Question about Cadet Manufacturing 6F1500W Baseboard Heater
A friend disconnected there Cadet baseboard heater model BTF1. They cant get it to go back together without blowing the breaker. They didn't label how it came apart. How do you integrate the hot and neutral poweer source with the two black wires on the heater and the red and black wire from the thermostat....
  • 456 Answers
Hot wire from power source to Black wire to thermostat, Red wire from
thermostat to Black wire to heater. Other Black wire from heater to nuetral.
Posted on Jul 14, 2010
Disconnected the baseboard heater - turned power back on - no power
If the breaker (you mean from the main board?) is turning off there is a line fault or short somewhere. If the breaker is not kicked off then there is a loose connection or maybe a small blown fuse in the base board heater unit itself.
Feb 17, 2014 | Heating & Cooling
How to install two electric baseboard heats together?
Connecting the heaters in parallel means that essentially the two wires coming from the power source (the thermostat) go to the two ends of the first heater, and the same two wires then continue on and are connected to the two ends of the second heater as well. This means that each heater will receive the full 220 volts, and each one will draw the amperage it was designed to in order to reach its maximum temperature. As long as the sum of the two amperages is less than the size of the circuit breaker (20 amps in the case of baseboard heaters), then they both get what they need. If you put too many in parallel on the same circuit, you simply blow the circuit breaker and nothing warms up.
Jan 04, 2012 | Heating & Cooling
Installing a cadet softheat hydrondic baseboard heater on 12-2 wire on 20 double switched breaker. Is this possible? I was told I could change the white wire to black giving me one black to each prong of...
Yes it is acceptable and common practice. You do not need a neutral on a 220 Volt circuit. Just wrap it with black electrical tape so anyone who gets into the wiring later will know that both are hot. This is accepted by the National Electrical Code.
Feb 13, 2011 | Cadet Manufacturing EBHA1000W The EBHA...
How do I know if I have 240v when replacing old baseboard heaters
When you turned off the power to the heaters was the breakers a double (2 pole ) one? If so, then yes, it defintely is 240v. There are very few 110v baseboard heaters out there anyway. The best way to check is to have an electric meter and check it out for sure. Actually if you are working on electrical circuits and you do not have an electric meter to check if you have them shut down for sure, you are on dangerous ground. Always be safe and check before working on any circuit.
Nov 14, 2009 | Fahrenheat Electric Hydronic Baseboard...
Cadet Thermostat
from the mod number it looks like you have electric baseboard. these do not have blowers in them they work off natural air movement. but heat up rather quickly. your gonna have to chk if baseboard is getting power to determine weather or not the t stat or the heater is not working. but first chk your circuit breakers. most heaters are 220v (double breaker)
Mar 19, 2009 | Cadet Manufacturing 6F1500W Baseboard...
Heater is excessivly noisy, can be heard over tv
first, my research into the Cadet model #09954 is a 240v unit. if it is wired to only 120v that may be your problem. I am not even sure it work work on 120v.
Feb 11, 2009 | Cadet Manufacturing 09954 Baseboard Heater
Baseboard heater cadet model
Check the circuit it is plugged into first with a tester or something else.
If it is 240v there are two hot wires.
You have to examine it first for power and then I would check the thermostat next.
You could have an open element.
Mar 25, 2008 | Cadet Manufacturing 09950 Baseboard Heater
Cadet Manufacturing 6F1500W Baseboard Heater Logo
186 people viewed this question
Top Cadet Manufacturing Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
Are you a Cadet Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
