Question about All-Pro Forced Air Kerosene Space Heater SPC-K75
Good spark...no fuel in burner....5 gallons in tank
  • All-Pro Master
  • 43,501 Answers
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Jan 16, 2011
CAR switches itself off when fuel is on querter tank
check the calibration of the sender unit as may actually be on empty. Find out the exact capacity of the tank and add a known amount of fuel and see where the gauge reads. For example if the tank is 60 ltrs or 20 gallons add 5 gallons and see where the gauge reads. 5 gallons in 20 gallons should read 1/4 or in your case after the engine stops should read 1/4 full. If it reads 1/2 then the sender is out.
Sep 11, 2013 | Cars & Trucks
Bronco II fuel injector back fires and rpm go down then back up?
You may have a failing fuel pump, the symptoms are that of low fuel pressure. The fuel pump is located inside the gas tank, the gas tank must be removed to access the pump for renewal. Remember to replace the filter and be careful not to create sparks and blow yourself up, seen it happen first hand.
Jun 12, 2012 | Cars & Trucks
The 1990 XJ6 has been sitting for the last 2 years and now won't start. The engine turns over fine. The dash gages don't seem to operate. I filled the gas tank with 5 gallons of premium gas. HELP!!!
I wish I could give you an instant fix, but I can't. Do you have spark? If so then its either your fuel pump or the CPS, crank position sensor. If no spark then it could be your coil.
Nov 12, 2011 | 1990 Jaguar XJ6
Fuel comes back out fill tube when fueling 04titan king cab
With the information you've provided, one cam only imagine that you are obviously over filling the tank.
So this leads me to suspect that maybe (just maybe) your gas gauge is saying you are on empty, or 1/4 tank or a 1/2 tank whatever, etc. And you are wanting to make sure it is full.
I presume it always says this and that perhaps you need to have the sending unit replaced inside your fuel tank.
Otherwise, if all things are in working order and you meant to say that the Pump Nozle that the service station uses (where you fuel up) is not shutting off when your tank is full.
One of two things are happening,
In the case of a pump handle that has an auto lever, either they have a faulty pump nozle, in which case you need to talk with them about this.
OR
It is a manual Nozle, in which case you are holding the lever personally and are over filling your tank...
It would be advisable to look up the total fuel capacity of your tank and make a note of approximately how many gallon are in it before fueling up.
This way, if you know there are say around 5 gallons and you have an 15 gallon tank.
Adding even 10 gallons you would be running the risk of over flowing since you are only estimating say 5 gallons at the beginning, maybe it is 5 1/2 or even closer to 6. Therefore only about 9 gallons could be added without over flowing...
Hopefully you'll have found something useful in this.
Good Luck and happy motoring
Respectfully
Jun 10, 2011 | 2004 Nissan Titan
I accidentaly put diesel fuel into my 2000 Acura 3.5 RL, the tank is 18 gallons, it was at about 2 gallons when I filled the tank with 4 gallons of diesel, I got the car towed back to my house, what steps,...
Very easy! Get a siphon and get all of the fuel out through the fill hole. Then put 5-10 gallons of good fuel with a can of Seafoam this will help to dilute any remaining diesel that is left. Start and let idle for at least 10 minutes. It may run rough for a little bit but will clear up and you will be ok! Good Luck!
May 11, 2011 | 2000 Acura 3.5RL
Several days ago, after I had gotten gas, my trailblazer hesitated & sputtered which led us to believe there was water in the tank. We replaced spark plugs, put in dry gas & fuel injection cleaner...
have the codes check in the computer. it sounds like a clogged fuel system which can be inside the tank with a clogged fuel screen or a faulty fuel pressure regulator on the fuel rail
Apr 22, 2011 | 2002 Chevrolet TrailBlazer
1996 Seville died and won't start
Try Spraying Some Throttle plate cleaner into the throttle bore & see if it tries to start?? If Yes Most likely fuel pump died.
May 08, 2009 | 1996 Cadillac Seville CA Value
My 2003 yukon won't start.while idling car ran out of gas
you are either lacking SPARK or FUEL. You put 5 gal in the tank, but is the FUEL PUMP working ? The lights and radio operating only indicate ther is power in the battery.. Hope this helps.
Apr 10, 2009 | 2004 GMC Yukon
Having a problem with burners not generating .
so you have a yellow flame, not blue?
my mate had same problem. He now uses unleaded, adding 10 drops Redex to a gallon.
He was also told not to overfill the tank - just 3/4 full.
Works much better but he says not perfect.
Ian
Aug 24, 2008 | Coleman 2 Burner Dual Fuel 424-700G Grill
All-Pro Forced Air Kerosene Space Heater SPC-K75 Logo
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
