Question about Dell Inspiron 9300 Notebook
Dell insperion-power button only turns on green lock symbol with
Female power receptor snaped off the ,other board. Wore a static ground, desembled the laptop completely. Desodered the half broken piece, small crack in mother board.
Resembled machine with out a new power reciever. When I press the power button, the lock symbal with an "a in it lights up for a bit.
What could it be
please help, at work, need comp now, thanks alex@sweetnotedesign.com
  • 61 Answers
If there is a small crack in the motherboard did you inspect it closely under magnification to ensure no tracings were broken? (These can be very difficult to detect even by tech's with years of experience) My money is on a bad trace on the mb.
Please rate this solution if it has helped you.
Thanks, Gary
Posted on Jul 13, 2010
Model gw711. Where can I get a wiring diagram?
beside the main power plug on the board there is two connectors which are for earth so link all the freen/yellow wires so the are all earth one way or other hope that helps
Feb 12, 2016 | Fisher and Paykel Washing Machines
Is there a power nreset button on a dell insperion
Your power reset button is your power button. You need to hold down the power button to have it shutdown.
Jul 12, 2014 | Dell Inspiron 1525 Notebook
Wont turn on
follow this steps and fix it.God bless you
There is something blocking the receptor on the main unit.
Remove any obstructions and clean the area in front of the receptor.
The remote is too far from the receiver or at too extreme of an angle.
Move closer to the receiver (within 23 feet) or change the angle (within 30 degrees) to the receiver.
A fluorescent or other bright light is shining on the receptor on the main unit.
Turn off the light or shield the receptor.
The device has a keylock or lockout feature turned on.
Check the display for a key or lock symbol, then follow the instructions in the device's user manual to turn off the keylock or lockout feature.
Either the remote or the receptor on the device is not functioning.
Use an Intraed Sensor to see if the remote is sending a signal.
If the remote is sending a signal, it used to control that device, and no other solution works, you should have a service center look at the device and remote to determine the problem and if it can be fixed.
If the remote is not sending a signal and you have replaced the batteries, you will need to repair or replace the remote, depending on cost.
Jul 26, 2013 | Televison & Video
My charger broke like six months ago and I never bought a new one. When I charged it my computer didnt want to turn on. all it does when I push the power button it turns green along with the power symbol...
  • Turn on laptop.
  • Laptop will be start booting. Red/yellow light will be blinking. If yes then check your monitor light will be fixing and Show *********** Board.
  • If shows and your OS will be Booting and fail to start.
  • If yes you can repair it.
  • Insert OS disk into the DVD driver.
  • Turn off PC.
  • Turn on
  • "Press any key........" when comes this message you press any key.
  • After that you can see two option
?? Fresh copy Installation OR
?? Repair Option
  • For Repair Press "R"
  • It will be start repairing
May 16, 2011 | Dell Inspiron 6000 Notebook
DXDIAG DISPLAYS NO AUIDO HARDWARE FOUND AFTER FULL SYSTEM REBUILD, WITH CHIPSET INF INSTALLED. DELL HARDWARE TEST SAYS SOUND HARDWARE IS FINE AND MAKES SOUNDS. MODEL DELL 9100 INSPERION LAPPTOP Thanks
Check that all drivers are up to date... I had the same thing happen to me. NVidia has a newer driver that might help u out. Also unplug the laptop and remove the battery. Hit the power button a few times to ground it out.
Plug only the power cord in and open up command prompt. As administrator run a chkdsk to possibly find the problem...
For me it was the driver! Good luck
Nov 09, 2010 | Dell Computers & Internet
I recently moved and when i hooked all of it back
open it up check all the connections memory and add in cards for security.
connect it and try again. Sometimes the bios battery can cause wierd problems, they are usually a 2032 battery on the motherboard. replace it if it's suspect. I would then look at the power supply. Big heavy capitors don't like being dropped, (neither do hard drives for that matter).
Jan 10, 2010 | Dell Dimension 8200 PC Desktop
Laptop wont turn on, Capslock just blinks
what's the status of the other link lights? the numlock an scroll lock? are they bliking or steady on? try to eseat the memory modules
Oct 03, 2009 | Dell Inspiron 1525 Laptop Jet Black
Is there a problem with the battery? insperion 8600
"The battery is nearing the end of it's useful life and will need to be replaced soon." is the official definition of that battery indication.
If you boot to the system BIOS (F2 at boot, and arrow down to battery, it will tell you such.
May 16, 2009 | Dell Inspiron 1501 Notebook
Dell Dimension 8300 wouldn't start
Sounds like a power supply. You are getting the standby voltage and not the switched. plug all your wires in except the big 20 or 24 pin motherboard connector, take a small wire and short the green (PSU_ON) to black (ground) wires. This will simulate the computers "ON" signal. The fans should all spin up and your plugged in accessories should work, which means bad motherboard, if not bad power supply.
Mar 24, 2009 | Dell Dimension 8300 PC Desktop
Dell Inspiron 9300 Notebook Logo
51 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
