Question about Watches
We bought a sportline solar watch that has a light mode and rerset and st/stp function mode we want to set the time but don't know how? Help please
    Genius:
  • 1,970 Answers
Mcdevito75 here, I see in your question, SOLAR if that means the watch is operated from the sun"s energy, you first have to get the watch going (ticking) before you can set the time, Instead of a Battery your watch has a capacitor that holds onto the sun"s energy and releases it, makeing the watch go (tick). After the watch goes, you need worry about 2 buttons, MODE & SET. Press MODE and see display Flashing, now press set to set each function, (hour, minute etc.) presss MODE after ecah function is set to move on, once all functions are set, press MODE for steady display, also if thew watch is new, look for a small piece of plastic just under the crown, remove that plastic and push crown down to start watch. Hope this helps.
Posted on Jul 13, 2010
I cant change the time on my sportline solar watch 8105 help
Press "MODE" and above it "SET" and it should help you re-set the time correctly.Hope this helps!
Mar 07, 2011 | Sportline 1000 Memory watch
How do I change the time on my fossil watch dq1185
Time Setting Instructions:First press and hold ST/STP for a few seconds and make sure it says (Time 1). This watch has a (Time 2) to use in other time zones.You change from Time 1 and Time 2 by pushing the ST/STP button for a few seconds.Time 1 setting:- Press and hold the SET button (Light Function will blink) use the ST/STP button to select on or off. Then push the Mode button to go to the next function.- The Chime function will blink. Use the ST/STP button to select on or off and then push the Mode button to go to the next function.- Next will be to select 12hour or 24hour time by using the ST/STP button then press the Mode button to set the Hour, Minutes, and Seconds.- Continue to set the year but when you get to the Month/Day you have the option of putting the day first then the month, use the ST/STP to select then push the Mode button to enter the month and day.- When satisfied with your settings push the SET button and your done.
Time 2 Setting:- Press and hold the ST/STP button it will say Time 2 and then go away only showing the time and date for Time 2- To adjust this time to another time zone you push and hold the SET button.- Use the ST/STP button and the RESET button to move ahead or behind in hours depending on time zone. Push the SET button when done.-Your time 2 is set for a different time zone and your Time 1 is set for your local time. Remember to use the ST/STP button to go back and forth from Time 1 to Time 2.
Jan 25, 2011 | Fossil Watches
Setting the time
On the C9 Fast Wrap Strap digital watch, press and hold the "LAP/RST" button until the display shows "SET" then release. Use the "MODE" button to switch between second, minute, hour, etc. Use the "ST/STP" button to change. Press and release the "LAP/RST" button to exit. The Sportline might be the same or similar.
Mar 15, 2010 | Sportline C9 by Champion Fitness 910 Watch
How do I set the time on the watch? It won't let me go to each function to set the time. It also won't let me get out of the military time mode...
For the Amritron 45/6975:
From the "Time Telling Mode" (date/time displayed): to set the date and time: Press "reset" unit the date disappears--release; press "mode", the "hour" will flash2_bing.gif, press "st/stp" to adjust hour; press "mode", the "minute" will flash, press "st/stp" to adjust minute; continue same sequence to adjust date; when done, press "reset"
Dec 30, 2009 | Armitron Digital Sport #45/6975RED Watch...
Digital umbro watch purchased 2001.How to change time please. 2 buttons on left. top light, bottom mode. 2 on right, top st/stp, bottom reset.
Press mode continuously for about 2-3 seconds then release
Press mode again so that the seconds are flashing
Press ADJ + ST/STP at the same time
Adjust what you need to adjust and move between minutes and seconds by repeating the ADJ + ST/STP
Thanks!!
Oct 06, 2009 | Bulova Watch
Can't set time, etc. on Ottimo Billboard Solar watch.
I just picked up this watch.  Setting it is easy.  Hold down the button marked "RESET" (lower right) until the numbers start blinking.  Hit the "MODE" button (lower left) until the the settings you want to change are blinking.  Hit the "ST/STP" button (upper right) to change that setting.  Keep on hitting these two buttons until the settings are as you would like them.  Hit "RESET" button to finish.  So, to change just the day, I would hold down "RESET," hit "MODE" four times, hit "ST/STP" until the date is correct, hit "RESET" to save.
Dec 20, 2008 | Bulova Watch
WATCHES
i hope this helps....
the top right says st/stp....tells you the year
the bottom right is the light...
the top left is the reset....
and the bottom left is mode...alarm, stop watch,and time 2
Oct 29, 2008 | Watches
Time Change
Using a Sportline but I'm an hour off with daylight savings time. How do I change the time, I can't figure it out. Can
Mar 10, 2008 | Sportline Big Digit Watch
Watches Logo
484 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
