Question about Intimus 250 Shredder
Will not start after jam up
Electric o.k. as green and red light working, I gess red light is for fault/overload. Cleared shredder and turns freely be rotation fan on motor, but will not start. Is there a way of resetting unit?
Shredder has quit working. red light on. nothing works everything is on tight bin emptied
Mosy likely the shredder is jamed try to push a iece of cardboard through to see if the wheels and gears rotate while trying to run it.
otherwise it is likely bad gears from overloading
Mar 07, 2018 | Shredder Office Equipment & Supplies
Bosch AXT 2200 HP shredder motor turns the wrong way
Try flipping the plug on the wall plug it in c which way the unplug rotate an plug it in again I no when working with. Motor proper polarity determined direction
May 21, 2014 | Bosch AXT 22 D Electric Drum Garden...
Overload light stays on
Most likely the cutters are still stuffed with paper shreds and needs to be dismantled and cleaned
Mar 29, 2014 | Honeywell Seven Sheet Micro Cut Paper...
McCulloch chipper not starting
Overload protection is a euphemism for too much electricity going into the motor. That can only be caused by two things - 1 - the motor is not turning freely because of some restriction in the drive mechanism or 2 - some of the motor windings have shorted out and now the motor windings have less resistance than before and more electricity is entering and less back emf is being generated.
Condition 1 is repairable 2 - fogetit - motor is shot.
Mar 03, 2017 | McCulloch Electric Chipper Shredder
I plugged in my xd490u [mitsubishi] data projector...and then power turned red, status turned green for few some seconds. later power blinked [red + green] and did not work. can anyone tell me what the...
It sounds like your lamp may need replacing. Before you go that route try all of these:
-Make sure the lamp cover on the bottom is fully attached. -If you unplug the power cord while the fan is rotating, the lamp may not turn on about 1 minute when you plug the power cord next time. After the status indicator stops blinking press the power button to turn it back on. May have to press it multiple times. -If your Power Light continues to blink red/green then you should contact your dealer.
Sorry I couldn't be more helpful.
Feb 28, 2011 | Mitsubishi XD490U Multimedia Projector
The green timer light flashes 3 times at 10 second intervals and there is no red operation light on
Indoor fan motor mechanism locked. Rotate manually, if hard, replace bearing or motor. If easy to rotate replace capacitor. Still not working, check your motor windings.
Jan 11, 2011 | Fujitsu Heating & Cooling
It stopped as I was pushing leaves through it
there might be a red button (overload) on the motor.
Nov 07, 2009 | RTO Deluxe Electric Leaf Shredder
Motor works only in reverse direction only.model sh1524cp
Your shredder thinks it is jammed ... did you clean the electric eye or the small lever - does it work freely?
Can you use canned air to blow dust out of the top? Have you cleared any paper stuck at the bottom of the unit?
Try these things - I have had occasional success with this kind of fiddling around.
Oct 18, 2009 | Aurora Electronics AS662C Shredder
Paslode im350 has indicator light flashing red/green
The nailer’s electrical system has gone into overload protection. There may be something wrong with the fan motor or the wires going to the fan motor. Remove the cap and grill to inspect the red and black fan motor wires. If the wires are pinched or broken, that may be the problem. It may also help to disconnect the small white connector on the wire assembly that goes to the motor and then reconnect it.
Jun 22, 2009 | Tools & Hardware - Others
Gbc shredmaster 4220S just stopped working
Check swich door , if door is open the machie stopped for securyti of the operator . the swich is closed whith the door is closed , good luck
Oct 31, 2008 | Quartet gbc 4220S Shredder
Intimus 250 Shredder Logo
65 people viewed this question
Top Intimus Office Equipment & Supplies Experts
Lonnie Arks
Lawrence Oravetz
ray gallant
Are you an Intimus Office Equipment and Supply Expert? Answer questions, earn points and help others
