Question about Lucent AT&T Speakerphone 832 (21215)
I have an old 2-line 832 att speakerphone (now Lucent I believe) and it's pretty much bit the dust. I can't find another anywhere. i need a replacement as close to this as possible. Any suggestions?
I need to turn the ringer OFF on my AT&T 210/Lucent TrimLine.....sounds like a fire alarm...!!!
Search Results
FAQs - AT&T® Telephone Store
https://telephones.att.com/product-support/faqs/symptom/1591/89 Tip 1 of 8. If the phone does not ring at all, you may have the ringer turned off. The handset and base have independent ringer programming. To adjust the handset ringer volume: Step 1: Press MENU/SELECT on the handset when it is not in use. Step 2: Press ?DIR or ?CID to display Ringers, then press MENU/SELECT. Missing: lucent
[PDF]TRIMLINE® Memory Telephone 210 - Amazon S3
s3.amazonaws.com/szmanuals/62619bc8d4792f47b6654ed48c3548a3 AT&T and the globe symbol are registered trademarks of AT&T Corp. licensed to Advanced American .... Ringer Volume. The RINGER volume switch allows you to turn the telephone ringer OFF, or set it to ring at LO or HI volume. You can dial or answer calls normally when the ringer is off. Other telephones in your home will.
How to change the ringer tone on the AT&T Trimline 210 - YouTube
? 2:58
https://www.youtube.com/watch?v=xZxexCm7xtk
Apr 30, 2016 - Uploaded by kmbfanofpacman
I just figured out how that works after the day I got the phone and its pretty cool to be honest.Missing: my ‎lucent
[PDF]AT&T 210 User manual - Multi-Link Inc.
https://multi-link.net/wp-content/uploads/ATT-ATT210-Manual.pdf Make sure the ringer volume switch is not set to OFF. You may have inadvertently turned off the ringer. Press. ,. , , . If there are several other phones on the same ... 11. 12. For Customer Service Or Product. Information, Visit Our Website At www.telephones.att.com. User's manual. Part 2. TRIMLINE. Memory telephone 210. Missing: my ‎lucent
Lucent AT&T Trimline 210 Corded Phone Ring tone - Questions (with ...
www.fixya.com > ... > Lucent > Lucent AT&T Trimline 210 Corded Phone
Lucent AT&T Trimline 210 Corded Phone, ring tone related issues. ... If the ringer volume has been turned off, the handset will not ring ? ... ...ring tone im receieveing the voice ring tone but prefer the volume how can i change my ringtone When the phone is sitting in its normal mode hitting the "flash" button toggles through ...
Apr 07, 2018 | AT&T Lands Phones
How to program speed dial
Directly from the manual for the ATT 822:
Storing numbers:
1. Press Line 1 or Line 2
2. Lift handset or press SPKR.
3. Press PROGRAM
4. Dial the telephone number you want to store. If you want to include a 3 second delay, press PAUSE where the delay is needed.
5. Press the memory button where you want to store the number. You will hear two beeps to confirm that the number has been stored correctly.
Good luck !!
Jul 12, 2010 | Lucent AT&T Speakerphone 822 (21213)
I used my ATT 830 phone as a wall phone and now want to use it as a desk phone. Where can I get the base for desk use?
On the bottom of the phone remove the plastic cover from the bottom half of the phone and re-install it on the top half. The phone will now be at the proper angle for desk use.
Jun 08, 2010 | Lucent AT&T Speakerphone 830 (21214)
Programming numbers
Press the button at the bottom left corner in the one touch dial section.  Dial the number you wish to program.  Press the memory button which you'd like the number stored under.  Repeat as needed.
Aug 25, 2008 | Lucent AT&T Speakerphone 825 (21211)
Lucent AT&T Speakerphone 832 (21215) Logo
110 people viewed this question
Top Lucent Lands Phones Experts
Paul C.
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
