Question about Nintendo Wii Console
Wii controllers have new batteries lights flash but no cuurser.The lights just blink when nyou press the buttons
    Genius:
  • 1,340 Answers
You need to sync the remotes to the console.Open the large door on the front of the console.Open the battery cover on the remotes.Point the remote at the sensor bar and hold the red button inside the remote while holding down the red button in the front of the console.Hold them for a couple seconds.Do the same for the other remote(s).It may take a couple tries but they will sync.
Good luck and game on!
Posted on Jul 26, 2010
How to add extra controller on a wii
1. Turn on your Wii and let it finish booting up.
2. Take off the battery cover off the new controller.
3. Press the sync button on the new controller. All the blue leds will light up and blink.
4. Press the sync button under the SD card slot on the wii console.
5.The blue leds on the controller will stop blinking when you are done.
Jul 26, 2014 | Video Game Consoles & Games
How do i link a wii remote to my council
there is a little button on the controller on the top you just hold it in while the system is on it will sync the controller.
Jan 07, 2012 | Nintendo Wii Console
On my wii remote at the bottom of the remote belong 1&2 them lights all flashing and it will not pick up we change the batties still not working can you help me..
  1. Press the Power button on the Wii console to turn it on.
  2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
  3. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
This procedure must be followed for each additional Wii Remote added to your system.
Nov 29, 2010 | Nintendo Wii Console
The remotes flash then switch off, i have synced them again but still wont work.
start with the basics FRESH BATTERIES:
1) Fresh batteries should be in each.
2) Turn on the Wii with Player 1's remote or the button on the console.
3) Open your SD Card cover and press Sync. Very shortly afterward, press the red button on your P1 Remote (in the battery cover). Lights will blink and then will be showing a light in the first square, denoting the connection is complete and it's P1.
4) Do the same as Step 3 for the P2 remote. For the P2 remote, after the blinking, then the second square will be lit, meaning it's P2.
That is the Standard Connection. It is tied to the Wii until it's re-done.
After you attempt to synch them (pressing the red synch button on the wii, followed by the red synch button underneith the battery cover of the wiimote), make sure the wii is turned on and press the buttons 1 and 2 on the wiimote at the same time to have it search for recognized bluetooth devices (ie. your wii).
_________________________________________________
found this article too.
this should help you.. leave a testimonial if I helped.
The first thing I did while the Wii was turned on was that I tried to sync the Wii Remote by pressing the "1" + "2" buttons at the same time. The lights at the bottom of the controller flashed for about 30 seconds, but never received the signal from the Wii. Bummer.
The next step I followed was to hit the sync button on the Wii Remote (Wiimote). Then immediately opened the cover for the opening where the SD Flash card goes and pressed the sync button on the Wii. 30 seconds of flashing, and no result. Double bummer.
Finally, after some Google searching, I found a couple of message boards where people had to press the Sync button on the Wii (not the Wii Remote) for 15 seconds to reset it. I performed this step and then pressed sync on the Wii Remote. The 2nd controller synced up almost immediately. What a relief!
Apparently the problem lies in the fact that the Bluetooth technology being used has to be manually synced in order for it to connect to the Wii. It does not make much sense at all. You would think they could be pre-authorized in order to minimize time and ease of use. In addition, you really have to be careful that your other controllers are turned on while syncing or else the controller that you are trying to put on channel 3 might end up on channel 2! This happened to me on one occasion.
Good luck with getting your Wiimotes in sync with your Wii. Hopefully this helped!
If this helped you out, please let me know with a comment below!
Apr 10, 2010 | Nintendo Wii Console
Wii Controllers not causing anything to happen.
OK so do led lights on the on the bottom of the controller just keep blinking or ever light up under "1" to signify that it is connected? What you do if they keep blinking is take off the battery cover on the remote and press the red button and the red button under the sd card cover at the same time. This syncs the wii remote with the console. You will need to do this with all new wii remotes.
Jan 11, 2010 | Nintendo Wii Console
Bought brand new batteries for my remote, but
You need to re-assign to the Wii. When you first bought it you pressed the button on the front of the Wii to configure controllers, then the controller buttons to find the Wii. When you change batteries you need to repeat this process as the 'memory' of the controller to the Wii has been wiped
Nov 12, 2009 | Nintendo Wii Console
Balance board on wii fit doesn't turn on? power light flashes
All i had to do was SYNCHRO the board by pressing the synchro button on the wii balance board were the battries go, the power LED will blink (note once the power LED has started blinking, stop pressing the synchro button)
THen you need to press the synchro button on the wii console, while the wii balance board's power LED is blinking
Oct 17, 2009 | Nintendo Video Game Consoles & Games
My wii control the lights blink all four do it has new batterys in it whats up
You need to sync it again with your Wii, that happens sometimes:
1 Turn on your Wii Console
2 Remove the battery cover on your Wii remote, and press the red button thats in there.
3 Open the flap on the front of the Wii Console where the SD card can go, and press the red button in there.
4. When the blinking lights stop, syncing is complete!
Sep 10, 2009 | Nintendo Wii Console
Power
    Try these steps!
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
Sep 09, 2008 | Nintendo Wii Fit for Wii
When new batteries have been put in both controllers of the wii, indicator lights supposed to indecate power level of batteries instead of which all blue lights flash then stop and nothing happens, no...
If all the lights are coming on then going off again the controller needs to be synched with the wii. Once it is synchronized after all the indicator lights flash one should stay on indicating which player you are (1 -4)
To synch a controller to the wii:
Make sure the wii is in
Open the battery cover on the wiimote
Open the front panel of the wii
Press the synch button on the console
Press the red synch button on the wii mote
Should work for you.
Jul 04, 2008 | Nintendo Video Game Consoles & Games
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
