Question about Kenmore 24032\24036 Top Load Washer
Hot water turned on but not going into the machine
  • Kenmore Master
  • 2,699 Answers
Take the hot water line off the back of washer and stick it in the machine and then turn the water on,if water comes out of the hose you have a bad water valve on the back of the washer,if no water comes out of the hose,you have a problem with the house water valve and not the washer
Posted on Jul 14, 2010
Hot water when cold is selected
""Selectedd cold / cold and machine fills with hot water.""
Is your machine a FAV6800A or FAV9800A? If it's one of those I Have specific info to troubleshoot in Service Mode.
We will go into Service mode and turn on the Hot and Cold water inlet valves from the console and make sure the correct water inlet valve opens and fills the machine...........Rich
and a p/n if you need to replace the water inlet valve assembly.
Apr 29, 2010 | Maytag Neptune FAV6800AW Top Load Washer
No hot water
Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine isn't working the way it used to--or should--try these tests:
  • Is the hot water turned on? If not, turn it on.
  • Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct.
  • Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
  • Sep 21, 2008 | Hotpoint VBXR1090D Top Load Washer
    Getting cold water in machine can't get hot water, have hot water through out house
    Turn off the water and reverse the hot and cold water connections going into the faucet, then turn the water back on. If only hot water comes out of the unit when on cold temperature then you need to order a water valve solenoid which I suspect is the problem or wash only in cold water. They are replaced by removing the back washer panel a couple of bolts, one connector, and two hose clamps. Remember to restore the hot and cold water connections.
    Jan 20, 2010 | Fisher and Paykel Washing Machines
    The wm does not accept cold water. I put it on cold cycle and it does not work the water line is fine... what could be the problem ?
    Why has nobody mentioned the fact that if you “draw off” hot water using a tap beside the washing machine you can get “instant” hot water to your hot-fill. I have been doing this for years – now that all my hot water is heated by a crabon-neutral energy source (either wood or solar) I feel it is even more energy efficient.
    As for water consumption, my house has a secondary return pipe on the hot water circuit with a temperature sensor fitted to the pump so that it only switches on when you turn a hot water tap on – you than turn the tap off, wait 5-10 minutes while the water circulates, then turn it on again, by which time the hot water only has ashort distance to travel and you don’t waster much down the drain.
    However, I have been interested to read about the pros of cold fill only, especially the arguments about such a small volume of water being used anyway and the possibly improved wash performance? Also, I was dismayed to read that washing machines with hot and cold fill don’t use the hot wate very efficiently.
    So would I be better off going for a hot and cold machine while they’re still available or going for a high-efficiency cold fill only machine? I am still minded to get an LG with hot and cold fill… comments please?
    Dec 04, 2009 | Washing Machines
    Water flows in cold side of water valve and out hot side valve
    It seems unlikely that something went wrong just from moving it unless it got banged up!
    It sounds like you may have stripped the hot side.
    I'm assuming the water is going in the cold side and out the hot side and out the back.
    If this is so and you are happy with just cold water try this:
    Go to a Plumbing Store and buy a cap for the leaking intake...if it still leaks you can try soldering the two together!
    I hope this was helpful.
    Good Luck!
    Jan 20, 2009 | Maytag PAV2300 Top Load Washer
    Water Leak
    take channel locks and tighten the hose connections going to the back of the washer
    also tighten the connections going to the hot and cold water bibbs
    remember turn to the right (clockwise to tighten
    Jan 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Hot water not going into washing machine
    hi there,
    try the following, it may help:
    * Is the hot water turned on? If not, turn it on.
    * Is the washer getting cold water but no hot water? If so, check to see if the control panel
    Nov 05, 2008 | Frigidaire Gallery GLWS1339EC Top Load...
    Hotpoint BWM129
    hi there,
    Apr 18, 2008 | Hotpoint BWM12 Front Load Washer
    No hot water to wash
    Is the hot water hot that is coming to the washer? Are you using the correct settings on the unit? If yes to both then either the solinoid water valve is bad or the timer switch unit is bad. Try going to a totally hot water setting. While turning on the machine feel of the hot water line at the machine and see if you notice a buzz or feel a click as you turn on the machine. On this setting does water run in and is it hot or cold. If water runs and it is cold try going to a total cold setting and see if you get cold or hot water. Is this a new setup or has it been working and stopped? If new, you could have the hoses connected backward. If you get water in both hot and cold settings but cold both ways then your hot water heater is not working....let me know....
    Feb 10, 2008 | Frigidaire FEX831CS Top Load Stacked...
    Kenmore 24032\24036 Top Load Washer Logo
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
