Question about Hayward Phantom Pool Cleaner Complete with Booster Pump
Unit does not go under water - Hayward Phantom Pool Cleaner Complete with Booster Pump
  • 640 Answers
Have you adjusted your setting? If the cleaner is set to "top" or "automatic", try switching it to "bottom" only so that it will dive to the bottom of the cleaner. In addition, check the pool cleaners hose weights to make sure that they are spaced correctly and that you don't have too many hose floats attached.
Posted on May 25, 2011
I am getting water on my shelves which freeze in the back and under my vegetable drawer i get puddles of water.
Sounds like the water drain in the evaporator case is plugged causing the 'defrost' water to overflow instead of going down under the unit where it is evaporated.
You may be able to blow out the plug if you can get to the drain end under the unit. on in the lower part of the fridge.
Jul 23, 2014 | Electrolux Refrigerators
GE MODEL # PSS25MGN water wont dispense on door ice maker works
Your water line could be frozen inside the freezer door. Open your freezer door and remove the kick plate on the bottom of the unit. Follow the water line from the door under the unit and it will be clipped under the unit. Pull out the water line and disconnect either line from the coupler (push the water line in and hold the ring then pull out the line). After you do that close the door and try the water again, if you get water then you will need a low wattage heater for the door.
Mar 14, 2013 | Refrigerators
Water on door wont dispense
Mar 14, 2013 | GE PSS25MGN Side by Side Refrigerator
Gsh25jsxn ss won't dispense water
Mar 14, 2013 | General Electric GSH25JSXSS Stainless...
Water on the floor under the freezer side of unit
It happens to all those old refrigerators. There is a shield separating the drip container and freezer through a small hole. Check if it is blocked. This won't do much of the work and may not be stopped even if you do something. If you can, have a new refrigerator.
Apr 21, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Unit doesn't clean well. Is it normal to find water underneath the round unit at the bottom under the wire mesh filter?
Yes some water is normal.
Replace the water supply valve under the sink and water supply line to dishwasher.
Over time minerals deposit in the valve and restrict the water flow to the dishwasher.
This is especially inportant on todays water saving units.
Many people replace an old dishwasher and hate the new unit due to a white film left on dishes.
Although you may have paid for a professional installation a new shut off valve is almost never replaced even though the waterline may have been at an additional cost to you..
Jan 09, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Water leaking under floor when dishwasher runs
check the water to the unit it is locate under the door open the panel 2 -4 screw take flash light turn the unit on and see where the water come from ... it might be also from under your sink.
Jan 01, 2010 | Dishwashers
Water coming in stops short of the proper level - not enough water comming in to clean properly. I have to add water.
most dishwashers fill level is determined by time.
If the water pressure is to low, or the flow is restricted by sand or rust cloging the water valve, the unit will not fill with enough water to clean the dishes.
if you are willing to try, and you can use basic hand tools, you might be able to clean a clogged water valve.
first make sure the ELECTRICAL POWER to the unit is up-plugged or turned off. turn off water supply.
Valve is located under unit most can be reached by removing panel on lower front of unit. disconnect water pipe at valve and look for a filter screen inside the valve, remove it, clean it, reinstall it. now reconnect water pipe, and turn water and power back on look under unit and check for water leaks before reinstalling panel.
Sep 29, 2009 | Dishwashers
Water leaking into machine
it's possible, like mine with the same problem, that one or more of the plastic feet under the water tank has broken, then making the tank move and upsetting the valve underneath. My one always leaks clean water, never dirty and I have a broken foot.
Sep 29, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Can my pentax optio WP can go underwater without a water housing unit? How deep under can it go?
The pentax optio WP can go underwater without a water housing unit. It can only go underwater about 5 ft.
Aug 30, 2005 | Pentax OptioWP Digital Camera
Hayward Phantom Pool Cleaner Complete with Booster Pump Logo
234 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
