The washing machine quits working when it reaches the draining and and spin cycle. it does not drain the water.
  • Washing Mach... Master
  • 8,220 Answers
WellThe washing machine quits working when it reaches - aa9899a.jpg1ce9613.jpgAll front loaders have a filter. You gotta remove that filter check for objects.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 13, 2010
When the timer reaches the spin cycle the water does not drain or spin. All other functions are working.
Hello Joe, thank you for your inquiry!
From what you have described your Frigidaire washer will not drain or spin. I would recommend checking on the drain hose to make sure it is not restricted or too long. Also check to make sure your drain hose is not too far down your drain pipe. If the drain hose is in good condition it might be a possible problem with your timer or drain pump. Since it could any one of those underlying issues I would recommend having a professional technician out. This will help you avoid any unnecessary part purchases. -Matt
Dec 11, 2015 | Frigidaire FWS933FS Top Loading 3.0 cu.ft....
Why did my washer quit spinning out in spin cycle
Quite often the problem with spin cycles is that the cycle cannot start until a sufficient amount of wash/rinse water has drained. So what will often happen is that the washer drains, the cycle starts, a lot of water comes out of the clothes, it stops, waits for the water to drain, then restarts. If the drain pump or drain lines are restricted or blocked or the pump is faulty, the unit may never achieve spin cycle.
Sep 18, 2014 | Washing Machines
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
Washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Mar 19, 2010 | Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Roper rtw434osq0 not spinning/draining water
Set the timer to spin manually and turn it on.
Does it spin?
If not,
Your lid switch is bad and must be replaced.
If yes it does spin.
The timer is bad.
Mar 12, 2009 | Roper RAX4233PQ Top Load Washer
Tube doesn't spin during rinse/spin cycle.
It needs a new clutch. Call a repair technician.
Nov 19, 2017 | Washing Machines
Will not drain or spin
Unless you jarred the machine it's the timer. You can check this by bypassing the lid switch and seeing if it will cycle.
Dec 13, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
paul
paul
