Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
The tubing for the condensation tube disconnected
The tubing for the condensation tube must have disconnected in the wall.
I can hear the water dripping but there is no water outside.
How can I take the unit off the wall to reconnect the tube? Thanks!
    Problem Solver:
  • 12 Answers
You need a pro here because you could break refrigerant lines and that would be an even more costly repair! Go with someone who knows mini-splits.
Posted on Jul 21, 2010
Superba 10 yr old fridge is blowing condensation from the bottom back vent onto wall. how do I fix so that we can still make ice and water?
Probably not condensation but run-off water generated by the auto-defrost.
This water should drain through a tube into a tray attached to the motor where heat from the motor operation causes it to evaporate.
Sometimes the drain tube or the tray becomes detached.
If condensation is forming on the outside of your fridge it indicates the internal insulation jacket is failing and repair is impractical and replacement of the fridge is desirable.
Nov 03, 2015 | KitchenAid Refrigerators
2004 lexus es330 has water on the passenger side floor I think that the air conditioner creates condensation and it should be going out through a tube and there may be a blockage. the problem just started.
sometimes there is a rubber tube under the hood at the back of the engine bay. this tube is coming out of the firewall. (thats the metal wall at rear of engine.this tube is short and is open at one end to drip out the condensation out. this tube get's blocked debis or insects make a nest there. you open it by sticking a small screwdriver up the opening. if it blocked and you do the solution water will come out till empty
Sep 18, 2011 | 2004 Lexus ES 330
Where is evaporator hose on 2001 dodge dakota?clean water on floor .
Condensed water from the AC drains out through the fire wall. Check that small tube/hose for plugs. Some models just have a hard plastic tube sticking out and when the seal on the firewall goes bad, the water drains back into the passenger compartment. Add a piece of hose to that plastic tube so it drips down away from the firewall.
Sep 09, 2010 | 2001 Dodge Dakota
Drivers and passenger side floorboard wet from air conditioner condensation. How can i fix?
There is always drain tube because AC always condenses water.
The drain tube must have become disconnected. Look underneath the car and you will see it pointing down.
Jun 05, 2010 | 2004 Chevrolet TrailBlazer
Air Conditioning water leak inside
The drainage tube for the evaporator case is plugged causing the the condensation to drain inside instead of outside the car. The car will probably need to be lifted to find the drainage tube. Use a pick to gently remove the debris blocking the tube. You must be very careful as not to puncture the evaporator core.
Jun 04, 2010 | 2003 Chevrolet Impala
I recently replaced my water pump and everything worked great. Now 4 months later I get a/c on driver side and heat on passenger side. Now today I gave a good stream of water running out the overflw tube...
The A/C - Heater issue is a stuck blend door or blend door motor issue. This often happens when the battery is replaced or disconnected. The doors park to a neutral position and get stuck there. They can be commanded to move with a scan tool. This usually does not work. Next step is remove the glove box and part of the dash to see what's stuck or not working.
As to your fluid leak, are you low on any fluids? You'll have to be more specific as to where and what your "overflow tube" is. If this tube goes to the A/C evaporator then what you see is condensate water from the A/C operation and normal.
Apr 01, 2010 | 2002 GMC Envoy
Water was found on the bottom of unit on the floor, what could be the problem. I notice water in the tray on the bottom also.
Either a cracked drain pan or a broken water line. If you only see the water once a day or so....or once every few days it is probably a cracked drain pan.
Sep 14, 2009 | Sub-Zero 642
Kenmore refrigerator model 363.9711781 water appears daily
This water comes from a plugged up defrost drain tube. Do you see like a cup at the back of your refrigerator connecting using a plastic tube in a hole at the back of your refrigerator ? This cup collects dripping water from your freezer during a defrost cycle - you will notice a hole above it on the ceiling - what drips into this cup and drains out back the hole in your refrigerator wall and into a long drain tube extending down into the drip pan at the bottom of your refrigerator, usually sits ontop of the compressor or in newer systems next to the condenser fan and evaporates. If this drain tube is plugged up with debris water will backflow back into your fridge and drip against the wall and under your cripsers.
During a defrost cycle (when you hear the sizzling sounds and all motors are off, open the door and you should notice water dripping.
If you can manually remove the cup yourself you can pass a piece of pipe cleaner or long cable and dislodge whatever is blocking it or if you can't do that you will need to have it serviced, sometimes there is a seal around base of the plastic tube it's best you don't touch or break it. Makes ure the cup is firmly connected and inserted into the hole, you can try raising the fridge a bit, the front part so it is slightly inclined to back. If all fails, have it serviced, it is a very simply problem easy to repair and common too.
Aug 24, 2009 | Kenmore Refrigerators
What is the white part that holds water tubing on back of Amana refrigerator? It is leaking water around the tubing
hi,
tubing at the back refrigerator is the condenser, function of this is heat rejection that absorb from your evaporator inside your refrigerator,the white part of holding tube condenser is tube holder mounted by screw to hold condnser tubing has no relate inr efrigetration cycle.the screw use on tube holder was directly pin at the back side of eveporator where cooling effect emerge some ice melted or defrosted form water pass through on screw tube holder,you can fix loosen screw have some sealant pathced to hole where srcew located after a minute of drying time screw it again so that water leak may not come out to that tube holder through your condenser,
well,if that leak does not harm or not make any trouble passing through your condenser its still good condenser need to be cooled so that refrigerant inside tube can flow on liguid state effeciently.on large refrigeration such as ice plant
condenser was designed to have a water shower on tube called evaporative system.it make coole the condenser tube.
this ideas can give you clear explanation why water leaking on tube condenser.have anice day rate me,thanks a lot
May 04, 2009 | Refrigerators
Condensate Leaking
sounds like a stopped up drain tube. probably will need to take to repair facility so they can use compressed air in drain tube to unstop it. Hope this helps.
Sep 10, 2008 | 2004 Mitsubishi Galant
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
99 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
