Question about Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi ZDT6252Non filling / rinse hold light flashing problem
Like any of the "fexes" I have seen, I have cleaned the filters on the feed hose with no luck. I took off the side panel from the machine to see if the overfill system was blocked up. There is a large chamber half way up and slightly towards the back of this unit which is filled with a liquid/sediment mix beige/brown in colour. Is this a deposit or is this there from new? Looks strange?
  • 3 more comments
  • Garry Keogh
    Garry Keogh Apr 21, 2008
    Sorry Guys, The problem is the one caused by the "Flood Warning" system. If I disconnect the feed hose and start a cycle, then wait until the drain pump cycle is complete and reattach the feed hose, the built in dishwasher will fill one time only. It will then proceed into the wash cycle, will drain this first fill and then go into the flood warning alarm (rapidly flashing LED #1). I can repeat this any number of times I like. If I start a cycle without first letting off the back pressure from the flood warning system. Can anybody tell me if and where on the automatic water level sensing system a blockage would occur and if it can be relieved? Is the machine simply over filling during this first fill due to a faulty float switch?
    Can I simply take off the solenoid or any other connections to check?
    It seems to me that either
    (A) The flood alarm passage is filling with water the first time the machine fills, not draining, then it goes into alarm the next time it drains and tries to refill.
    or
    (B) The machine is over filling and correctly setting off the flood alarm.
    Can anybody tell me that they have seen this and fixed it before as it is not obvious watching the machine fill and drain with the side panel removed other than some of the passages on the level sensing matrix are filling and not draining.
    Thanks
    G
  • Garry Keogh
    Thanks Marrie,
    But I don't think it is related to a partial fill. The fill level seems perfectly adequate. The machine once it has been started with the fill hose removed, will go ahead into any of the wash cycles. The problem is that once it drains and goes into the "refill" stage of the cycle, it will not open the solenoid valve as it seems the level sensing system has flagged a flood warning alarm.
    My problem is why the level sensing system is filling, and not draining into the sump of the machine. This would surely allow the solenoid to open again to fill.
    I can easily clear the level sensing matrix by starting a cycle with the feed hose disconnected (no water pressure on the solenoid) and allowing it to drain the sump of the machine.
    From here it will start a cycel but will always halt once the program requires a second fill.
    Similarly, if I power cycle the machine without removing the feed hose, then it will just not fill, wait for a few minutes and flash the #1 LED telling me that the flood alarm has activated.
    Any clearer?
    G
  • Garry Keogh
    Thanks Maanita,
    But, the appliance is a European integrated Zanussi Dishwasher, not a North American washing machine. This seems to be a common problem but I have not seen a logical fix yet.
    Thanks
    G
  • Garry Keogh
    OK then, I have looked at the machine again and it is just as I described.
    I have checked the main solenoid and the magnetic diaphragm and it all seems fine. The coil has not failed and the diaphragm is airtight e.t.c.
    I also measured the coils of two other solenoids that are mounted directly to the automatic level sensing matrix on the same corner as the main inlet solenoid valve. Both of these coils seem fine also.
    I have checked just about everything I could see except one pressure switch (or something that looks like a pressure switch) that is totally inaccessable (positioned in front of the pump on the underside of the machine).
    The problem is in the operating logic of the machine and I guess it is due to one of the channels in the pressure sensing matrix not draining.
    Has anybody ever found a fix for this fault?
    It appears that this is a common failure on these particular machines but there is no standard fix on any forums.
    Anybody???
    G
  • Garry Keogh
    Garry Keogh Apr 22, 2008
    Thanks TJBENGR,
    But I have covered both of your suggestions and it is neither. The problem is related to the flood alarm. The machine has a system that will stop if from filling if it believes that it is about to overfill and flood. Somehow this seems to be activated during the first regular fill and prevents subsequent fills. The sequence times out waiting for a switch to open/close but then goes into this alarm.
    This is a very common problem in this machine yet nobody seems able to tell me where the flood alarm is sensed on the water level sensing matrix and where the switch is that registers this overfill condition.
    Look at all the similar problems below and you will see that a few describe the same symptoms! I have checked a few forums and nobody seems to have fixed this problem before.
    G
Had similar problem with dishwasher holding on rinse and rapildly flashing cycle light. Tried all fixes suggested above finally called engineer. He diagnosed the problem by emptying dishwasher into a bowl and all the drain pump impeller blades came out.
