Question about AOC LM729 17" LCD Monitor
AOC LM729 17" LCD Monitor Screen goes black
When i turn on the monitor it works for some seconds everything ok. But then the screen goes black, but the power button still stays green. When i unplug it for some days and try to use it again it works again for some seconds. When itry to turn of an on from the powerbutton nothing happens. Can anone PLZ help?
Thank you!
Jack
  • 3 more comments
  • Jacky_9000 Apr 20, 2008
    ok, Ive solved the problem. It was the Capacitor C926
    Thanks again
  • Anonymous Apr 26, 2008
    i have the same problem does it work
  • Anonymous May 03, 2008
    Considering I'm reckoned to be "Mr Fix-It Genius" for most pieces of electronics, I have to confess an embarrassing problem: how is the case/housing opened on the AOC LM727 Monitor 'cos I can't see any screws on mine ?
    I have a similar flickering-then-of scren problem.
    robin@dragonsblood.co.uk
  • C0kX May 23, 2008
    When i turn on the monitor, it works for a half second then it goes black but the Power LED is still green. I want to open the case too, but I don't know how. Who can help me?
    thx
  • Anonymous Jun 08, 2008
    hello , how to open this monitor at all,I do not see any screws
First take off the speakers. you'll see the cable for the speaker. in this slot u can put a screwdriver an pulloff the silver front carefully. then you will see the screws at the top and the buttom. but its better to take off the stand before removing the front. there are 4 screws behind a cover right near the stand. without removing the stand u wont be able to remove the display/electronic
Posted on Jun 11, 2008
  • C0kX Jun 11, 2008
    first take off the speakers. you'll see the cable for the speaker. in
I just redid the solder on the power bd and it fixed the screen from going black.
Posted on May 16, 2008
  • 975 Answers
YOU HAVE A DRY SOLDER PROBLEM, You have to open the monitor and check the solders in the PC BOARD , mainly where theres A SMALL transformer resolder it , and try again ,that should fix it . hope it helps
Posted on Apr 20, 2008
How did you do to open the AOC LM727? There are no screws on the back or sides on it. One can remove the black speakers part on the bottom of it (three screws visible if ju bend the speakers backwards a little) but that doesn¨t open any solutions for opening the rest of the monitor.
How do I attach this monitor to my laptop to use it as a second screen Please?
How do I connect my laptop to an external monitor - Page 2 ...
h30434.www3.hp.com > Laptop & Notebook > Video/Touch
May 6, 2013 - 10 posts
I have a pavillion dv5 2070us and the screen is cracked and I can't see ... I have a pavilion dv6, can someone please tell me the order of the menu ... 06-01-2013 08:19AM ... Once I connected my laptop to the extra monitor, the screen on my extra ...Connect your second monitor while the computer is on. 2.
The HTG Guide to Adding an Extra Monitor to Your Laptop
www.howtogeek.com/.../the-htg-guide-to-adding-an-extra-monitor-to-y...
Aug 7, 2014 - Adding extra screen space to your laptop, however, can be quite a bit trickier. ... If you're looking to do the same, to add a little space to your laptop ...Playing Minecraft on the second monitor was a smooth experience with no drop in FPS. ... Because the AOC does what it does so well, we'll use it to highlight ...
AOC E1649FWU 16-Inch 1366 x 768 16 ms LED LCD Monitor
www.amazon.com/AOC...Monitor/dp/B005SEZR0G
Amazon.com, Inc.
Rating: 3.8 - ‎1,067 reviews
Jan 04, 2016 | AOC 936sw 19" Widescreen Lcd Monitor -...
AOC 2036S won't connect to laptop
Is the cable working? try reducing your laptop screen resolution and connect to your monitor. Your monitor may not support full hd resolutions....
Jan 09, 2014 | AOC 2036S 20 INCH BLK LCD MONITOR
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
AOC 1" - Monitor Says "no signal"
Sounds like a connection problem. Make sure BOTH plugs are securely located. Ian.
Sep 20, 2009 | AOC LM729 17" LCD Monitor
19" aoc lcd monitor flashes pink constantly and turns black
THIS COMPUTER THAT I AM ON ALSO DOES THE SAME THING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! GRR...................=.="""""
Apr 17, 2009 | AOC 917Sw 19" LCD Monitor
AOC LM725 Monitor Problem
Change the monitor and check if the PC works. If it works then the problem is with the monitor, you will have to send it to repair. If not then, the problem should be with the power supply, check whether all the cables is kept intact.
Mar 21, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
AOC LCD LM725 monitor - Black Screen
OK WELL DID YOU UNPLUG IT FOR A LIL WHILE? IF NOT DO SO. IF PROBLEM STILL THERE HOOK IT TO A DIFFERENT CPU AFTER ALL IS DONE HIT ME BACK
AOC LM725 LCD Monitor
try looking for bloated caps, check all diodes... see if its not shorted/leaking and finally check the power regulator ic if its not shorted! note: some capacitors and diodes are very tiny, you should use a lens with good amount of light...
if it does not help..... well, what the hell? try pouring some gas, then light it up! that should solve the problem, at least it turned on right? hehehehe!
Mar 21, 2009 | AOC LM729 17" LCD Monitor
Black screen saying no signal
turn off the computer and get a can of compressed air blow out all the dust and make sure everything is tight put back together and see iff it works. geek squad charges 99.99 to do this in store.
Jan 28, 2009 | AOC LM729 17" LCD Monitor
Aoc lm725 display off after few seconds
I've had a very similar issue on many Dell Monitors. Mine have been under warranty and they usually send me a new monitor, but I believe the issue lies with the power supply within the monitor.
Jul 10, 2008 | AOC LM729 17" LCD Monitor
AOC LM729 17" LCD Monitor Logo
713 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
