Question about Peg Perego John Deere Gator HPX Ride on Toy
Where to put the plug ??!
We are trying to figure out where to plug the charger in for my brothers john deere/ peg-perego do you have a solution ?????
  • ilaina_alexa Jul 13, 2010
    ok i don't need help any more!!!! :-) ! i figured it out !!!!
    Genius:
  • Peg Perego Master
  • 1,508 Answers
The battery is behind the front grille, you have to remove the screw in the middle and then pull out on the green plastic clips on each side then fold down
Posted on Jun 14, 2012
momsjustknow
  • 149 Answers
SOURCE: peg perego john deere gator 4x2
Here are the printable instructions from the Perego website.
http://www.pegperego.com/pegcatalogue/toys/downloads/Gator_Work_FIUS0301G24.pdf
From what I can tell, there are levers on both sides of the grill that you press to flip the grill down to the ground. You can then get to the battery to pull it out and charge it.
Hope this helps!
Good Luck! from Moms Just Know
Posted on Nov 03, 2008
  • 60 Answers
SOURCE: do I need to replace all tires on peg perego john deere
Hi!
On these, only the 2 rear wheels are the gear wheels. You will just need to replace the tires on those with the rubber ones if you choose to go that way.  Good luck!
Posted on Mar 11, 2009
  • 60 Answers
SOURCE: old john deere gator and battery new charger still will not move
Could be several things.  Your battery could be bad. After not being charged for a while, they do go bad- often. You may want to try a new battery along with your new charger.  You could also have a switch /connection problem. If you get a new battery and it still doesnt work, you may want to check the switches and wiring. It is not uncommon for the switch to go bad especially if it had been stored outside.
  • 19 Answers
SOURCE: my sons peg perego john deere jeep only sets off
I would get the Peg Perego Gator Shifter Assembly from http://www.shopjandl.com/
Make sure the wires are secure on both motors in the back.
One time I had the same problem and I had loose wires on the motor, but I ended up replacing the switch assembly later because it would only work in 1st gear.
Hope this helps
Posted on Jun 09, 2009
mikeramesar
  • 37 Answers
SOURCE: cannot find out how to get to the battery for a
Where the front bully bar is, there is an indent in the middle , enough for your phillips head screw driver to get into, you must undo that screw and there will be a tab on either side of that panel to pull and the front bummer assembly will hinge out towards you, you can then unplug the battery and connect your charger..
Good luck!!
Posted on Dec 27, 2009
How to change battery
you need the thing that connects to the battery and plugs into the wall. You can get one at walmart for around $40 Peg Perego 12 Volt Quick Charger for Peg Perego John Deere Polaris and...
Aug 01, 2014 | Peg Perego 12 Volt Rechargeable Battery
Peg perego john deere tractor charger indicator light does not light up and tractor does not take a charge - brand new
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show
any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Sep 02, 2012 | Peg Perego John Deere Gator HPX Ride on...
I havent used by feber car for 5yers n i lost the adaptor to charge it so if i get a new gharger will it be fine to use it or should i remove the battrey n re-charge the battery? n where can i get the...
KidsWheels features a full line of Kids battery powered electric ride on vehicles, cars, pocket bikes, Kids battery powered electric toy cars, Kids cars, Kids ride on trucks, Kids ride toy Quads, Pedal Cars, Big Toy Ride Ons, Big Wheel, Jeeps, Peg Perego Battery Powered John Deere Gator, Honda Minimoto, Winther Tricycles, Peg Perego Vespa, Peg Perego battery powered John Deere Worksite Gator, Peg Perego Gaucho Super Power S Series, Peg Perego Gaucho Super Power S Series, Peg Perego Ranger RZR, Orange County Choppers, Power Wheels Ninja, Peg Perego Gaucho 4.0, Lightning PAC, Power Wheels MX3, Peg Perego John Deere Power Lift Gator, peg Perego Polaris 800 Twin, Power Wheels Nascar Ride On Jeff Gordon L7822, and more..
KidsWheels Ride On Toy Store
519 North Bell Blvd.
Cedar Park, TX 78613
800-396-9680 512-257-2399 Fax 512-257-0093
Store Hours:
10AM - 5 PM CST Monday - Friday
10AM - 4PM CST Saturday
Closed on Sunday
http://www.kidswheels.combenluis_1.jpgbenluis_0.jpg
Jan 17, 2011 | Toys
My Peg-Perego John Deere Battery Powered Gator HPX will no longer drive
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Sep 08, 2010 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego Gator won't run.
look for a bad conection on the wires follow them from the battery back to the point of origin
Apr 18, 2010 | Peg Perego John Deere Gator HPX Ride on...
Help for my childs John Deer Gator
the peg perego gators have two switches in the shifter that need replaced.
I have replaced them before on my grandkid's gator.
Here is the website I get my parts from
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
You can also call them direct at 1.801.655.0800.
They seem to always know which part I need and I have always been very happy with their service.
Hope this helps
Mar 17, 2010 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator HPX Ride on Toy Logo
Top Peg Perego Toys Experts
Marvin
Marvin
Lawrence Oravetz
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
