Question about Epson PictureMate 500 InkJet Photo Printer
All plugged in and not turning on? - Epson PictureMate 500 InkJet Photo Printer
  • 524 Answers
Hi...
this is because of the follwing reasons
1.there is a lose connection in the power cable
2.the power cable may be damaged/broken inbetween
repalce the cable and try...if the problem presists then the problem is with the printer only. the socket where you put the power cable may be damaged.
please vote me the information was useful
Posted on Jul 13, 2010
Engine will not turn with plug installed
Are you sure you have the right plug?! If the plug is too long the piston will hit it. It will likely close the gap on the plug if this is happening! If you hear or fell a definite "clunk" or stop this is likely what's happening. Find the exact plug you are to use and inly use that numbered plug. Just because it fits, doesn't mean it will work! You can damage the piston (therefore the whole engine) if you use the wrong one.
If it is electric start (you didn't specify), are you sure the battery is strong enough? Turn it by hand first tho as it may be the problem mentioned above! With the plug in there is compression and it takes more power to turn the engine.
May 08, 2016 | Echo Garden
Tip
Trailer Wiring Standards (Color Codes/Plug Marks)
Hello all,
For those of you that have or occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, grd is white, +12vdc is black, etc), this is for you.
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are Color, Function, Mark on the plug.
Seven wire Trailer plugs
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
on Sep 09, 2009 | 1981 Ford F 150
How do i replace spark plug
Without more information, like make and model, I'll have to give you a generic answer:
1. Unplug the plug wire from the plug
2. Place a plug socket over the plug
3. Use a socket driver to un-screw the sparkplug
To reinstall:
1. set the new plug's gap to the manufactures recommendation.
2. Lubricate the threads of the new plug with lithium anti-sieze grease (lightly, an amount the size of a grain of rice is plenty)
3. Hand-thread the new plug in as far as you can hand-turn it.
4. Put the socket wrench on it, tighten no more than 1/2 to 3/4 turn after the gasket contacts the head.
5. Replace the wire on the plug's top.
On some cars, the space to get to the plugs is very limited. I've changed plugs where the plugs were between the exhaust pipes, or behind the alternator.
Jan 17, 2015 | Cars & Trucks
Which direction does the oil drain plug turn to come out?
When looking at the drain plug turn it counterclockwise. In other words, when you look at a clock the hands turn clockwise. So turn the drain plug opposite to the way the hands on a clock turn.
Dec 22, 2014 | Cars & Trucks
How do i replace a spark plug on a honda cub
find the plug first then take a 5/8 plug socket and ratchet turn the plug left to loosen install new plug tighten turn right to tighten the plug should already be gaped make sure the numbers and letters on plug match and dont put a american plug in a japanese engine
Sep 26, 2014 | Garden
Why bosch dishwasher will not turn on?
Suggestions: First, make sure it's plugged in.
Assuming it won't turn on when plugged in, First plug something else into it's plug or test it with a plug tester. The plug itself may be off or broken. Assuming the plug is OK, the next thing is to make sure it is unplugged and look for a fuse in the dishwasher. It should be located near where the plug goes in. You may need to remove a panel. Note that some dishwasher also wont turn on unless you have water hooked up.
Jun 16, 2014 | Maytag Dishwashers
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
Plug turned a 1/4 turn and locked down didnt want to force it
no dont force spark plug its trying to cross thread.back spark plug back out.apply thin coat of anti seize compound to spark plug threads.if you have problems getting spark plugs back in a hard to reach place, use a long piece 3/8 vacuum hose about what ever length you need.place vacuum hose over spark plug insulator then install spark plugs to hard reach places to keep from cross threading.if plug tighten 1/4 turn.back out spark plug and try again.dont cross thread or you have to remove cylinder head.if spark plug hole hard to reach to retap or install thread inserts.
Apr 09, 2011 | Toyota Pickup Cars & Trucks
Epson PictureMate 500 InkJet Photo Printer Logo
59 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
