Question about Whirlpool LEB6300 Electric Dryer
There's heat, the drum turns, but no air flow, clothes remain damp after 3 cycles! ??
    President:
  • 1,430 Answers
The blower wheel has broken. This is a common failure and easy to replace. Here is a couple links that should help
http://appliancehelponline.com/dryernoisyge.html
http://appliancehelponline.com/dryerblowerassy.html
Posted on Jul 13, 2010
Why won't my dryer heat up sometimes?
It may be a cracked ignitor. check the ignitor and look for any white spots. these can be an indication of a crack which can cause intermittent problems. Replace if necessary. Hope this helps.
Bob
Jul 18, 2014 | Maytag MDG16PD Gas Commercial Dryer
Doesn't dry
Drying consists of removing moisture through heat and airflow. Check to make sure that your venting tube is not kinked somewhere and therefore not allowing the air to flow freely from the dryer.
Apr 11, 2014 | AEG T57800 Electric Dryer
Hello I have a Beko DRCT 70w.When i turn it on to
you have a bad air flow problem...try takeing your vent hose of and run a load to see if it dryies faster
Oct 03, 2013 | Dryers
Clothes still damp after 2 cycles
Many times one pole of a double pole breaker may trip allowing the dryer to operate but with no heat. Go to the electric panel and reset the circuit breaker for the dryer. Also check to insure there is air flow at the vent a clogged vent willl prevent clothes from drying
Feb 26, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I have model 110.60832990 and the dryer is on the drum is turning, the heat is on but the clothes are not drying.
Check the air outlet and see it is not clogged with dirt/flint. Clean the air filter mesh located at the air outlet of flint. This blocks the free flow of air and thus do not dry the clothes. Drying will take place when the air inside has free flow. Before putting clothes in the dryer EVERYTIME this filter must be cleaned OR after every drying cycle.
Aug 29, 2010 | Dryers
My dryer will only slightly dry my clothers
make sure you have the required 240 volts to the unit,then check the high-limit and cycling thermostat(s) on the element case and make sure you have good air flow through out the unit,if its plugged with lint air won't flow and it won't dry right
Apr 26, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Clothes aren't dry
Heating and not drying can be caused by 3 different things. I will address all three most common first
- Restricted air flow, usually a blocked vent. If the moisture from the laundry cannot get outside and fresh air in the dryer you will take extra long to dry. Be sure there is ventilation into the laundry room and more important make sure the vent is not kinked behind the dryer and that it is clean and allowing good air flow. You can go outside to where the vent terminates and feel the flow while it is running to check.
- Sensor has build up on it. Look in the dryer drum, inside on the back wall, inside on the front wall, somewhere depending on your model you will two strips of metal about the size of a pencil. Clean those with a little alcohol. Those are what sense the wetness of the clothes and control the cycle. If they get a build up residue on them they do not sense properly.
- The load is mixed, meaning you have some articles that absorb moisture like towels and some light garments that dry fast, the fast drying articles can fool the dryer into thinking the entire load is dry when the heavy articles are not.
Apr 23, 2010 | Frigidaire Electric Dryer
Clothes Arent Drying
Try running a load without the venting connected. Your venting may be plugged. If that isn't it, check the heat element. Inspect it for a break. It may heat partially if it is broken and touching the housing. Hope this helps!
Feb 08, 2009 | Kenmore Dryers
Dryer not heating every cycle
A fellow once told me to do the simple things first.  Is the filter and the area where the filter goes in completely clear of lint?  Is the outlet discharging air in large or reduced amounts?  Make sure all is clean and flowing alot of air.  Oh, and check this before replacing other parts....turn both breakers off and then back on.  You may be running on 110 volts which will cause half of some heat elements from working at all or from working at full capacity.  If you've still got a problem and the clothes have been spun to mild dampness by your washer, you may need either a new element or new thermostat.
Nov 15, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool LEB6300 Electric Dryer Logo
53 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
