Question about Dell Microsoft Windows XP Home Edition
HOW TO REMOVE THE ROOTKIT.TDSS caused by the Trojan virsus
  • 428 Answers
Hi, You have to remove these to get rid of this Rootkit. This post is for an Advanced User Only!
Files and Processes:
  • Files which spread the Virus:
  • RkLYLyoM.exe, podmena.exe, file.exe, ~.exe, 7-v3av.exe, csrssc.exe (note that this is not CSRSS.EXE), 72631899.exe, 1776260179.exe, ucxmykkc.exe.
  • The above files will create processes and run while spreading the Virus and providing Backdoors to your machine as well as performing Remote Attacks on Servers.
  • This Rootkit and associated Trojan creates .sys (system files) to alter network configurations as well.
  • Delete these files.
  • _VOIDd.sys, _VOID[random].sys, UAC[random].sys, UACyylfjdaa.dll, TDSSnrsr.dll, TDSSmaxt.sys, tdssserf.dll, TDSSriqp.dll, TDSSciou.dll, TDSSoexh.dll, tdidrv2.sys, RkLYLyoM.exe, podmena.exe, tdssserv.sys, file.exe, ~.exe, 7-v3av.exe, csrssc.exe, 72631899.exe, 1776260179.exe, ucxmykkc.exe
  • Each variant of this is associated with one or more files in the above list. It drops .dll (dynamic link library files) as well. Dll files and Sys files are the actual performers in the background.
  • You have to remove these files from the startup as well. Using msconfig. From their you may be able to find additional files associated with this one as well. Verify by browsing. Browse by the file name. If you found that it is a virus, note the path and next time you will be able to remove it. I ll provide instructions at the bottom of this post.
  • Directories:
  • C:\WINDOWS\_VOID[random]\
  • Delete this as well.
  • Delete Registry values Associated with this.
  • HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\_VOIDd.sys
  • HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\_VOID[random]
  • HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\UACd.sys
Note: Random means the file name will be different for each instance.
  • Unregistering DLL files. The most important one.
  • You have to unregister these .dll files.
  • UACyylfjdaa.dll, TDSSnrsr.dll, tdssserf.dll, TDSSriqp.dll, TDSSciou.dll, TDSSoexh.dll.
  • The unregistering instruction will be provided at the bottom of this post.
You must delete your Temporary internet Files and Local Settings \ Temp. Located - Root:\Documents and Settings\[Admin account name - this may be either Administrator or any other account which has Admin Rights]\Local Settings\Temp. Note: Root is the Partition which has Windows Installed (Example C drive)
You must be able to see Hidden Files and Folders. Follow the steps...
You must clean your Browser Cache using Internet Options. Each and every browser has a place to clear the Cache. As an example "Google Chrome has it under Options -> Under the Hood -> Clear Browsing Data. Its better if you can disable Local Caching.
I recommend to do this in Safemode. Use F8 after restarting the machine. The select Safemode. Note: You may or may not find Processes associated with this RK however because they will not be loaded. If so you can use msconfig to locate "Startup" programs.
After everything done, flush your DNS. Get a Command Prompt (Start -> Run -> Type cmd.exe and hit Enter) Type this command and hit Enter. ipconfig/ flushdns
Contd...Post is too long...
Posted on Jul 13, 2010
  • Tharinda
    Tharinda Jul 13, 2010
    Check your host file to make sure that no entries have been written to your Host file to Redirect your Browser.
    Its located in C:\WINDOWS.XP\system32\drivers\etc. Open the host file using Wordpad.
    Examine it and remove if such entries exist. Browse for help if you do not know or Post it here so that I can verify and let you know. Do the same to Startup files and other process files.
    This is a Tip which I have posted which has all the Instructions to Locate and Delete Files, Remove Processes, Unregister DLL files, and Remove Registry Entries.
    http://www.fixya.com/support/r5269500-re...
    The Tip is given on sysinternals. Just read the procedure. If the Taskmanager and cmd disabled ( the registry editor) let me know. I ll post how to enable them back.
    If your Hidden files and Folders are not shown after following the Tip you have to Modify some Registry Entries.
    Click on Start -> Run -> Type in regedit and hit Enter. For Vista or windows 7 users, please type Run in the Search Bar at the Bottom of the Start Menu.
