Question about Maytag Washing Machines
We have a front load Maytag Neptune machine. After a wash there is water behind the drum that does not go away - the clothes are spun as they should, but there is a lot of water back there - you can tell by trying to spin the drum.
  • 2 more comments
  • levitesyona Jul 13, 2010
    Thanks. The problem is that there is a stale smell inside the machine - i thought it is from that water. What could be its source?
    The machine smells bad after a day or two - i thought it is because of that water. What can be the reason?
    thank you
    Great thanks - we just moved to a house with this washer and i was sure it is broken!!!!!
  • 259 Answers
This water that you are hearing is actually a calcium chloride solution in the tan/gray colored ring at the front of the stainless steel inner wash tub. This ring is called a balance ring and is made internally to force the solution to walk up stair step like chambers inside the ring to off set any off balance load conditions. So for example if you had only one garment in the tub and the machine tried to spin, the solution would be moved to the opposite side of the ring via the out of round motion the tub begins to make.
If you place your hand flat on the ring you will actually be able to feel the solution inside the ring move around.
This ring is present on all the "MAH" models.
IF this is not the answer to your question, feel free to comment back and I will tell you anything and everything you ever want to know about your machine.
Thanks and Good luck!
Posted on Jul 13, 2010
  • Robert DeStevens
    Robert DeStevens Jul 13, 2010
    On the neptune washers a trick the factory recommended was to use some lemon scented dishwasher powder (enough for two loads in a dishwasher), one cup of bleach (directly in tub) and run it on a cottons sturdy cycle with the extra rinse on and hot wash selected.
    Since then there have been products release to the market to combat odors in front load machines such as Affresh. You can find such products in your supermarket or on-line.
    I have a neptune at my house and do the bleach and lemon dishwasher detergent trick about once a month and I leave the door open after use. I also clean the door boot regularly to try to prevent mildew growth.
    Hope this helps you!!
My 10+ year old Maytag Neptune washer has standing water behind the drum after the spin cycle
Griffin is correct but, I took it one step further and removed the front cover and rubber gasket and used a long thin brush after spraying white vinegar with a spray bottle and cleaned all the **** from around the drum. I use white vinegar with clothes once in a while to keep the drum free of built up soap and softner.Its a little work but trust me when you see all the stuff on the drum you will understand why the machine stinks. I also leave my soap tray door open all the time to allow air inside.
Oct 29, 2012 | Maytag Neptune MAH5500B Front Load Washer
Mah7500aww
what it sounds like is the drain from your house wher the washing machine drain hose hooks into is daraining slow so after it spins and pumps the water out the pump shuts off but the drain hose is syphoning the water back into the machine,theres probally lint built up in your drain pipe
Jul 09, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    I am getting little brown spots on my white clothing. Bleach seems to take them out. It just started happening.
    sounds like a rear drum shaft seal may be leaking and getting either rust or brown grease spots on your clothes.If this the case,you should be able to see signs of water leakagein the back of the unit.Take the rear cover off and look in the area behind the large drum pulley.This problem also usually results in noisy operation eventually.The water would be getting into the tub bearing behind the seal.
    Aug 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
    Why isn't the maytag neptune draining? when you spin the barrel you can hear water?
    if you do not see water in the tube and the clothes have spun out enough to go into the dryer when the washer cycle finishes the washer has drained out all of the water the water you hear in the tub when the door is open and you spin the tub with your hand that liquid is in the sealed balance ring , that is a sealed channel around the front of the tub to help the machine stay balanced it does not come out
    Apr 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
    When i spin wash tub wigth my hand i can hear lots of water still in the machine under neath the wash basin
    That is becouse most washing machines are made up of an inside drum where your clothes are washed and an outside durm that catches the water when the washer spins the water out of the washed clothes. A pump is connected to the bottom of the outside drum. If the pump fails, the water would not get pumped to the drain and would collect in the outside drum.
    Aug 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Water drips out of front door
    There does obviously need to be water in the drum to wash or rinse the clothes, however it may be the water level is now higher than normal , check for any blockages and check any drain pump filter.If all o.k. it may be the door seal is leaking .If under g/tee call maytag for repair
    Jan 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
    My Maytag Front load stack unit washer/dryer model # MLE2000AYW
    I had a similar problem, My washer spun but the clothes were still soaked with water. We replaced the inertia switch. That solved it.
    Dec 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Maytag neptune front load odor
    its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
    Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Washing Machines Logo
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
