Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
I self cleaned the oven for 4 hours and it worked great. I decided to take the front glass off to clean inside it. it was quite dirty inside and the self clean did not effect it. Once I put everything back together, I could not close the oven door as the oven lock was either in the wrong position or was out too far. I did not disturb the latch when I cleaned the door except to take apart the "U" shaped catch in the door. This is held together with 2 screws. I have tried everything, but cannot get the door to close. I feel like cutting off the catch and forget about the self clean as we have to use the oven. Any help would be appreciated. Regards Rick
  • corvetteseas Jul 13, 2010
  • Kenmore Master
  • 8,220 Answers
Did you flip those levers that hold the hinges into place?
I have a oven repair manual from whirlpool that shows the hinges on the oven and the correct position:
WHIRLPOOL LATE MODEL OVEN REPAIR MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 13, 2010
  • 2,272 Answers
The procedure to Disassembling the door is as follows:-- 1. Set the oven door wide open. 2. Lift the hinge jumpers with your thumb and index fingers, then turn them fully outwards to the end of stroke. 3. Turn the door towards the closure position and lay it on the jumpers: in this way the hinge's spring is blocked. By fully closing the door the hinges are unhooked from the connection slits which are integral with the oven muffle. 4) Re-assemble the door by carrying-out the aforesaid operations in the opposite order. Disassembling of the door glasses:-- for your safety, before removing the glasses you should remove the oven door. To facilitate the cleaning, after having removed the door from the oven, you can proceed with the disassembly of the glass. Release the two upper blocks so that the glass can be removed. After the cleaning you should reassemble the glass, replace the blocks and lock into position. Check that all components have been assembled correctly and than you can re-assemble the door onto the oven. check fig:-- For more help click this link directly. The model and brand is different in the picture but the procedure to assemble the door is similar to your model http://www.partselect.com/ModelFrames.aspx?ModelID=1015781&ModelNum=plef398aca&ManufactureID=4&Selected=QN7WQCV6&Position=1&mfg=Frigidaire&Type=Appliance&Mark=3 Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
    Thanks, but I need to solve the problem that I cannot CLOSE the door.
    Is the latch in the wrong position? Should it be vertical or horizontal when in the normal mode (not cleaning)?
    The turkey is ready to be cooked, but we can't yet.
    Regards
    Rick
Aqua lift doesn't clean the oven.what should I use or do.
Spray with Easy Off. Put a glass dish of cleaning ammonia in the middle of the oven. Leave overnight. The next day everything will rinse off. Have plenty of ventilation and wear long gloves.
Maytag AquaLift Self-Clean Technology - YouTube
2q==? 1:55 https://www.youtube.com/watch?v=LdBzf6DHyHI
  1. Similar
Mar 23, 2012 - Uploaded by The Home Depot Watch Associate Joey demonstrate Maytag's AquaLift self-clean technology. If you'd like an oven that ...
AquaLift self-clean oven technology - YouTube
9k=? 1:09 https://www.youtube.com/watch?v=4mdiD1yid1Y
  1. Similar
Jan 6, 2012 - Uploaded by Whirlpool Corporation Whirlpool Corporation is introducing AquaLift™ self-clean technology, a first of its kind cleaning solution to self ...
AquaLift TM Technology Cleaning Methodology - YouTube
z? 3:48 https://www.youtube.com/watch?v=zfKLpQdZD5c
  1. Similar
Feb 3, 2012 - Uploaded by Whirlpool Appliance Repair Self Help Videos AquaLift TM Technology Cleaning Cycle & Cleaning Methods.
Whirlpool® Cooking - AquaLift™ Self-Cleaning Technology - YouTube
z? 0:21 https://www.youtube.com/watch?v=N1-Gty3LUik Mar 6, 2014 - Uploaded by WP Canada Now it takes minutes, not hours, to get a great clean that's odour free with Whirlpool® AquaLift™ Self-Cleaning ...
