Philips HTS3548W entertainment system.. Continues to say Wrong region for dvd's! WHat is the code to unlock the region and make it region 0??
  • Anonymous Sep 09, 2008
    I also have Phillips model HTS3548W and it will not play my DVDs because it is regionally locked. I have tried the code give but it doesnt work...any other suggestions
  • Jadwick Feb 22, 2009
    I had the same problem with my Phillips HTS3548 System. After you press the "Stop" button on the remote, enter the code provided (734466), at the bottom left of the screen it should pop up with "Region:" followed by the region the player is locked too. This is when you need to enter "0" then ok, if you dont get the pop up then you have not entered the code correctly, keep on trying, took me 3 times to get it right, but my player is now region free.
    Thanks to the Guest who posted this.
Turn on DVD
Open tray
Using remote, press stop 734466
Select zone 0
Press OK
Posted on May 20, 2008
NEED TV CODES FOR PHILIPS TV. I HAVE A ONE FOR ALL MODEL URC-5741B00 REMOTE. NEED CODES FOR A PHILLIPS TV.
Here are the codes for your philips tv:
  • PHILIPS Codes: 003/ 004/ 006/ 008/ 062/ 068/ 069/ 074/ 075/ 076/ 086/ 087/ 089/ 133/ 163/ 183/ 184/ 205/ 206/ 207/ 208/ 212/ 213
  • Apr 15, 2011 | One For All URC-3021 Remote Control
    I have a Philips HTS 3371 DVD home theatre and can not play many DVD's as it give wrong region error. Can you please provide the unlock code and how/where to enter it to get it fixed?
    Hi -
    Please follow the instructions below for unlocking your Philips HTS 3371
    Please note: Unlocking a DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
    1. Switch the DVD player ON
    2. OPEN the disc tray
    3. Key 9 9 9 9 0 using the Philips remote control supplied with the player
    4. Press PLAY. The disc tray will close.
    5. Switch the player OFF then switch ON again.
    6. To test, play a disc from a region which was previously locked.
    If it does not work the first time, switch the player off and back on, then try again.
    This is a verified unlock method, but I was unable to confirm whether it works for players sold locked to Region 1 (North America). If you have a Region 1 player and the method above does not work, you will not be able to unlock your player.
    Regards,
    BElectric
    Mar 26, 2011 | Philips HTS3371D Theater System
    Unlock region code for Philips DVDR3480 region code 5
    Here you go.....
    The only thing you do to unlock DVDR3480 is this:
    With NO disc in your DVDR3480-player you press SETUP on the remote and then press this code: 5 0 1 8 ,now you can pick Region-code with the remote from 0-6
    ( 0=Region free)
    Karlos
    Jul 07, 2009 | Philips DVD625 DVD Player
    ''WRONG REGION'' MESSAGE ON PHILIPS HOME THEATRE SYSTEM
    Ensure both TV & player are on , no disc in player
    on the remote press: disc menu, then open/close then stop
    enter the following numbers:
    7,3,4,4,6,6,0
    you should see region 0 in the bottom left hand corner
    the player should now play, if not and your in Australia ring Philips on
    1300 363 391
    good luck
    Terry
    Jan 11, 2009 | Philips HTS-6500/37 System
    Philips Portable DVD Player PET 730/98 Unlock Code Needed!
    Philips PET730/05
    Using remote control
    Setup
    Down arrow
    Down arrow
    Right arrow
    212225 (you won't see anything!)
    Left arrow
    Down arrow
    should now show region code box
    Enter 0
    Setup to save
    Jan 09, 2009 | Philips PET724 Portable DVD Player
    Dvd player is in region 3 need multi region for model philips hts3548w/98
    1.open tray with empty CD
    2. press stop for 2 seconds
    3. press 734466
    4. on the screen region will appear press 0 for all regions
    5. press ok to close then after open and insert your DVD.
    Jul 15, 2008 | Sony DAV-SA30 System
    Phillips Home Theatre System
    to play discs from different regions on HTS3548:
    Before you begin, ensure you have connected your DVD player to your TV and both have the power on. Once you have connected the TV, follow the instructions below.
    -- Open the disc tray
    -- On the remote control, press in sequence:
    Disc Menu
    Stop
    7 3 4 4 6 6 0
    OK
    -- Make sure Region 0 is showing on the TV.
    This should hopefully help!!!!
    Jan 02, 2008 | Sony DAV-SA30 System
    Televison & Video Logo
    1,295 people viewed this question
    Top Televison & Video Experts
