Question about Poulan Garden
I cut at the highest setting but cut is still too close (about 2 in) How do I adjust this for a PoulanXT model PXT12530.
3 Suggested Answers
vincob
  • 718 Answers
SOURCE: even on the highest setting, it still cuts too
When you put it in the highest setting can you see the deck actually moving in an upward direction? If not the linkage might be broken or damaged. When you raise the deck up or down with the lever it should move, a deck setting in the full up position is a pretty high setting you have to have some long grass to be cutting in the full up position and still think its to short. You might be able to reposition the deck, if when you look under the unit you see a bracket that controls the deck height setting that has a number of holes in it(maybe even 2 brackets), there should be a pin(s) in one of the holes this could be set in a low position and therefore you can change position to change height of deck.
Posted on Oct 15, 2009
john224
  • 1378 Answers
SOURCE: New mower hit small stump, cuts too low now/ can't adjust height
It is a bend blade. I feel your pain...I had a riding lawnmover that took a good two-hours to take apart and chage blades and 3/4 of an acre with old ornamental garden root balls popping up all the time. That was a long summer...
You may want to get the blade ahead of time so whomever can help you look under the mower can change the blade once they confirm it is bent. Even if they can fix the old one it is a blade you will need sooner or later and they are not very expensive.
Posted on Dec 17, 2009
Homelite 42cc model ut10580 high low jet set settings?how to ajust
try 1 1/2 turns from shut then adjust to get highest revs and richen it a bit till rpm slow. too rich is highest revs. and will burn piston if continued at too lean.
Nov 30, 2016 | Homelite Garden
Model 795.78412
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
Mar 27, 2015 | Refrigerators
I have a Honda HRX217 versamower and I would like to know where the wheels should be for the highest height for my lawn, or should I buy a riding lawn mower to get more height. My lawn is dying with
Move the 4 wheel adjustment levers to the number 4 position which is all the way forward (towards you if facing the front of the mower) and that is the highest setting which is about 4" cut height. Each number for the lever position represents the inches in cut. In between numbers is 1/2" so in between 2 and 3 would be 2 1/2" cut as an example.
Aug 22, 2012 | Garden
What is the standard air mixture setting ? and the needle position ? Yamaha ttr250 2004 bike runs on choke but when you turn it off bike cuts out like it runs out of fuel
Hi, You have a closed mainjet (need cleaning) as for idling you must screw in all the way and then unscrew 2 turns (that's a standart) and then you only have to do minor adjustments.
As for the needle position they all work the highest grove you set the more fuel to your engine. Start from the lowest, test the bike for power and rpm's and adjust from there
Good luck
Sep 16, 2011 | 2004 Yamaha TT-R 250
2010 Craftsman Lt 2000 deck height adjustment?
just bought a new craftsman riding mower. model lt1500. 17.5 hp with 42 inch deck. first time using I had the deck hight handle set on 6 the highest setting and still cuts grass to short, matter of fact it scalped the grass. anyway to set the deck higher. Its only 3 days old and still under warranty but the sears store is 20 miles away and I rented a trailer to go pick it up and hate to go rent another trailer to bring it back if its just a simple adjustment.
Jul 31, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Dec 17, 2009 | Garden
Even on the highest setting, it still cuts too low. can i adjust it to cut higher?
Oct 15, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Need adjustments for 88 model carter 2 barrel carburator. fits 4.2 jeep
To set carb adjustment, first set timing correctly, then put both a vacuum gauge and tach on the engine. adjust one idle screw to highest vacuum reading and highest tach reading, then do the other one. go back to the first and re-adjust again, then the other. I find that if you have a mechanical screw or a solenoid that holds idle speed on the linkage, turn them back so that engine is idling at the lowest possible rpm without stalling before making adjustments, then when finished, bring idle rpm up to recommended rpm using those. On an older carb, usually the idle screw covers have already been removed. If not, you need to remove them before you begin, usually best done with carb on a bench.
Oct 06, 2009 | 1988 Jeep Wrangler
I had to remove the carburetor and soak it. After reassembly I need to know how to adjust the two mixture screws that protrude out the side of the chassis. On the carburetor they are marked H & L.
Turn both screws CW to stops (lightly), then both CCW 1-1/2 turns each. The saw should run at these settings. Warm it up, then start with H screw--run full speed and adjust (usually CW) for highest speed, but 4-stroking which begins 2-stroking with light cutting load. Next set L so that it idles fairly smoothly, but will try to follow the throttle when accelerating.
Sep 01, 2009 | Garden
How to adjust height on tractor mower model no. 917.270812? I turn the adjustment knob and it will lock in only on the highest and lowest heights and nowhere in between.
You need to turn that knob to its highest point with the deck height lever to its highest setting. Now turn that knob counter clockwise a few turns and let the deck lever all the way down. That knob will stop the lever part way down. If it mowes to high rase that deck lever again and turn that knob counter clockwise some more and let that deck lever down again. Repete till you have the correct cutting height. If you were cutting to low turn the knob clockwise insted of counter clockwise in the instruction above. The knob only set the stop of the deck lever. Once set the deck lever lifts the deck up and holds it but when you let that lever down it returns to its mowing set height.
Aug 12, 2009 | Craftsman Garden
Garden Logo
46 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
