Question about Maytag Neptune FAV6800AW Top Load Washer
Wat cause an overfill ? - Maytag Neptune FAV6800AW Top Load Washer
  • 526 Answers
FAV6800A or FAV9800A correct?
If so see if this post will get you started. http://www.fixya.com/support/t5268400-maytag_neptune_washing_machine_about_5
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Rich
Posted on Jul 13, 2010
Iv got a toyota duet i serviced everything but wont stop smoking wat could be the problem?What's your question?
Depends on what color smoke...
Blue smoke means oil in the engine, could be overfilled oil, bad rings, or a leak in the break boost system.
White smoke usually means water in the engine, blown head gasket.
Aug 31, 2015 | Toyota Cars & Trucks
Over fill oill
You should never overfill the oil in a motor. What happens when you overfill the crankcase, is that usually causes the oil foam up and loose the lubricating properties of the oil or the pressure will cause a gasket to leak. If you overfill the oil, you must drain some back out to the proper level.
Aug 09, 2014 | Briggs & Stratton Garden
Engine oil overfill wat to do
Take some out thorughe the oil pan bolt and then check level again. Overfilling engine oil can create problems on engine's lubrication system.
Mar 27, 2013 | Suzuki XL7 Cars & Trucks
Engine cooling light on, I accidentally overfilled it
overfilling won't cause a light to come on. may be a bad coolant level sensor. overfilling generally will not cause any problems either.
Sep 14, 2012 | Infiniti G35 Cars & Trucks
Fl code is on
Hello there and welcome to FIXYA
The FL error code means:
Flood Condition:FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem i see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
Jun 19, 2012 | Washing Machines
The water is overfill
Hi
Overfilling is caused when either the water inlet valve or water level switch is bad. When any of these parts goes bad it won't shut off the water and so cause overfilling. Hope this helps...please post back for further assistance.
Daniel
Jan 21, 2011 | Whirlpool AWZ410 Front Load Washer/Dryer
Washing machine keeps beeping when i try to start it and it goes from the minutes on the screen to do to FL ?? ive tried turning it of and restarting it ?
Hello there: FL Flood Condition FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
Press STOP/CANCEL to clear the display. You may want to have the water level sensor replaced cause this will cause this condition if it is faulty ok
Hope this is very helpful for you
Best regards mike
Jul 07, 2010 | Maytag Neptune MAH5500B Front Load Washer
How do you reset the overfill switch on the kenmore Elite calypso machine? It shows FL and we cut the power. There is water inside
Flood Condition:
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 15, 2009 | Kenmore Elite 45986 Front Load Washer
It says FL
Jul 15, 2009 | Kenmore Washing Machines
My maytag neptune mah550bww will not start up , gives a code FL
Flood Condition: FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
There is a backup valve or flap in the drain assembly that seems to sometimes cause problems with the FL error code. Remove this piece to see if it helps.
If this is a new installation - check that the hoses arent reversed (cold on hot and hot on cold). This will also cause the FL error.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
