Question about Fisher Price Power Wheels "Wild Thing" Switch
Battery replacement for FP Take-a-long swing
Where do you find the batteries for the Take a long swing to restore the lights and sounds?
  • 31 Answers
Buy them att shop
Posted on Jul 14, 2010
I am broken down and vehicle swings over but will not start. Engine light is on. battery is good. Beeping noise while swinging
Tthat beeping noise is telling u whats wrong dont let the battery die it will clear the code and u wont find ur problem so charge it every week i need to know the beeping on it
Jan 06, 2015 | 2006 SsangYong Rexton RX
Fisher price my little lamb baby swing will not swing
If it makes a sound but doesn't swing then the metal rod inside the motor casing was probably bent. If it makes no sound then it could be several different problems.
If it does make noise (my daughter did the same thing) then you can fix it, though it's not the easiest fix. Unplug it/remove batteries, and you'll need to remove the legs. Start removing screws to get to the motor casing, the first ones you'll need are in the battery compartment. Be careful as you're doing this, once you get the plastic casing off things can move around. Have someone as a second set of eyes if you need it.
Once you can see the guts look for a thin metal stick, no thicker than a telephone cord. Yup, that's what moves the swing. The metal is easily stressed. You can carefully power it up if you want to see how it works or make sure that little thing is moving. There's a small gear underneath all that, but you don't need to get to it.
Instead, you'll need to beef up that little stick. I used a leftover rubber gasket from a ceiling fan first, then I was so amazed it worked I took it back apart and used a longer piece of rubber tubing with a harder plastic tube over it (it's a very tight fit). It will still need to rock back and forth in it's little hole so don't go too crazy.
The one drawback is that I think it has a louder operation now, but the one thing that both my kids adored with the swing was the rhythmic tick-tock. If baby is happy, mama is happy.
Anyway, FP will sell you a whole new motor, or if you an find the exact part number you might be able to get a new pendulum. But I like fixing stuff, and I like free better, so if this is what yours needs I hope it helps. If this is but you don't follow what I've written I'm happy to try and take pictures of mine.
Aug 30, 2012 | Fisher Price My Little Lamb Dreamy Motions...
Swing stopped working
Had the exact same issue, so I called FP. I had already taken the motor housing off to see if it was something obvious, like a loose connection or broken part. I didn't see anything wrong so I just cleaned it up and put it back together. When I called they offered to sell me a new motor for around $80. Then the lady I was speaking to (who was typing as we talked) said "hey, wait, there's a note in here about this issue..." She said to do what I had done, lightly clean it out with something like a keyboard cleaner, then using the plug (not batteries) set the speed to two/center. It somehow resets it.
That worked for me, and it was free. If that doesn't work then yes, you can get a motor directly from FP. Call the customer service number listed on the back of your manual, if you have it, or 800-432-5437. You'll need to have it nearby so you can give them the model number and year that is listed on the back of the motor housing (open the battery compartment if it isn't on the outside).
You can also get motors online, especially ebay, from any of the papasan swings FP makes. I love this swing so much that I think it's worth it. I've used it for four years now and plan to use it in the future.
Aug 01, 2012 | Fisher Price Starlight Papasan Cradle...
Fisher Price power plus swing
I just went onto Ebay and searched for your tray. A slew of FP trays came up. Good luck!
Jan 06, 2012 | Toys
Done using the fisher price deluxe take along swing. wanting to put it back in original box but can't get it broke down to fit in box. got one part off easy enough but i know it can break down further.
click on this link for the instruction sheet for this swing http://www.fixya.com/postanswer.aspx?thid=9128817&prdid=0&ctgid=0&ref=unsl if its not the Aquarium Take-Along Swing Model go here http://www.fisher-price.com/fp.aspx?st=30&e=search&N=0&Ntk=Products'Articles&Ntx=mode+matchany&type=keyword&Ntt=take and select the model your looking for,, and go to http://service.mattel.com/us/default.asp?from=fp for your instruction sheet
May 04, 2011 | Fisher Price Toys
How do i change the batteries on the fisher price take along aquarium swing?
Insert coin in slot in inside top right side arm (facing swing) & replace with 4 C batteries. I found assembly instructions on Mattel website (/Fisher Price)
Oct 25, 2010 | Fisher Price Ocean Wonders Aquarium Take...
I have the FP Aquarium swing (take along). Where is the battery compartment?
Well, i failed to find anything detailed on where the compartment is, however i found several references to it being located "above the babies head." I hope this helps :)
Jul 29, 2010 | Toys
Fisher Price Power Wheels "Wild Thing" Switch Logo
44 people viewed this question
Top Fisher Price Toys Experts
Bill Boyd
Bruce Mommaerts
Bruce Mommaerts
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