Aqualift really does work - YouTube
2q==? 2:33 https://www.youtube.com/watch?v=5GRImKNE3BA
  1. Similar
Aug 20, 2012 - Uploaded by apreston123 This video shows the aqualift self clean in action. Video starts after the 40 minute cleaning cycle has finished ...
Jan 10, 2018 | Ovens
How to clean inside glass oven door
Taking the door off the oven and lay door on a soft surface so as to prevent scratching ,taking the door apart ( Carefully ), allow for a large work space, lay out your screws, the glass you are trying to reach is an inner glass, so obviously self clean is not going to help. Good luck!
Oct 02, 2014 | GE Profile JTP56 Electric Double Oven
Self clean for 4 hours -- do i need to leave my apt?
The first time you do a self clean it does smell weird and you do not need to do it for 4 hours change the setting to 2 or three hours. This uses allot of ellectricity to do the cleaning. I usually just use a oven clenaing product for light cleanup. If you have a pie that has spilled over or something then it works great. The Smell is a bit of ash and smoke from all the things that you are incinerating inside your oven.
Cheers
Al
Sep 11, 2009 | Bosch Ovens
I have a Whirlpool electric build in oven with self-cleaning feature. It is about 8 years old and we just used the self-cleaning feature for the first time last week. The oven was not that dirty, but...
Your thermal fuse or TOD mounted to the back of the oven went out during the self clean,it shuts off the power to the elements.
 The oven must be removed from the wall to change this.
Aug 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Dirty streaks between glass front
depends on type of unit,but most separate by opening oven door and removing the screws around the perimeter of the door, be careful reinstalling as to get inner and outer glass re-positioned right along with insulation,this is especially critical because the outer glass can't withstand self-clean temps and will break
Aug 22, 2009 | Ovens
Clean glass range door
Hello. I recommend a product called Cameo. Cameo is a non abrasive cleanser actually designed for the new type enameled sinks recomended by American Standard. AND iit works great on oven door glass. You can get it at Walmart. Very inexpensive and works great on all kinds of surfaces that may be hard to clean but you don't want a harsh cleaner that might damage the surface or scratch. Has a very light to almost none scent. Very good for cleaning the oven both inside and out. Doesn't have the chemical smell left by some cleaners that can be intensified by heat.
Aug 14, 2009 | Frigidaire 27 in. Electric Gallery Pro...
How much time to leave on self cleaning...clock does no work
Depending on the condition of the oven, it could take up to 4 hours.
I ran the auto self clean on my oven last week for the first time and it set automatically for 3 1/2 hours. (It stunk, but it worked.)
A couple things to remember is: (1) Make sure you do not turn the light on inside the oven. The clean cycle should disable it. (2) Lock the door if it does not lock itself. (3) Do not open the door during the clean cycle.
Remember the self cleaning temperature is extremely high. Do not allow children in the area while doing it.
Dec 15, 2008 | GE Profile JTP18 Electric Single Oven
How do I clean the inside of the door window of my self-cleaning oven?
umm. there will always be some assemblence of grease on the door glass, if its on the inner most panel and you can scrub it off, then i would reccomned using a razor blade lying flat to scrape it off, however if it has developed within the panel(s) of glass then the only remedy is to dissassmeble the door and glean them that way.. there was some conflict as to the age of your machine in your description, you say "3-hour cycle for the first use late last spring, if I remember correctly--whatever the directions said to do for the first time, a 4-hour cycle after Thanksgiving last fall and a 3-hour cycle for the second cleaning a couple of days ago since it wasn't very dirty"" so i cant be a mont old??? reason i say is that is the unit you purchased probably come with a pretty kickin warr and the manufacture will want ot make good on your issue if you cant resolve it, betterchance though if only 1 month not 11
Oct 26, 2008 | Electrolux EOG9330 Gas Double Oven
The F5 error code?
I unplugged the oven and it cleared the code and was able to self clean the oven.
Jun 19, 2007 | Whirlpool GBS307PR Electric Single Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
454 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
