Question about HP Compaq nx6325 Notebook
Does th-e nx6325 have a bios battery if so how do i change it
You gain access to the bios battery by lifting the keyboard. First, undo the external memory cover ( 1 screw) on the bottom of the laptop. Then you will see 2 screws which hold the keyboard down - undo these. Turn the laptop right way up, open it up and move back the 4 small keyboard retaining latches (located at the top edge of the keyboard). The keyboard can now be carefully tilted up by its top edge to reveal the motherboard with the bios battery there in the middle.
Posted on Jan 12, 2011
Bios password
This sounds like your motherboard battery needs to be replaced. I assume you had a password setup and previously never had to change it but now it's on every startup.
Should be relatvely simple to replace as most are simply button type cells but would need information on the laptop to advise further.
Regards
Jul 01, 2013 | HP Compaq nx6325 Notebook
Nx6325 battery
If the battery is not charging,it can be that the battery itself works properly,but the system doesn't indicate that the battery is charging. in order to fix this problem,you will need to reinstall the battery management software by using Device Manager
1.Open Device Manager
Right click on My Computer->select Properties->click Hardware tab->click Device Manager
or if you're using Vista or windows 7,type "device" on the Start menu and select Device Manager
2.Expand the Batteries category
3.Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall .
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
4. On the Device Manager taskbar, click Scan for hardware changes .
Aug 17, 2012 | HP Compaq nx6325 Notebook
Can I migrate the actual processor (AMD tl-50) of my nx6325 to a faster AMD turion tl-64 ?
No
You cannot change or upgrade the processor and graphics card of any laptop or Netbook.
While hard drive and RAM could be changed.
Jul 11, 2011 | HP 430864-001 - HP Compaq nx6325 Full...
Hello, I have a HP Compaq nx6325 laptop. At once my laptop was incapable to start. It was suggested to me to reinstall the Windows. When I start again my laptop to boot from the install CD it was all OK,...
Hi
Try to replace either the RAM Memory is defective or the HDD drive had a bad sector because of Viruses lock up some bad sector in your hard disk drive. Try to replace this parts and reinstall again the Operating system. Regards
Jun 22, 2011 | HP Compaq nx6325 Notebook
How to reset laptop compaq nx6325 bios password
To remove the bios password you need to clear the CMOS.
Open your laptop casing look at your motherboard. locate the CMOS jamper it is near the battery. To clear remove the jamper and turn your computer on with in 5 to 10 seconds and turn it off. Reinsert the jamper back to there proper place and try to turn go to BIOS if there will be a password box appear.
You need to open your laptop and look at the motherboard and locate the CMOS battery. Just remove it with in 5 minutes to clear BIOS password.
Nov 30, 2010 | HP Compaq nx6325 Notebook
How i can move delete bios password on laptop hp nx 63 25or can i get original password
it is not possible to delete the BIOS password set by the user. However, you can try remove and reseating the CMOS battery of the computer. This will delete the BIOS password sometimes. You can refer the manual below to remove reseat the CMOS battery.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00715299/c00715299.pdf
Refer page no:116
i hope this helps u. If not, then the only option is to contact HP or any local computer service center
May 21, 2010 | HP Compaq nx6325 Notebook
Nx6325 keyboard problem: no response ..
fuddi dya keyboard nwa lai la 200 rupye da anna wa
Jan 18, 2009 | HP Compaq nx6325 Notebook
HP Compaq nx6325 Notebook Logo
410 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
