Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My garage doors cannot be closed from the remote fixed on the Door frame inside, only if is pressed twice and held it pressed. From the outside remote cannot be closed ( or from the car ) at all.
    President:
  • 3,197 Answers
Sounds like you have a door sensor problem. Make sure they are pointed at one another and that the small light on each one is lit and not flickering. If you cannot get both lights to come on you have bad sensors
Posted on Jul 13, 2010
Garage door will open from remote or car;but wont close,only closes by inside wall unit
Something could be blocking the electric eye.they are down at ground level on both sides of the door
Dec 20, 2011 | liftmaster Chamberlain Garage Door Opener...
I have a SecuraLift Garage door open. The door will not open with the remote or on hte wall device and the status light is flashing... Can I fix this or do I have to call for the door to be serviced? AND...
Many of these devices use a code that changes each time the door is opened and closed. This feature is used to keep potential bad people from learning your operational code and entering your garage. You may have a communication problem whereby the Garage Opener needs to be reset. You may try to change the settings. If you have dip switches on the main unit in the garage, change the dip switches to another setting and write down the numbers in the order that you have the set them, Then go to the remotes, hand held and hardware placed on the outside door, and change the settings on these devices to MATCH up with the inside unit. This is a good time to REPLACE the batteries also.
Feb 20, 2018 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage door will only close if button is held in; with remote blink twice and not move.
If the main light flashes 10 times when you try to close the door it is a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have bad sensors.
Dec 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
I recently had to change the outside entry code on my garage door and since then my gargage door remote will not open or close my door. The code works fine, but the remote does not. The batteries seemed to...
You might possibly have held the smart/learn button in too long and erased the code for the remote. Hold the button down on the remote and then press and immediately release the smart/learn button. This should program it for the remote. Now make sure the keypad is still working.
Oct 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have 2 liftmaster 3245. The hand held remotes were working fine then stopped. I replaced the batteries and turned of all electrical/RIF close by. Still not working. Both cars operate the doors with no...
You need to reprogram the remotes by briefly pushing the learn button on the garage door opener until it flashes once, then release the button on the garage door opener.
Now press the remote button once until you hear the garage door opener click, now press the remote button once again and the remote should be programmed to work for that garage door opener.
DO NOT press and hold the garage door opener learn button for more than 10 seconds or you'll erase all programs and have to relearn all the remotes, including your car ones.
Hope you found this very helpful and best regards.
Aug 06, 2009 | liftmaster Chamberlain Garage Door Opener...
Remote missing on old dominator garage door opener
This is the most complicated way I know of coding a remote and I am a tech. who does this all the time.
Turn power off. Wait 3 sec's & turn back on. Quickly press program button on back of box twice. Lights will flash, bottom light will stay on. Press program button twice, & No. 3 light will start flashing. Press and hold your remote button until light stops flashing. Code will be accepted.
Apr 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage remote wont work when car is running
first garage door frequency is very uncommon to most other div. find your antana on operator and be sure you have it out and pointing toward garage if you can not find antana this may be part of your problem. also metal buildings are hard to get good frequency threw
Apr 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
64 people viewed this question
Top Sears Building Materials Experts
Mike
Steve Allison
Steve Allison
Are you a Sears Building Material Expert? Answer questions, earn points and help others
