Question about Kenmore 53082 / 53084 Side by Side Refrigerator
When it is in defrost it is leaking water and sounds like it is dripping on something hot
  • Kenmore Master
  • 43,501 Answers
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from Freezerwhen it is in defrost it is leaking water and - 2_bing.gif
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Jul 13, 2010
Freezer leaks water out the bottom
sounds like your defrost drain line is clogged or unhooked, you will have to remove everything from the freezer and take the inside back cover off to check the problem.
Mar 22, 2014 | GE Refrigerators
I hear dripping from the freezer section
defrost element is on may need defrost timer
Oct 08, 2009 | Whirlpool GC5SHEXNS Side by Side...
Water dripping in the freezer We have side by side kenmore fridge and freezer and filtered water. I just opened the freezer and heard dripping of water behind back cover. It sounded as water is hitting...
this IS normall. the freezer is just in defrost cycle. the heat elements are on and defrosting the evaporator. you are hearing the water hitting the elements and running to the drain. this is normall, does it every day, just the first time you happen to notice it. shane
Aug 25, 2009 | Refrigerators
LEAKING WATER AND MAKING A HISSING SOUND UNDERNEATH IS IT DEFROSTIING OR SOMETHING LIKE THAT
Yes. Every 12-14 hours your refrigerator goes through an automatic defrost to clear the ice from the evaporator. The hissing sound your hearing is the water dripping on to a burning hot element.
No Worries.
Jul 30, 2009 | Whirlpool Refrigerators
Whirlpool has water drip inside fridge
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Oct 25, 2008 | Refrigerators
Hot coil?
Hello gaylekell,
Welcome to Fix ya
You said, you just opened your fridge a minute ago and it sounded like water or something is dripping on a hot coil at the bottom back of fridge.
It is in the auto defrost mode!
All frost free or self defrost refrigerators use this method of dispersing the water into the air as vapor.
As the water accumulates below the fridge is supposed to blow the water onto the hot coil or compressor and evaporate it away. That's why there are no more drip pans to empty!
If you do not notice any problem in the operation of your fridge
and it is not excessively loud, (Which I do not think it will be under a normal situation )
Your fridge is more than likely running normally and fine!
How old is the fridge and what's the model number?
Thank You for utilizing my advice, Huuum
Please remember to leave a rating!
Oct 03, 2008 | Danby Designer DAR1102W Refrigerator
Sound of water dripping on something hot
don't worry about it. there is a defrost heater to melt ice off the evaporator when in defrost mode. happens about every eight hours. the sizzling noise is water dripping on the heater
Sep 25, 2008 | Whirlpool GS6NBEXR Side by Side...
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
Falling water hits something hot in freezer and causes sizzle sound
the sizzling noise is water hitting the defrost elememt and this is normal - shows the defrost system is working. if water comes on the floor of the freezer, this may be the drain for the defrost water is blocked. remove the freexer back panel and the drain is in the tray where the defrost water is caught. if it is blocked - usually with ice - clear it with hot water and make sure the water drains freely. takes some patience and maybe several attempts
Jul 13, 2007 | KitchenAid Superba Architect KSCS25IN Side...
Kenmore 53082 / 53084 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
