Question about Soleus LX-120 Air Conditioner
UNIT WILL RUN FOR 15 MIN WITHOUT PROBLEMS THEN THE DISPLAY WILL GO BLANK AND UNIT WILL THEN BLOW OUT WARM AIR.
    Problem Solver:
  • 5 Answers
Check the condenser coil blower wheel. Soleus Air units use a cheap plastic wheel that comes apart after the warranty period. The condenser coil is the backside coil that is rejecting heat through the exhaust when unit is cooling.
The display going blank is a symptom of unit overheating, it's can't exhaust the heat buildup at the condenser, therefore the cabinet overheats.
If you find the blower wheel in pieces, I have a parts source for you:
www.shop.soleusparts.com
Posted on Aug 15, 2010
Unit freezies ,blow does not blow sometimes
Your unit was run without filters in place and the coil has a dirt/fuzz coating that gets wet from condensation and then freezes when unit is on. When this happens less and less cold air comes out of vents making unit run continuously . The fix. Turn the AC off and run fan only until air flow returns to normal and air is warm. Then carefully remove debris from return air coil on the air filter side
Oct 22, 2015 | Heating & Cooling
2002 jeep liberty heat only works at high rpm
Sounds like low flow issue. Flush and clean system, PROPERLY! Buy a flush kit, drain system, blow compressed air through, fill with cleaner/water mix, run for 30 min with heat on, drain system, blow out with compressed air, fill with water, run for 30 min, drain, blow out with compressed air, fill with 60% coolant mix.
Nov 26, 2013 | 2002 Jeep Liberty
A/c cold air stops blowing cold
Is the compressor cutting out? It could be the compressor clutch relay is going bad.
Jan 06, 2018 | 2004 Dodge Stratus
I have a ruud ubhc-14j11sfd will a 17500 50 amp generator run without any problems
Look at the data plate on the unit, You need the LRA locked rotor amps, and RLA run load amps
It will also show max fuse size and min fuse size. A 3-4 ton unit should run on the gen, but starting is my question, this can be 3-7 times run load amps.
Aug 31, 2011 | Ruud UBHC Air Conditioner
2010 model 20 hp Briggs motor. Fuel going through fuel line, but not going into carberator. Motor runs good for about 15 min, but after heating up this fuel problem starts. After cooling down for an...
Two things:
1 Is fuel coming out of the fuel line. Older mowers have old fuel lines and they tend to get weak and collapse went they warm up with engine heat. Replace the old fuel line.
2 deposits in the carb. take off the air cleaner, start it up and spray a good carb cleaner in the carb until the engine dies. Put some 'seafoam' in the gas and a little in the oil and put the air cleaner back on and start the mower and mow on FULL THROTTLE. this should claen out the carb. Yes the mower will run rough for awhile.
these two cheap fixes will solve 85 % of carb problems. GOOD LUCK
Jul 17, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a glow warm ventless heater and the pilot goes out every 1
Take the 4 screws out and remove the front of the heater. Then blow the dust and cobwebs out with compressed air, I have to do it once a year. The pilot will get dust and hair in it. Hope this helps.
Jan 04, 2010 | Empire ECS HearthRite HB20T Heater
Im at an rv park, approximately 90 degees in the sun, air was cool for about 2 hours, fan continued to run but no cold air. When I change the thermostat I can hear it click but nothing changes.
Take air filter off , look up inside & see if coils freezing/frosting up when starts to blow warm air.
Is this a new unit, and has it always done that or just recently?
Jul 21, 2009 | Coleman Mach 15 Air Conditioner
Intertherm heat pump blows hot then cold then hot
You may have a problem with a temperature safety system.  Before changing anything else, check to see if the unit is clean!!!  Dirt/dust can fool the safety system into an overtemperature status.  Inspect the heat coils for damage and dirt.  Gently clean.
Nov 23, 2008 | Intertherm P3RA-048K Air Conditioner
Soleus LX-120 Air Conditioner Logo
195 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Dennis Boxerman
Craig Butler
Craig Butler
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
