Question about HP Officejet J4680 InkJet Printer
HP officejet J4680 no scan options
My HP officejet j4680 shows an error message when I attempt to scan telling me that the HP Imaging device cannot be found. I have seen several solutions to this problem and I believe it could be resolved in the HP Solution Center, in the Scan to settings. However, I can't access these options as the error message also appears when I attempt to change the settings. I have tried turning the printer off and changing them with the printer offline but this doesn't help. Is there anyway I can disable the error message or work around it?
SOURCE: HP officejet/HP officejet pro J4680
What do I do to ron Faxs from the top instead of the window?
Posted on Jan 14, 2009
  • 85 Answers
SOURCE: i would like to know
Hi
See if this manual gives you any tips.
http://www.manualnguide.com/dl/24771/
Thanks
Taz
Posted on Oct 24, 2009
Geekman
  • 32281 Answers
SOURCE: how to install driver for hp officejet j4680 all
Have you got an installation CD or downloaded the printer driver?
If not you need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model printer and the XP or Vista Windows version of the drivers you require and install them. Use this link to download the drivers: -
www.hp.com/#Support
Then click on the downloaded file to install the printer driver.
Posted on Nov 29, 2009
  • 3 Answers
SOURCE: help with hp officejet j4680 all in one printer.
If you are trying to do this from the printer, open your HP Solution Center on your computer. Click Settings, then Scan Settings, then select Scan To setup. I added everything from the list. Then you just click Update the device. Then you should be able to scan from the printer to your computer.
To check, scroll over to Scan, click OK, you should see Scan To, then hit OK again you should see your computer, hit OK again to see the available scan options, use the arrow to find what you want to scan, then just hit OK again to start your scan.
Posted on Jan 08, 2010
Riztech
  • 731 Answers
SOURCE: how to scan with hp officejet j4680
Please install the printer software and try to scan via the installed software from the computer. Or, start scan using scan button from printer; after installing software.
Regards,
Rizwan
Posted on Mar 03, 2010
How to scan with HP officejet J4680 printer
To scan from the device control panel (direct connect)
1. Load the original.
2. Press the left arrow or the right arrow to select the Scan function, and then
press OK.
3. Press the right arrow to select what to do with the scan, and then press OK.
4. Press Start.
Mar 15, 2011 | HP Officejet J4680 InkJet Printer
Can't get my HP j4680 to Fax or Scan. I have spent many hours today trying to set up thi HP All in One. I finally have the printer working on my wireless network. When I tried to set up the fax, I got...
Hi Jelind
This is the first thing to do to clear all the printer history. Go to the bottom of the thread.
http://h30434.www3.hp.com/t5/Printer-All-in-One-Software-and/Unable-to-install-HP8500-drivers/m-p/17...
This is the second thing to do after you try to install and it tells you a section is missing from INF. There is probably a missing registery value for imaging device. It fixed my 309a issues. Great hardware-support a bit lacking.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00035977&cc=us&dlc=en&lc=en&jumpid=reg_R1002_US...
sharpinjr
Apr 18, 2010 | HP LaserJet P3005 Printer
How to scan with hp officejet j4680
Regards,
Rizwan
Mar 02, 2010 | HP Officejet J4680 InkJet Printer
HP Officejet j4680 All-in-one: windows installer interrupts scan
kindly re install the printer driver.
Have a nice day and do not forget to rate please...!
Feb 03, 2010 | Computers & Internet
Print Cartridge Problem: (Tri-Color) See
Top three solutions to this query at HP support are close to your described problem: (not exact) Try the closest match to your error.
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Officejet+J4680+All-in-One+Printer&qry=print+cartridge+problem+tri-color&submit.x=0&submit.y=0&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=3692887&productBigSeriesOid=3645080&spid=3692888&opname=HP+Officejet+J4680+All-in-One+Printer&pname_desc=HP+Officejet+J4680+All-in-One+Print%2FFax%2FScan%2FCopy&ptype=consumer&stype=pn&contextual_lname=&spname=HP+Officejet+J4680+All-in-One+Printer&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-007%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&product_line_code=DU&search=0
Nov 28, 2009 | HP Officejet J4680 InkJet Printer
HP Officejet J4680 InkJet Printer Logo
720 people viewed this question
Seeker5211
Seeker5211
