Question about KitchenAid Pro Line KPCM050
When I turn the on switch on to start the brewing process the blue light comes on and beeps..then goes back dark and nothing happens. No coffee for me. always worked great until this happened. No local service facility. ron
I just bought a used one of these on ebay and started having the same problem. It worked 3 times in a row, then had the same trouble you describe. I think there is some sensitivity with the water level. I started with 8 cups, then added 2 more and it still didn't stay turned on. Then my husband said the previous pot shorted him 2 cups of coffee, meaning that 2 cups of water was still in the pot when I started it. So I dumped out all the water and tried it one last time and it worked right away with 8 cups of water. Try emptying your water, dumping it upside down, add new water, then plug in and turn on. Good luck.
Posted on Sep 02, 2012
SOURCE: Kenmore Coffeemaker 100.82006
hi gayley i could have wrote your post. i am so mad . i brought this coffee pot in oct. or nov and really liked it . it brews really fast . now i cant find the receit. hope some one knows what to do
Posted on Feb 16, 2008
Coldcut
  • 1554 Answers
SOURCE: turn off beeping alarm when the coffee maker is done brewing
you can't ,its up in the top behind the controls.
you have to take the pot totally apart.
only a trained tech should attempt this.
Posted on Apr 02, 2008
SOURCE: delayed brewing
The problem is in the sensor that tells the coffee maker when the brew cycle is complete. This is a heat sensor that's clipped to the heating element. The sensor gets overly sensitive and shuts things off too soon. Since schematics and parts aren't available for this unit, it's pretty much junk after it starts to fail. You can remove the sensor, but this creates a major fire hazard. My advice is to pick up a good percolator and forget the drip units. The Grind-N-Brew makes excellent coffee, but they barely last out the warranty and the cost of replacing them mounts up. I've gone through two (same problem with both) and it's no longer worth it to me.
Posted on Jul 26, 2009
SOURCE: Need To Turn Off Beeping After Coffee Brews
on my 12 cup kitchenaid coffee maker, i can press and hold the Auto button to enable/disable the alarm
Posted on Dec 21, 2009
SOURCE: I just preapred my Cuisinart to brew coffee. Now,
yes, it is.
Posted on Jan 18, 2010
Green light goes ON but nothing happens
I have the same problem after using it only twice...the store won't take it back as they no longer carry them, and there is no place local to repair them...and I can find nothing online to fix it. it was too expensive of a machine to have this kind of problem that is not easily repairable.
May 07, 2014 | Bodum Bistro b.over Coffee Brewer - Black
Beeping sound, won't brew
Our Hassle-Free Replacement Warranty guarantees that if your PRO LINE™ countertop appliance fails in
the first two years, KitchenAid will replace it free of charge. We will:
  • Deliver a replacement to your door
  • Arrange the return of the failed appliance
  • Guarantee the new appliance for two years
    For more information or complete warranty details on KitchenAid® PRO LINE™ countertop
    appliances, please call Customer Service at 1-800-541-6390 or click here.
    spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif Product Literature spacer.gif Additional Resources
    Feb 15, 2008 | KitchenAid Pro Line Coffeemaker Coffee...
    Set the timer to start brewing, i have always done this with no problem till now
    Could be the brewing mechanism or the timer. However, if you get the action you describe on BREW NOW, I am inclined to think the brewer has failed.
    Nov 10, 2013 | Mr. Coffee 072179228578 12 Cup Coffee...
    Cuisinart dcc 3000..set to self clean and nothing is happening? Both the cleaning light and power light are on. How long does the cleaning process take or is there something wrong with the coffee maker.
    Press the "CLEAN" button and it will light up red. Then press the "ON/OFF" button which will light up blue. Be patient, nothing happens right away, but the cycle has begun. In a few minutes the water reservoir will begin to empty. This self-clean/decalcification process takes approximately 30 minutes. Then pour the water/white vinegar solution out of the coffee reservoir, rinse the water and coffee reservoirs and run one cycle of fresh cold water through before using to brew coffee.
    Sep 17, 2013 | Conair DCC-3000 - Cuisinart Coffee on...
    Coffee maker turns on but will not brew
    why question to all of this is with a "self clean" button, why doesn't it every tell you to clean it..... ??
    Sep 07, 2012 | Cuisinart DCC-1200 Coffee Maker
    My Breville is only a couple weeks old. Over the ...
    Try completely unplugging your pot and then plugging it back in. It is possible that this will reset the programming in your coffee pot. If this doesn’t work, I recommend calling Brevell customer service and they will either help you or probably send you another pot.
    Nov 05, 2017 | Breville BKC600XL Coffee Maker
    Coffee not brewing after grinding
    After grinding did you hear the brew group goes up and pump start? If you hear the pump start and stopped, itis blockage in the brewunit metal screen. Just needs cleaning.
    If you don't hear the pump starting, the problem is with the faulty micro switch inside the gearbox , that is behind the plate of brewunit.(service center job)
    Apr 14, 2010 | Saeco Odea Giro Plus Coffee Maker
    The program light won't stop blinking
    Same here. I'm dead in the water. This started happening a few weeks ago and with patience and luck and different combos of buttons I'd get it to stop and I was able to brew. Today it just stopped completely. The program light either blinks constantly or stays lit constantly, but I cannot brew coffee. I see lots of people online with this problem, but have yet to see a solution.
    Dec 08, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
    Coffee maker beeping
    Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
    Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
    Flashing water light - will drain water but will not make coffee
    Something is wrong on the coffee cycle side of the machine. Check the brew unit screens and and try doing a preground cycle with out inserting coffee. IF water comes out, I would looking into your grinder a little bit and try increasing the grinder size.
    Espresso parts and service
    www.cerinicoffee.com
    Dec 08, 2007 | Saeco Magic De Luxe Espresso Machine
    KitchenAid Pro Line KPCM050 Logo
    114 people viewed this question
    Top KitchenAid Coffee Makers & Espresso Machines Experts
    Dan Webster
    Dan Webster
    graybeard32301
    Ismael Rodriguez...
    Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
