.
Sep 13, 2015 | Water Water Heaters
I just bought a 2008 hyosung comet and when applying the rear brake it locked up and will not pads will not release
Its usually possible to release the calliper by loosening the bleed screw to relieve pressure then carefully push the piston(s) back with a screwdriver or similar... Careful not to scratch the piston though.
Dec 08, 2013 | 2005 Hyosung GT 650
The battery release screw is broken
Carefully use a very small flat screwdriver and place it between the case where it separates when the screw is being removed. Lightly pry as you unscrew the screw. Do NOT pry hard, use just enough pressure to help the screw work its way up/out.
Nov 07, 2013 | Computers & Internet
Pressure releif valve leaking
Hot water pressure relief valves serve two functions. The first is to remove high-pressure water from the hot water tank. The second function is to act as a high temperature valve to remove water that exceeds a predetermined point for the valve. Both of these relief settings are preset at the valve factory. Many pressure relief valves will come with a metal tag that identifies these release points. If you're attempting to remove the hot water heater pressure relief valve, pay careful attention to ensure that you replace with the correct valve.
Your hot water heater has a pressure relief valve safety mechanism. When pressure inside the water tank exceeds certain limitations, the valve opens up to allow the pressure to be released. A faulty pressure relief valve will not release excess pressure, which could cause extensive damage to your home. You should test the hot water heater pressure relief valve once every six months to ensure proper operation. If the pressure relief valve fails the test, replace the valve with a new one immediately
Locate the pressure relief valve on your hot water heater. The pressure relief valve has a lever handle on top with a drain pipe attached to it. The pressure relief valve is most often on the side of the water tank toward the top. Newer models of hot water heaters have the pressure relief valve on top of the water tank.
  • Inspect the area around the pressure relief valve for signs of leaking water. If there is leaking water near the relief valve connection, replace the relief valve. If no leaking is evident, proceed with testing the pressure valve.
  • 3
    Examine the area below the pressure relief valve drain pipe. Most water heater closets either have a drain in the floor below the pipe or the pipe is inserted into another pipe to direct the water out of the home. If the end of your drain pipe is not in another pipe or there is no drain in the floor, place a bucket under the drain pipe to catch water when you test the pressure relief valve.
  • 4
    Pull the lever handle on the top of the pressure relief valve up with your fingers. A working lever will lift up without difficulty.You should begin to hear water going through the drain pipe. Slowly release the lever to shut off the pressure relief valve. The pressure relief valve is good. If you did not hear water running through the drain pipe, lower the lever on the pressure relief valve and replace the valve. If the lever is difficult to raise, do not force the lever. Replace the pressure relief valve.
  • Now with all that said if you have a closed loop water supply system and you have a pressure vessal/expantion tank it may have gone bad and is making the TP valve leak. you can call your water provider to see if you have closed loop system.
    Feb 04, 2011 | Whirlpool Water Heaters
    Water coming from around the bottom of gainsborough 9.5E electric shower. I think its a pressure release device. Do I need a call out or a new shower. Or can I fix it.
    Piece of P: youre prob right and its the pressure relief device, which is a silicone rubber ball that gets blown out of a branch of the exit pipe just behind where the hose screws on. If you are careful you can push it back with a small (non sharp) screwdriver etc, looking up from underneath. It would be easier to see if you unscrew the hose first.
    Sep 05, 2010 | Home
    The car wont start after it has been driven for about half an hour or more.. i have to help it some times like give it gas and keep pressing it till it starts
    sounds like the fuel pump has an issue,
    seen this before with a stuck check vavle in the pump. the fuel pressure relief valve retains pressure.
    once the fuel pump primes the line is over presurizes to line and hydro locks the fuel injectors....
    the test i use.
    drive car around for 10 miles, ending back at your place to work on it.
    shut car off and try to restart. it should fail.
    Carefully lossen the test screw on the fuel rail.
    allow the fuel pressure to lower.
    try to restart. if it starts after releasing the pressure then you know the vavle in the fuel pump is not allowing the pressure to release from the fuel line.
    Sep 27, 2009 | 1999 Honda Civic
    Bxi combe 80e - should the screw on the autmatic
    according to observation of similar boiler, the screw on the relief valve is shut.
    Feb 27, 2009 | Combi Centre DX - Mango
    Paper jam on the ouy feed roolers
    outfeed? u mean the fixing assembly?? where the paper gets warmed?? u need to unmount the panel, open the cartridge cover and unscrew. the slide panel and carefully unplugged the flat cable.
    then you need to remove the platten glass. remove left small cover and then remove platten glass. remove the black cover besides the scanner. now remove the left covers, all of them, and unplug the fixing assembly. they are at least two connectors that go right to the power supply board. now you need to unscrew the fixing assembly, see the top of the recently uncover top, you must see two holes, thru them you should see screws, two on one side and one on the other, unscrew them, and then you will finallly release the fixing assembly. now that you got it out remove the plastic cover if it's there and then remove the two screws that has one on each side, now rmeove the metallic cover, you may need to unlock a little metal locks on the sides, push or pull depending situation and then finally free the unit from its cover. at this point you must be really able to remove all the jammed paper. clean up with pressurized air if possible. now that is paper free you need to mount everything back as original. good luck!!
    Jan 30, 2009 | Canon imageCLASS D760 All-In-One Laser...
    Plumbing Logo
    672 people viewed this question
    Top Plumbing Experts
    Andrew Bugbee
    Tom Chichester
    Gil Shultz
    Are you a Plumbing Expert? Answer questions, earn points and help others
