Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Where the fuse located on a craftman lawn tractor, model #917286070
  • 376 Answers
SOURCE: excessive smoke when runing oil in exhaust
Sounds like it could be a blown head gasket betwen the cylinder and valves. The gasket is very thin in that area and is a common problem. Not a recommended fix for a novice. Best taken to a shop..... Dwain
Posted on May 15, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Posted on Jun 08, 2009
canbruce75
  • 1776 Answers
SOURCE: need to know how to replace drive belt lawn tractor
Check out the video at the link that I am providing and see if it helps you with the drive belt replacement. Sure hope so and best wishes.
http://www.youtube.com/watch?v=YIRUAMSjGfg
Posted on Aug 31, 2009
  • 33 Answers
SOURCE: model # 917.28907 craftman riding tractor. 19.5 HP
Drive belt is likely broken
Posted on Sep 10, 2009
  • 4 Answers
SOURCE: What year model is lawn tractor (mower), advice or solution
Hi there Avu
It's quite east to see when was your tractor was made, follow these simple steps and you'll know how to see what model it is
  1. Lift the tractor / mower seat (pull it up)
  2. You will see there's a small metal label with the serial and model number of the tractor / mower
  3. Check the serial number of the tractor / mower
  4. the first six digits of the number are you the model month day and year (i.e 090999XXXXXXX this tractor was made in September nine in 1999
Hope this helps
Attached is an image of the tractor seat and the metal plate
Posted on Sep 21, 2009
Testimonial: "I did it and there it was, Thanks a lot for the help with the solution for this lawn trctor problem"
Fuse diagram for poulan model: po17542lt size of fuse and the location of fuse
20 amp automotive-type plug-in fuse. The fuse holder is located behind the dash.
Feb 12, 2015 | Husqvarna Outdoor Poulan PO17542LT Lawn...
Where is the fuse for craftman lawn tractor model 917 289210 located
The fuse is on right side engine from back of engine to right panel.
Sep 20, 2014 | Craftsman Garden
Why T 3000 craftman lawn tractor Starts efficiently, engine dies when clutch engaged
Check the limit switches. They may not be opening. You have several switches.
1.Blade engage switch
2.Seat Switch
3.Brake switch
4.Gear Switch.
There is a specific order to these switches and One has to be engaged to allow another to work. Its safety built into the lawn tractor. You just need to download the operators manual. And possibly download the shop manual to get locations of these switches.
Here is a link to the owners manual.
Craftsman Gas Powered Riding Lawn Tractor Operator Manual ManualsOnline...
These diagrams may not be your model but the switches are used by a lot of tractor companies. These will give you a general idea on how things work.
6d55bc45-a6f9-4eba-8290-36b2c972107d.gif 93f74dc3-f6d1-4182-a039-e5ff5d7086d4.gif
Jun 27, 2014 | Garden
Where is the fuse located in my tractor 917.287011 craftman
Hi Rodolfo: the fuse hotder is located behind the dash. The follow information work for your Model: Crafstman Lawn Tractor 38 inch - Model 917.287011 - Operators Manual
Additionally, if you are interesting, this is a different tractor # but schematic is the same: Model 917.258552 (page 29/56).
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice weekend.
Nov 18, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
NEED MANUAL FOR MODEL 917252631 CRAFTSMAN RIDING LAWN MOWER
Go to www.managemylife.com
Its Craftman site
Get your free manual.
Oct 22, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Owners manual for craftman's model 917.275520riding riding lawn mower
Go to www.searspartsdirect.com , put in your model number and it will take you to the parts listings for that model, also, if you look to the right side of the page there is a link to download a full Owner's and Parts manual
Oct 12, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftman Lawn mower continues to burn oil at a fast rate
Are you getting a lot of smoke? If so the oil is getting past the rings and burning.
Jun 23, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
May 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Blown fuse
Follow you positive cable from your battery to the solenoid. There will be a smaller red wire on the same terminal or built into the battery cable. The inline fuse will be on it. Or, you can look on the right hand side under the dash about 6 inches above the bottom. The solenoid is mounted on the side and the fuse is there.
May 23, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
142 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
