Question about LG LRSC26940ST 36" Side-by-Side Refrigerator w/ 26 Cu. Ft. Capacity, OptiChill Crisper & Jet Freezin...
Bad smell LG side by side refridgerator model GRB207TUJA Have cleaned tray for condensation water by the compressor, but cannot find how to clean tube from the fridge side
SOURCE: LG GR-602TVF Top Freezer
turned out to be the compressor all fixed and working fine now
Posted on Feb 26, 2007
cresguy
  • 75 Answers
SOURCE: outside of fridge condensation; hissing boiling noise
under the compressor there will be rubber bushes which would have got damaged so change the rubber bush and ur problem may get solved
Posted on Jul 25, 2008
  • 28 Answers
SOURCE: Fridge Condensation
Check the seal of the rubber gasket, if there are improper seal of the magnet, pour hot water along it to soften the rubber. (be careful when handling hot water). When the rubber is soften, try to stretch it a little by pulling it. close the door and the magnet will keep the seal in place.
Posted on May 09, 2009
  • 106 Answers
SOURCE: I Have an lg fridge
contact company orthe dealer
Posted on Nov 16, 2010
  • 4 Answers
SOURCE: LG model GR-620RW leaking water inside at back top
the drain hole (freezer) is blocked,
Posted on Jan 16, 2011
Kenmore model 105.53534300 side by side refridgerator not cooling
Relays are located on the left side of the compressor. How long ago did you smell the burning smell? Are you 100% sure the compressor is running? If it is, nothing is wrong with the relays. Although sometimes it is hard to tell if the compressor is running. By morning temps will be higher than tonight if compressor isnt running. If it isnt running, relays must be changed. I will post shortly on how to change the relays.
Dec 23, 2007 | Kenmore 53542 / 53544 Side by Side...
Evaporation tray at back of stand alone refridgerator is full of .....? and smells. How do I clean it as it is fixed to the back of the fridge?
syringe out drain hole/pipe with clorine bleach(clorine will gas off and leave no smell after an hour or so)clean out tray with bleach,as it will kill the bacteria that causes the smell,the higher the himidity the more often you will need to clean drain/tray.(any clean water in tray ,use to feed your house plants,
Aug 04, 2010 | Zanussi Refrigerators
I have a Whirlpool side by side refrigerator model number edrhexnl00 that smells. Cleaned with baking soda top to bottom, cleaned water tray next to filter. I have not replaced filter yet but at this time...
This may not be the problem now but by the sound of the malfunctioning unit, it could be in the future. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com judging from the smell you are encountering, the device could already be malfunctioning
Jun 06, 2010 | Whirlpool ED2FHEXN Side by Side...
I have the same problem with my Kenmore refridgerator
To completely clean a frig of bad smells you will need to remove the back cover of frig and freezer compartment to access all areas. I operated a used appliance store for years and had all manner of stinky refrigerators to deal with so what we did was take out all panels and clean out with bleach and water solution. This took care of most odors. Hope this helps.
Jul 27, 2009 | Kenmore 50522 / 50524 Side by Side...
I have the Lg fridge model LSC26905TT side by side. There is a humming noise-that we never heard before-along with the freezer side on the outside is very hot, and the middle section on the inside where...
Okay, the heat you're feeling is normal. That's the door heaters doing their job. Without them, you'd have condensation building up in those areas and water all over the floor. Unless you can smell something cooking from those or, they stop working, they'll be okay. Most likely it has something to do with the humming which I will address now.
The condenser is probably plugged with dirt. This will cause the compressor to work harder and make that humming noise. Because it can't remove the heat as well (from being plugged), the cabinet is heating up in those areas you mention beyond their normal temperature.
Clean that condenser and see if that helps. It must be free of all obstructions to work properly.
Worst case scenario. If the condenser is clean, the compressor might have gone bad.
Jul 09, 2009 | LG LSC26905TT Side by Side Refrigerator
Recently got my compressor fixed by sears and the drip tray is now smelling like the blood of the melted meat, and to make matters worse the fan is now pushing the bad smell all over my house. does anyone...
on the back @ the bottom remove panel its like a hard board you will see the pan pull it out as long as you have it apart clean the condenser can be done with caned air (messy) or vacuum with a brush . Tom
Jun 17, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Window AC - foul smell
if the unit is cleaned and this smell is only when the condenser is on means the fresh air is open and this smell comes from outside . because the condenser fan is sucking air from condenser through it to motor side .
May 02, 2009 | LG Art Cool LA121CNP wall/window Air...
Foul odor
Yes ,there is a condensate drain pan in the compressor compartment under your unit.
You should be able to get to it from the rear of the unit, by remove several screws.
Use caution and unplug unit before attempting any repair.
The pan can be cleaned out with warm soapy water.
Nov 01, 2008 | LG LSC26905TT Side by Side Refrigerator
Water leaking out bottom of refrig/freezer
Sounds like maybe two things. Your freezer isn't closing correctly and condensation is forming, bad seal maybe. Other option is you need to clean the pan on the bottom of the fridge. Condensation gathers there and it is normal, but if you alot of crud down there it will cause water to gather. Hope this helps...
May 25, 2007 | Kenmore 50522 / 50524 Side by Side...
LG LRSC26940ST 36" Side-by-Side Refrigerator w/ 26 Cu. Ft. Capacity, OptiChill Crisper & Jet Freezin... Logo
132 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
