Boot Disc Failure
I'm getting a "boot disc failure" when I boot my PC first thing every day.I usally hit the reset button and it boots normally. When it fails it asks me to insert the system disc and hit enter.....is that the XP disc?
Is there a separate disc I need to get or make to boot this unit if and when the reset no longer works?
Any help would be appreciated..
    Problem Solver:
  • 8 Answers
The disk boot failure could come from a number of sources. I can offer some solutions one or a combination of which will hopefully correct the error.
First, check your BIOS settings to see if S.M.A.R.T drive reporting is enabled. To enter into BIOS please tap F2 key at start up. In the BIOS screen, if the S.M.A.R.T drive is enabled, disable it and give it a test run of 2-3 days under a regular rebooting cycle to see if the error persists. S.M.A.R.T. (Self-Monitoring Analysis and Reporting Technology)is a somewhat outdated standard developed as an "early warning" system to detect hard disk issues. If your desktop is newer, it may not even be available as an option as it is not widely used these days. The SMART technology while useful under certain circumstances had an extremely wide margin of error and would throw errors on boot occasionally when there would be nothing from either a physical or configuration standpoint failing or pending failing in the drive.
While we're in the BIOS, I'd recommend that you ensure that it is recognizing the drive correctly on each startup. The easiest way to ensure this is to reset your BIOS default settings. While on the BIOS screen, look for an indication either along the top or bottom designated by one of the function keys (I believe it used to be F10 to restore defaults). Be sure to save your changes and exit. Again, where you did not get the error every time, you may need to monitor it's progress to see if the error returns.
Second, physically check all cabling. A loose or in some cases failing IDE cable (assuming it is an IDE and not SATA connection) will produce these errors in the Pavilion line (and most others I would well imagine). Power everything completely down, remove the side of the case to give access to the drives and start with reseating the cable both at the drive end and the controller (where they plug into the motherboard) ends. Ultimately, if you were to pick up (or could somehow borrow) a different IDE cable to test for a short time it may also call out a failed or failing cable as well.
Third, we can't overlook the possibility of a failed drive itself. Formatting and/or recovering the drive will most likely not correct an error of this type. If any of the steps resemble those suggested above and have already been attempted, the issue may well point to the disk itself. How old is your system out of curiosity. I realize this option is quite a stretch given the timeframe.
Keeping with issues with the drive itself however, if all steps listed above don't correct the errors, there could be a strong possibility of a failing disk. Since you say it will boot on occasion the failure may not be severe enough at this stage to completely fail, but a total inability to boot may be looming on the horizon.
I hope one or a combination of the recommendations I've made correct your issue. Keep me posted if possible.
Thanks and Regards,
Mithun
Posted on Jul 13, 2010
Disk boot problems
Insert your OS disc to repair the damaged boot sector and then replace the hdd as that could be the cause.
Sep 11, 2014 | Computers & Internet
How can I a boot disk system failure on my Asus without a system disc?
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Nov 30, 2012 | Computers & Internet
System disc
go to your bios and make sure your dvd drive is first in boot order.
Nov 20, 2012 | HP Pavilion a1310n PC Desktop
Laptop not booting
Your computer is trying to boot from a Network or Lan. You need to go into the Bios or System Setup and change the boot order or boot sequence.
Reboot the computer and notice what key the screen says to hit to get into the Bios or System Setup and hit that key. Change your boot order or boot sequence. The best sequence is to have the CD Drive 1st and the Hard Drive 2nd. Changing this in the bios or system setup will make the change permanent. Just make sure when you boot the computer that nothing is in the CD drive unless you have a repair disc or operating system disc in it.
You could make a temporary change but then you will have to change it every time you boot. If you notice the screen when you boot it also gives you the key to hit to change the boot order or boot sequence. This will allow you to change it just for this time that you are booting.
May 03, 2012 | Computers & Internet
Failure to bootup
This message means that the computer could not find the MBR (master boot record) & the most likely cause is a hard disk failure. To prove this obtain an installation disk of an operationg system, say Windows XP, place the disk in the drive, and while its booting up, press F2. From the menu set the boot order to... 1. CD rom drive. Save and exit. The machine will now begin to install the operating system to your hard drive. If you get the same message again, you have a hard drive failure and it will have to be rep-laced.
Apr 05, 2010 | Acer Aspire 3680 Laptop
UNMOUNTABLE BOOT VOLUME
This is most likely due to a HDD failure, Try to boot the computer off a windows disc and try to get to the command prompt through the recovery utility. Once you have a command prompt if possible, type in chkdsk /r hit enter. If you cannot get this far, try uninstalling the hard drive, remove battery, work off the ac adapter only and reinstall the HDD and try to boot it up, if it boots, turn off, reinstall the battery and reboot, hit F8 and choose "last known good configuration".
Jan 07, 2010 | Dell Latitude D810 PC Notebook
Sony vaio pcv rx680g desktop
First, ensure that the bios is reading the hard drive and that the hard drive is part of the boot sequence. If you have a known working drive and the drive is not been read by the bios, you will get the Disc Boot failure error because windows resides on the disc which the bios cannot access.
Secondly, if the bios is reading the disc then ensure that the disc is set as part of the boot sequence-preferably the item after DVD drive should be Hard Disc in the boot menu.
If both of these items are in correct order then you could have a bad boot sector on the drive. Run a C:Chkdsk. If no bad sectors are found try C:Fixmbr-ensure that the Windows installation disc is in the CD/DVD drive when running Fixmbr.
If that fails do a clean install of windows.
Good Luck
Sep 28, 2009 | Sony VAIO Digital Studio PCV-RX680G...
Computer wont start up fully
Your boot menu for Windows is corrupt. Try to boot from the windows installation disc and make sure to key any key when told to boot off the disc. Once the windows files load, you will have a choice of what to do next. If you have XP, choose the repair option and you will be faced with a black DOS screen...after the blinking cursor type
FIXBOOT hit enter
Try to boot the computer without the disc in it. If it does not boot, then boot off disc again and this time type:
FIXMBR hit yes and enter
Try once again to boot without the disc.
Also try to boot into safe mode by tapping F8 when you see the Compaq name come up during starting. If you can get to the multiple boot up option screen, scroll to "Safe mode with networking" and choose that. If it boots then you can go to the start button > accessories > system tools > system restore > choose a restore point back a day or two and follow the prompts.
If you have Vista, boot off the disc and choose start up repair. If that doesn't work, boot again and choose restore computer to an earlier time. Again choose a restore point back a few days. Good luck ParrotHead PC Repair
Sep 06, 2009 | Compaq Evo N610C Notebook
I try to boot my computer from a windows 98 disc, but it won't lo
Hi matthewbugbe,
I think what that means is it does not recognize your hard drive. If you are trying to install Windows 98 you should format your drive first.
Mar 08, 2009 | Microsoft Windows 2000 for PC
Compac disc boot failure
this could be just the boot order, restart the pc and hit F1 or F2 keys, to get into the bios go to boot order and make sure the first boot device is HDD (hard disk drive) hit F10, save and reboot.
keep me informed
regards
Nov 24, 2008 | Compaq Keyboard
Computers & Internet Logo
124 people viewed this question
Alun Cox
David Payne
David Payne