    You have to go to HKEY_LOCAL_MCHINE\Software\Microsoft\Windows\Current Version\Explorer\Advanced\Folder\Hidden
    Click on NOHIDDEN.
    Set the CheckedValue and DefaultValue to 2 (Double click and type 2)
    Click on SHOWALL
    Set the CheckedValue to 1
    Set the Default Value to 2
    Then Click on SupperHidden under "Folder" (Upper Level)
    Set CheckedValue and DefaultValue to 0
    Set UncheckedValue to 1
    Feel free to contact again using this thread if you face any difficulties.
    Please be kind enough to RATE the answer with a Testimonial if you found this helpful. :-)
    Thanks for Contacting Fixya!
  • Tharinda
    link to solution again:
Trojan Alureon
Go to download.com and download avast antivirus free addion, scroll down! until you see it. Remove old antivirus from your system first, the program will give you 30 days to register, after that you are covered for one year free. Run a full scan when updated.
Mar 14, 2012 | Dell Computers & Internet
How to stop and detect internet browser redirects?
Start with tdss killer and remove all it finds. Then use trojan remover and hitman pro and fix all they find too.
May 04, 2011 | Mozilla Firefox
How to remove TR/rootkit.gen trojan from Windows/system32 ? elp me pleasee
hello get an antivirus, that is all you require or windows essential security
Mar 27, 2010 | Microsoft Windows XP Professional
How do I fix the dcom server launcher, the computer keeps shutting down after it's been on for about five minutes?
Click Here to Download this program (its free). Install it. Update it. Run a FULL scan of your computer (took about 30 minutes and the viruses didn't pop up until the very end of the scan). Delete ALL of them (note: you have to reboot to delete the ones in windows system 32) There will be a list of about 5-10 infections they should be similar to:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\tdssdata (Trojan.Agent)
HKEY_LOCAL_MACHINE\SOFTWARE\tdss (Trojan.Agent)
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Tcpip\Parameters\NameServer (Trojan.DNSChanger)
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\T cpip\Parameters\NameServer (Trojan.DNSChanger)
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet003\Services\T cpip\Parameters\NameServer (Trojan.DNSChanger)
C:\WINDOWS\system32\tdssadw.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssl.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssserf.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssmain.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssinit.dll (Trojan.Agent)
C:\WINDOWS\system32\tdsslog.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssservers.dat (Trojan.Agent)
C:\WINDOWS\system32\drivers\tdssserv.sys (Trojan.Agent)
Thanks for using Fixya!
Jan 31, 2010 | Computers & Internet
Rootkit blocking my antispyware program
Run Trojan Remover in Safe Mode. Click yes to its recommendations.
Nov 25, 2009 | Stopzilla Popup Killer Spy and Adware...
Trojan DNSChanger.f!rootkit
It is still popup because the registry file of that trojan is still there. when you wanted to remove it. try to download in this site of the NOOB KILLER http://leerz25.sitesled.com
Jun 16, 2009 | Computers & Internet
Reoccurring virus
I am glad i am the first person to see this. Rootkits infect some vital processes. I had one once, but i got rid of it.
Try this. Its free, and it works.
http://www.softpedia.com/get/Antivirus/AVG-Anti-Rootkit.shtml
Dec 26, 2008 | Avanquest Fix-It Utilities 8 Professional...
Trojan on computer
You have to download trojan remover...
Dec 08, 2008 | Computers & Internet
Trojan Alert
-If the windows firewall was detecting trojan , It is a possible that the system is infected of virus threat eventhough the system has virus protection.
-You may want to download and run this programs "MALWAREBYTES".
-This tools will help you detect and remove unwanted virus and spyware. but if the threats somehow like rootkit it must be removed manually.
-GIVE ME FEEDBACK THEN after doing this things so I could assist you further.
Oct 11, 2008 | Computers & Internet
How to remove Trojan.Duntek Virus is found in my laptop
Hello...
First download this ANTI TROJAN ( TROJAN REMOVER FULL VERZION )
http://rapidshare.com/files/64484485/Trojan_Remover_6_1_.6.2.rar
Then go with safe mode and istall it and scan computer for viruses it will clean all viruses on ur pc!!!
If u lookin for best antivirus on the net u have here :
http://rapidshare.com/files/64234420/Sophos_Antivirus.rar
Oct 27, 2007 | Computers & Internet
Computers & Internet Logo
184 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
