Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
Posted on Jul 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lt1000 20hp. briggs electrics on carb it will run when you pour i
Lt1000 20hp.briggs electrics on carb will run when you pour in gas but dies when it burns off what you have poured in
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 30, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
504
Points
Tractor starts fine then dies when I try to drive or engage blades. Any ideas
Anonymous
Level 2:
Sergeant:
  • Expert 200 Answers
  • Posted on Jul 20, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
200
Questions
0
Helped
76298
Points
513
Check fuel lines for clogging.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
2answers
3.5 hp Briggs & Stratton won't run unless I pour gas into carb
This sounds like a problem with the suction. If the air filter is clean then it will need new carb gaskets. There may also be an issue with the pressure being created by the engine.
Pressure washer will run for a little while the it just dies
under the carb, bowl is there an electric fuel shut off. sometimes they stick shut or hardly open so sounds like it is open enough to fill bowl with gas but not enough to keep it running
What's the cause of gas pouring out of carb on briggs&sratton edger
the float is open and letting gas get into carb need new float and valve
We have a briggs and stratton mower that has been in storage for 5 years with very few hours on it, it will start but dies shortly after.
needs to have carb cleaned out. most likely the main jet in the carb is plugged. symptoms include only running on choke and dies when choke is turned to run. or if you only have a primer bulb, it will only run for only a few seconds every time it is primed. if you are qualified to work on the carb, dont forget to start with fresh gas and possibly new fuel line and filter. R
No fuel flow to Briggs & Stratton Intek, 18.5 hp
blow air back threw the line towards the tank you have something clogging it or you forgot to turn the fuel on
3helpful
Won't stay running
I took the carb apart and found that it needed rebuilt, I installed the new carb and fuel pump kit and it runs great again.
Murray 17 hp briggs and stratton will run on starting fluid but dies will not run
You need to take the fuel system down, to see whats is going on. The fuel line from the tank to the carb is it clear? will gas pour out if disconnected? If yes now you will have to take the carb off and take it a part to clean it. That should fixit.
Oct 31, 2009 • Garden
2001 john deere saber briggs moter smell gas in oil
If you're using ethanol-blended fuel, the ethanol will eat away at the neoprene parts inside the Briggs carb.Going to need a carb rebuild.
Don't run your engine until it's fixed or you could damage it as gas will pour into the crankcase, causing the oil to thin and lose its lubricating ability.
1helpful
21hp b ANd S engine keeps stalling unless choked
CARB CLEANER FOR CARS WILL WORK JUST FINE,BUT YOU MIGHT HAVE TRASH IN THE BOWL.IF SO YOU WILL HAVE TO TKE THE CARB APART
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
