Question about Husqvarna Garden
How to assemble chain brake on a husqvarna 142
  • 45 Answers
SOURCE: Husqvarna chain brake
You'll have to release the brake with the cover off the saw. You just need to find a way to brace it well enough.
If you really can't do this, then it suggests your chainbrake is faulty, of ath the very least not adjusted right.
Posted on Sep 27, 2008
dontbother10
  • 2220 Answers
SOURCE: Husqvarna 136 chain brake handle spring.
You can get an IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
I don't think this has the detail you need.
If it were me I'd visit my friendly neighborhood Husky chainsaw seller (not Big Box Store) and ask to look at the clutch cover with the brake installed (take a camera). I'd probably ask for a quote for their repair too. HTH
Lou
Your model is no longer sold. The seller will know what model replaced it and may be willing to explain the repair procedure for your saw you. Take the cover and loose parts with you.
Posted on Sep 07, 2009
dontbother10
  • 2220 Answers
SOURCE: husqvarna 51 chain brake wont open
This thread covers it quite well. It is applicable to all models.
http://www.fixya.com/support/t1195376-chainsaw_brake_locked_husqvarna_455
HTH
Lou
Posted on Sep 10, 2009
dontbother10
  • 2220 Answers
SOURCE: Husqvarna 460 chain brake not aactivating
If you haven't owned for over 2 years it should be under warranty.
Posted on Oct 04, 2009
dontbother10
  • 2220 Answers
SOURCE: how do you reinstall chain brake on a husqvarna
Reset Chain Brake by Dolfoff
Please follow this link, http://www.fixya.com/support/t3102817-re_install_side_cover_after_chain
cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button
If you don’t have a vise a large C clamp to a work surface might work, you may still need a block or two of wood.
If you need need an illustration for how the clutch cover parts fit try the IPL here:
HusqvarnaUSA.com
Enter 350 in the "Enter Product" window (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
The easy answer is don't remove the clutch cover with the brake tripped. HTH
Lou
Posted on Oct 28, 2009
I have a Husqvarna 142 chainsaw. The saw will idle, however when I depress the throttle the saw chokes down a dies.
What condition is your spark plug in?Is your filter clean?Is your gas-oil mixture correct? Is your gas fresh?Is your brake releasing?Is the blade and chain on correct?
Nov 21, 2016 | Husqvarna Garden
Model 137. How do I assemble the brake spring?
Husqvarna Chain Brake - YouTube
? 7:13
https://www.youtube.com/watch?v=gK7eKakMCz8
Feb 13, 2011 - Uploaded by thoughtfulace
... brake assembly and install the spring in the cover of ahusqvarna saw. ... Next time I will try to remember to disengage the brake first. .... How to Remove a Chainsaw Clutch Cover and Reset the Chain ... Restricted Mode: Off.
husqvarna chain brake is stuck. easy fix - YouTube
? 6:31
https://www.youtube.com/watch?v=usP5XaXO7-8
Dec 19, 2012 - Uploaded by Plotnikoff Nate
How to fix your chain brake from being stuck locked to unlocked the easy way. ... BTW, I will NEVER sharpen a chainsaw again. This new chain ...
How to assemble the brake spring on a 137 husqvarna ...
www.fixya.com/.../t26010777-assemble_brake_spring_137_husqvarna
Dec 16, 2015 | Husqvarna Garden
Have a Husqvarna chainsaw, model 142, that starts and idles fine, but when I give it gas, it bogs (makes a low hollow sound) and the chain only turns a little or not at all. Any suggestions greatly...
Are you sure the the chainbrake is not on, grab the hand guard and pull it firmly back to the top handle until it clicks and the brake is off.
Sep 18, 2011 | Husqvarna Garden
How do I remove the chain on a Husqvarna 455 Rancher chain saw
Start by making sure the chain brake is off, pull the hand guard fully back to the top handle, remove the bar nuts ( 13mm ) if it has tooless chain adjustment flip the nut wing out and undo the big grey nut, screw the chain adjuster fully back, if tooless wind the knurled adjuster fully back, now remove the side cover/brake assembly, loop the chain off the nose of the bar, and then over the sprocket and remove.
Apr 15, 2011 | Husqvarna Garden
How to get the clutch off on a 142 husky
  1. Turn off the saw and release the chain brake. The chain brake is the plastic handle located on the topside of the saw's body, and is between the bar and the throttle. With a gloved hand, spin the chain to ensure the brake is off.
  2. Use the wrench to loosen the bar nuts until they are finger tight. Use the flathead screwdriver to loosen the bar tensioner screw. This screw is located in between the bar cover's two metal posts, and can be reached through the small, round hole in the cover's center.
  3. Finish loosening the bar nuts and remove the bar cover. Take off the bar and chain; set them aside in a safe place.
  4. Unplug the spark plug from the rubber spark plug connector, located on the top of the saw's body. Push some of the chainsaw's starter chord string into the spark plug cylinder to block the piston from moving while taking apart the clutch.
  5. Remove the clutch assembly with the clutch socket wrench. Husqvarna chainsaw clutches are left-locking nuts, so you will need to turn the bolt clockwise to loosen it. Tap on the socket's handle with a hammer if the bolt won't loosen.
  6. Remove the bolt and pull off the clutch cover, clutch spring and clutch drum. Replace these parts if they are chipped, warped or heavily worn.
  7. Follow these steps in reverse order to reassemble the clutch.
Nov 15, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Good Morning : I have a Husqvarna 142 e chain saw about 2 years old and I have an excessive amount of bar oil dripping out . Is there some kind of flow adjustment for this problem ? Thanks , Mark :
First, deactivate the chain brake, back-off the chain adjuster, then remove the bar and chain. Run the engine at speed for a moment or two--the oil should ooze out of the engine side port. If the oil quantity seems about right, then clean the drive end of the bar oil-passages including the two small passages that go out to the chain groove on each side. Clean the chain groove and check the sprocket on the far end (if equipped). Reassemble the bar and chain, then start and run the engine at speed for several moments with the bar tip near a piece of cardboard--it should throw off a thin line of oil onto the cardboard. Check the owner's manual for location of any oil-volume adjustment if needed.
Jun 04, 2010 | Husqvarna Garden
Hi how to put front spring in to clutch brake
No model 61 listed @ Husqvarna.
How about a 261 here:
HusqvarnaUSA.com
Enter 261 (no XPs, Es, just the numbers)
06 1500198
See the Chain Brake Assembly detail. HTH
Lou
Oct 22, 2009 | Husqvarna Chain Saw 20" Bar
I can't get the clutch cover back on my Husqvarna 235 e because the chain break is engaged. Spring is too tight to disengage it.
The chain brake is engaged when the brake handle is moved forward.....to ensure it is actually the chain brake...with the clutch cover off and in your hand, pull the chain brake back...if it will not move, attempt to move it forward to see if it was not engaged...if it moves forward, it is now engaged...pull back to disengage it...a lot of times the problem is not the brake, but rather the bar adjuster....if the brake is not the problem,...loosen the bar adjuster and reassemble the unit...once assembled, then adjust the bar as per the user manual.
let me know what you find.
clarkco
Apr 30, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Engine stops when chain brake is applied
sound like the springs are broken in clutch.they can be replaced.but when you replace them you should also grease the needle bearing in clutch durm
Feb 13, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
156 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