Ordered new pump unit and had it fitted all in for £135.
On inspection of old pump found impellers easy to change and pump is not to difficult to access. (New impeller kit £35).
Hope this helps and save some money!
Posted on Jul 18, 2008
  • 121 Answers
Just a thought...The discharge hose usually goes to the sink top (vacuum breaker). From there to the drain..often on the garbage disposer (top side) where it has a tendency to clog. (either place). The last one I fixed actually had a rag piece stuck in the strainer (and pump) at the bottom of the washer.
Posted on Apr 21, 2008
  • Timothy Brooks
    Timothy Brooks Apr 21, 2008
    Regarding the water level (pressure switch). When these become older, they usually get stuck - on or off. When stuck on (full) the washer will not change the water because it thinks its full. When off (normally empty) it requests more water, which when completely full..will drain in the overflow, causing a flood warning.
  • 563 Answers
Hi
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
  • Zanussi Master
  • 19,396 Answers
Check that the motor pump is working , that can be the cause for your problem
    Genius:
  • 1,142 Answers
Plz check teh following link
it can be of help
http://www.repairclinic.com/0088_11_1.asp
My zanussi washer zwh6160 p stopped working yesterday. It stopped with a load in it. We gad to manually drain it, then git the door open. We cleaned the filter and inlet pipe filter. We switched it on
Considering that machine did not show any error first check that is not activated option "rinse hold" what mean's "stop drum with full of water". I advise you to make a simple test that will show you where the problem is. In the washing machine or somewhere else. Disconnect the drain hose and lift it up to 1m in height and its end hold over the tub or some larger container. Select short drain program and press the start / pause button. If drain hose ejects a solid water stream then is a problem in-house installation of drain water. If does't or poorly drain water then is problem in the washing machine.
Dado
Nov 10, 2014 | Zanussi Washing Machines
Miele W1926 check inlet light flashes at he end of rinse fill
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
Jul 26, 2010 | Miele W1926A Front Load Washer
My Zanussi dishwasher wont run a programme
Hello Paul, The first thing to try is to clean the filters at the rear pipe(s) that connect to the main water supply. It is quite common that when the water-flow is impeded, the programs may stop with flashing lights depending on the rate/amount of blockage.
So, pull out the unit and disconnect the rear pipe and give the in-line filters(s) a good going-over. Please let me know if this does the trick...
Best Regards,
Peter...
Aug 11, 2009 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Rinse water barely trickles out of my washer
Do you fill the machine with hot water only?
If so, this is what I suspect. The filters in the inlet hoses on the back of the washer need cleaning. Remove the garden hose connectors, remove filter, clean, replace.
When filling with hot only you get a lot of pressure thru one hose. When you rinse, the best you can do pressure-wise is cold rinse -- but the cold water filter is going to be more clogged than the hot so it delivers less water.
When you use warm rinse, you get mediium pressure thru both lines, again less water than al hot on filling the machine.
Apr 29, 2009 | Washing Machines
Zanussi F1045W Front Load
indicated low water pressure from your external supply or blocked filters in the fill hose. turn water off, remove hose and check filter in end of hose - it is just a bit of gauze. also look into the valve and clean out if needed
Jul 20, 2008 | Zanussi F1045W Front Load Washer
Flashing power light and rinse hold light
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 24, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Dec 30, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi FJ1254 W - Machine does not fill
Yes if you remove your soap draw and take a look inside you will see that there is all residue built on the top part of the internal draw, Either you can jet wash it off or replace the soap draw,,
this should solve your problem.. if that does not work then one of your solinoid valves at the back is faulty...
Dec 01, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi zdt6252 stops on 'Rinse & Hold' midway thru Wash Cycle consistently...
The problem here is being caused by Blocked Filters in the Water suppoly In line/pipe. There are two(2) filters in this line, at the water connection point and at the Washer connect point(one at each end). If these filters become blocked, then the result will be a restricted water In-Flow and hence the Rinse & Hold Status. Disconnect the Water-Supply pipe and remove the plastic filters giving them a thorough cleaning before replacing them. All will be rectified by this action. Peter...
Jan 02, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi 23 in. ZDT6252 Built-in Dishwasher Logo
610 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
