Question about Pioneer AVIC-N1 Car DVD Player
The screen is blank. I have power and the unit turns on. I have reset the unit. it will open and close. the unit is not installed so Im not sure if there is sound. I bought it used so am unsure of previous care
  • Pioneer Master
  • 6,993 Answers
the blank screen might be as a result the screen flex, or screen inverter or the screen itself. One of these there is the cause of the problem of blank screen.
Also, the unit should have a earphone space, there insert a earphone into the earphone space of the player, in other to be sure if it will sound or not.
You can open up the unit, check for the flex that connects the screen to the player main board, see if the flex is not well fixed or if it has worn out.
And if you cannot open the player yourself, you can get a repair man to help you diagnose the screen and other parts of the player in order to know of the player is having only a screen problem or not.
I hope you understand this.
Good luck.
Posted on Jul 13, 2010
  • charmbarger Jul 13, 2010
    yes the screen will open and there is power I can see the connecting piece for the screen and there is no visual damage and seems connected properly.
  • Walesarumi
    Walesarumi Jul 13, 2010
    in this case, the fault should be from the screen inverter. You should see a small panel board under screen or connected to the screen. If the inverter is bad, there won't be any display. Usually, when the inverter is defective, there s no physical sign.
    Also, don't forget to test the sound of the player so that we will know our attention is only to be focused on the screen part of the player or if there is more to the screen fault.
    Take care.
My konica 2223 copy lamp is dim resulting to paper jams and blank copies, im just repalce my Power supply board
Check your newly installed power supply board input rating if the same with the old one if yes P51 error common for front door open and can be cleared by closing the front door. Door lock actually connect to the interlock switch at the back beside power supply unit sometimes we just clean connectors if not replace power supply. Now if the light scan with very low intensity the result would be darker and probably will cause you paper jam at the fusing/heater unit but, if blank copies the light intensity is to high. you may adjust or correct it by CVR adjustment/Light intensity adjustment " go to 36 mode off machine hold 3 and 6 while power on release 3&6 after display reads CC, enter address 9-0, start, p- select (0/30 darker 35/55 normal- 60/90 lighter) this adjustment may vary depending on drum coating and optical adjustment/cleaning. I suggest clean first all mirrors before you do it.Hope this may help you sold the problem.
Feb 19, 2012 | Office Equipment & Supplies
The message 'Door is open' is displayed even though all doors are closed.
I will suggest you try reset the printer, follow the instruction below to reset your printer, if the problem still persist, replace the cable that connects the printer to the power outlet. If that did not still fix the problem, you will need to reinstall the driver of the printer, you can get it at HP web site.
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold ?# and 6? keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
If that did not fix the problem, try this,
  1. Unplug the power cable from printer while the printer is powered on.
  2. Press and hold OK and HELP buttons while plugging in the power cord. Wait for the screen to go black or blank before releasing the keys.
  3. Just turn on the printer and configure your printer new.
Apr 06, 2011 | HP Officejet Pro L7380 Laser Printer
When eject is pressed, display says locked!
cant open or close dvd player.says locked.can use remote to play etc but cant open to change dvd
Mar 08, 2011 | Panasonic SC-BT200 Home Theater Systems....
Craftsman GDO don't not respond other than a click noise when remote or wall unit is pressed. When power is removed, then restored, wall switch is pressed, unit clicks, then green LED on back of unit...
The unit is flashing the code for 'motor overheated or RPM sensor failure'. If the door is stuck in the open position it could be because the trolley is jammed against the bolt just in front of the motor unit. Remove the bolt and run the opener until the door is closed. Now on the side of the motor unit you will find the 'up limit' adjustment. Turn this 2 full turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Dec 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have an ASUS Eee PC 900. It was working fine last night. I closed the screen (did not turn off the notebook) and when I woke up this morning and opened had a blank screen. All LED lights are working. ...
One more thing you could try is taking the battery out for a minute or two, because the Eee uses the atom it has a fairly complex onboard power controller that can overclock / underclock the cpu. Sometimes this gets malfunctions and locks the PC up, the quickest way to fix it is to simply pull the battery for a short while and stick it back in. You may well have already tried this, but it'll be the first port of call.
Aug 04, 2009 | ASUS Eee PC 900 PC Notebook
When I power up laptop screen is blank
You may have a burned video adapter.
A trouble shoting setp you can try is attatching an external display and seeing if that works.
Also try the function F5 key combo. I think that is the ASUS mapping to switch display output.
Aug 04, 2009 | ASUS Eee PC 900 Notebook
Had toner life end message. Replaced toner and drum with oem,machine reset but now just making blank copies. Tried to print internal report that's blank too
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
Aug 01, 2009 | Brother IntelliFax-2820 Laser Fax
Open/closing diaplay problem
replace your phone
Oct 07, 2008 | Cell Phones
Blank screen for demo's
I was have the same problem with F1 only and I did the reset .
That fix my problem
Hard Reset procedure for the PS3 (as instructed by Sony CS).
Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves!
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
May 11, 2008 | Sony Playstation 3 (PS3) Console
Garmin C330 white screen
Have you tried a Master Reset? If not, it may help, but it WILL ERASE ALL OF YOUR FAVORITES, and may remove anything you have updated. To do a Master Reset, turn the unit off. Press the On button and the bottom right of the screen at the same time. Release the On button, but keep pressing the screen until the unit asks if you are sure you want to reset. Press yes. This may help.
Oct 28, 2007 | Garmin StreetPilot C330 GPS Receiver
Pioneer AVIC-N1 Car DVD Player Logo
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
